Darksky 10 Geschrieben 3. Mai 2005 Melden Teilen Geschrieben 3. Mai 2005 Und da bin ich mal wieder mit nem Fehler. Hab seit 2 Tagen auf einmal BlueScreens oder einfach freezes ohne Meldung. gerade habe ich aber folgende bekommen und mal den debugger laufen lassen ;) KERNEL_MODE_EXCEPTION_NOT_HANDLED_M (1000008e) This is a very common bugcheck. Usually the exception address pinpoints the driver/function that caused the problem. Always note this address as well as the link date of the driver/image that contains this address. Some common problems are exception code 0x80000003. This means a hard coded breakpoint or assertion was hit, but this system was booted /NODEBUG. This is not supposed to happen as developers should never have hardcoded breakpoints in retail code, but ... If this happens, make sure a debugger gets connected, and the system is booted /DEBUG. This will let us see why this breakpoint is happening. Arguments: Arg1: c0000005, The exception code that was not handled Arg2: 3ad744fd, The address that the exception occurred at Arg3: b75babd8, Trap Frame Arg4: 00000000 Debugging Details: ------------------ ***** Kernel symbols are WRONG. Please fix symbols to do analysis. MODULE_NAME: win32k FAULTING_MODULE: 804d4000 nt DEBUG_FLR_IMAGE_TIMESTAMP: 4225181e EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - Die Anweisung in "0x%08lx" verweist auf Speicher in "0x%08lx". Der Vorgang "%s" konnte nicht auf dem Speicher durchgef hrt werden. FAULTING_IP: +3ad744fd 3ad744fd ?? ??? TRAP_FRAME: b75babd8 -- (.trap ffffffffb75babd8) ErrCode = 00000000 eax=00000000 ebx=3ad744fd ecx=e2438528 edx=0004e030 esi=e2438528 edi=8639ada8 eip=3ad744fd esp=b75bac4c ebp=00000000 iopl=0 nv up ei pl nz na pe nc cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010202 3ad744fd ?? ??? Resetting default scope CUSTOMER_CRASH_COUNT: 1 DEFAULT_BUCKET_ID: DRIVER_FAULT BUGCHECK_STR: 0x8E LAST_CONTROL_TRANSFER: from bf827f01 to 3ad744fd STACK_TEXT: WARNING: Frame IP not in any known module. Following frames may be wrong. b75bac48 bf827f01 8639ada8 00000001 b75bad34 0x3ad744fd 00010202 00000000 00000000 00000000 00000000 win32k+0x27f01 FOLLOWUP_IP: win32k+27f01 bf827f01 ?? ??? SYMBOL_STACK_INDEX: 1 FOLLOWUP_NAME: MachineOwner SYMBOL_NAME: win32k+27f01 IMAGE_NAME: win32k.sys STACK_COMMAND: .trap ffffffffb75babd8 ; kb BUCKET_ID: WRONG_SYMBOLS Followup: MachineOwner --------- Ka, woher das auf einmal kommt ;) ? Zitieren Link zu diesem Kommentar
Sigma 10 Geschrieben 3. Mai 2005 Melden Teilen Geschrieben 3. Mai 2005 Hallo, im Tipps&Links Bereich findest Du fast ganz oben einen Beitrag von EVIL. Mit den unter Nützliche Links aus dem MCSEBoard.de Tipps+Links Subforum angegebenen Links kannst Du schon mal selbst zu dem Fehler recherchieren. Kleiner Tip: Fehler 1000008e unterscheidet sich bei der Fehlersuche nicht von 0x8E. Was wurde denn am Rechner verändert? Ist der Rechner übertaktet? Tschau, Sigma Zitieren Link zu diesem Kommentar
Darksky 10 Geschrieben 3. Mai 2005 Autor Melden Teilen Geschrieben 3. Mai 2005 Ne ,ist nicht übertaktet! Habe nen AMD Athlon 2100 XP Kudoz7 Maimboard ATI Radeon 9600 TerraTec Audeon Sound und 1024 Ram (Ram iset nicht - habe ich nämlich durchprobier gehabt) Ist auch erst seit 2 tagen auf einmal! Spiele gerade Star Wars KOTOR, wo das oft passiert - geht aber wenn ich den Spound einfach abschalte. Ich frage mich aber woran das beim Sound liegen soll ,da das vorher Problemlos ging auch Counter-Strike etc. Nun schmiert es immer ab. Vorallem liegt ja anscheinend der Fehler bei der win32k.sys und nicht beim Audiotreiber. habe mir die karte ja auch extra neu gekauft! Zitieren Link zu diesem Kommentar
