mr._oiso 10 Geschrieben 12. Mai 2005 Melden Geschrieben 12. Mai 2005 Hallo Board, hallo IOS Freunde Hier mal ein Tip für das Web Management von Cisco Komponenten im Netzwerk. Seit Ende April ist der Network Assistant Version 2.0 von Cisco frei verfügbar. http://www.cisco.com/en/US/products/ps5931/index.html Die unterstützte Hardware : PLATFORMS Managed and Supported Devices The Cisco Network Assistant 2.0 supports the following SMB-Class Cisco Catalyst switches: • Catalyst 2900XL Series • Catalyst 2940 Series • Catalyst 2950 Series • Catalyst 2955 Series • Catalyst 2970 Series • Catalyst 2900 Series • Catalyst 2950 LRE Series • Catalyst 3500XL Series • Catalyst 3550 Series • Catalyst 3560 Series • Catalyst 3750 Series The Cisco Network Assistant 2.0 supports the following Cisco Catalyst modular switches and supervisor engines: • Catalyst 4500 Series Supervisor Engine II-Plus TS • Catalyst 4500 Series Supervisor Engine II-Plus • Catalyst 4500 Supervisor Engine IV • Catalyst 4503 Switch • Catalyst 4506 Switch • Catalyst 4507R Switch • Catalyst 4948 Switch The Cisco Network Assistant 2.0 supports the following Cisco Catalyst modular switch line cards and power supplies: • Catalyst 4500 10/100 Module,24-Ports(RJ45) • Catalyst 4500 10/100 Auto Module, 48-Ports (RJ-45) • Catalyst 4500 10/100 PoE 802.3af 24-ports (RJ45) • Catalyst 4500 PoE 802.3af 10/100, 48-Ports (RJ45) • Catalyst 4500 24-port 10/100/1000 Module (RJ45) • Catalyst 4500 Enhanced 48-Port 10/100/1000 Base-T (RJ-45) • Catalyst 4500 PoE 802.3af 10/ 100/1000 24-ports (RJ45) • Catalyst 4500 PoE 802.3af 10/100, 48-Ports (RJ21) • Catalyst 4500 6-port 1000BASE-X (GBIC) Gigabit Ethernet • Catalyst 4500 1000W AC Power Supply (Data Only) • Catalyst 4500 1300W AC Power Supply (Data and PoE) • Catalyst 4500 2800W AC Power Supply (Data and PoE) The Cisco Network Assistant 2.0 supports the following Cisco routers: • Cisco 800 Series Small Office Home Office Routers • Cisco 1700 Series Modular Access Routers • Cisco 1800 Series Integrated Services Routers • Cisco 2600 Series Multiservice Platforms • Cisco 2800 Series Integrated Services Routers • Cisco 3700 Series Multiservice Access Routers • Cisco 3800 Series Integrated Services Routers The Cisco Network Assistant 2.0 supports the following wireless access points: • Cisco Aironet® 350 Series • Cisco Aironet 1100 Series • Cisco Aironet 1200 Series The following devices are also supported: • Cisco Catalyst 6500 Series Switch with the Catalyst 6500 Supervisor Engine 32 • Cisco PIX 515E Firewall • Cisco IP phones Infos dazu : http://www.cisco.com/en/US/products/ps5931/products_data_sheet0900aecd8017a59e.html MfG Mr. Oiso Zitieren
rob_67 10 Geschrieben 12. Mai 2005 Melden Geschrieben 12. Mai 2005 Hallo Oiso, danke für die info, zum downloaden muss man leider registriert sein. Zitieren
WP3 10 Geschrieben 18. Mai 2005 Melden Geschrieben 18. Mai 2005 Hallo ich hab das tool im einsatz und hab keine problem bisher (2940 2950 3750) Zitieren
tgyssling 11 Geschrieben 19. August 2005 Melden Geschrieben 19. August 2005 Bekommt man das auch ohne Registrierung? Ich habe mich zwar registriert darf aber nicht downloaden Zitieren
sebastian.f 10 Geschrieben 19. August 2005 Melden Geschrieben 19. August 2005 Hallo, Also ich habs mir mal runtergeladen und installiert (habe CCO Account). Bei Cisco steht das der 4506 unterstützt wird. Allerdings sagt der CNA mir wenn ich einen 4506 verwalten will unsupported Device. Ich habe den HTTP Server und SNMP aktiviert. Muss man da sonst noch was konfigurieren? Gruß Sebastian Zitieren
romeo310 10 Geschrieben 19. August 2005 Melden Geschrieben 19. August 2005 geht mir genau so ! Zitieren
sebastian.f 10 Geschrieben 19. August 2005 Melden Geschrieben 19. August 2005 Hallo, also ich habe das Teil jetzt einen Tag getestet und muss sagen es konnte mich nicht überzeugen. Das was Cisco da machen will ist zwar schön aber nicht gerade ausgereift. Contras: - Nur 18 Switches pro Community - Das Topologie Layout stimmt nicht - Topologien lassen sich nicht mehr löschen! - umständliche Bedienung Pros: - fast alle Grundfunktionen lassen sich grafisch einstellen - wenn man die Topologien mal angepasst hat ist es ganz ansehnlich Alles in allem ist Cisco auf dem richtigen Weg mit dem Teil aber es ist bei weitem noch nicht ausgereift. Irgendwie ein Dejavu zum Clustermanager ... Gruß Sebastian Zitieren
