Stadt-Tiger 10 Geschrieben 25. Mai 2005 Autor Melden Geschrieben 25. Mai 2005 Und hier debug von q931 *Mar 1 18:12:40.515: ISDN BR1/0 **ERROR**: host_incoming_call: DIALER ERROR 0x1 : b channel 0, call id 0x73 *Mar 1 18:12:40.519: ISDN BR1/0 EVENT: process_rxstate: ces/callid 1/0x73 callt ype 1 HOST_DISCONNECT_ACK *Mar 1 18:12:40.523: ISDN BR1/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xCD Cause i = 0x8095 - Call rejected *Mar 1 18:12:41.973: ISDN BR1/0 Q931: RX <- BAD PACKET() *Mar 1 18:12:43.476: ISDN BR1/0 Q931: RX <- BAD PACKET() *Mar 1 18:12:45.311: ISDN BR1/0 Q931: RX <- BAD PACKET() *Mar 1 18:12:45.335: ISDN BR1/0 Q931: RX <- SETUP pd = 8 callref = 0x4E Bearer Capability i = 0x8890 Standard = CCITT Transfer Capability = Unrestricted Digital Transfer Mode = Circuit Transfer Rate = 64 kbit/s Channel ID i = 0x8A Calling Party Number i = 0x0080, '0123' Plan:Unknown, Type:Unknown Called Party Number i = 0x81, '3' Plan:ISDN, Type:Unknown Sending Complete *Mar 1 18:12:45.339: ISDN BR1/0 EVENT: process_rxstate: ces/callid 1/0x74 callt ype 1 HOST_INCOMING_CALL *Mar 1 18:12:45.343: ISDN BR1/0 **ERROR**: host_incoming_call: DIALER ERROR 0x1 : b channel 1, call id 0x74 *Mar 1 18:12:45.347: ISDN BR1/0 EVENT: process_rxstate: ces/callid 1/0x74 callt ype 1 HOST_DISCONNECT_ACK *Mar 1 18:12:45.347: ISDN BR1/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xCE Cause i = 0x8095 - Call rejected *Mar 1 18:12:46.793: ISDN BR1/0 Q931: RX <- BAD PACKET() *Mar 1 18:12:48.296: ISDN BR1/0 Q931: RX <- BAD PACKET() *Mar 1 18:12:50.167: ISDN BR1/2 Q931: RX <- BAD PACKET() *Mar 1 18:12:50.187: ISDN BR1/2 Q931: RX <- SETUP pd = 8 callref = 0x4D Bearer Capability i = 0x8890 Standard = CCITT Transfer Capability = Unrestricted Digital Transfer Mode = Circuit Transfer Rate = 64 kbit/s Channel ID i = 0x89 Calling Party Number i = 0x0080, '0123' Plan:Unknown, Type:Unknown Called Party Number i = 0x81, '2' Plan:ISDN, Type:Unknown Sending Complete *Mar 1 18:12:50.195: ISDN BR1/2 EVENT: process_rxstate: ces/callid 1/0x75 callt ype 1 HOST_INCOMING_CALL *Mar 1 18:12:50.199: ISDN BR1/2 **ERROR**: host_incoming_call: DIALER ERROR 0x1 : b channel 0, call id 0x75 *Mar 1 18:12:50.199: ISDN BR1/2 EVENT: process_rxstate: ces/callid 1/0x75 callt ype 1 HOST_DISCONNECT_ACK *Mar 1 18:12:50.203: ISDN BR1/2 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xCD Cause i = 0x8095 - Call rejected *Mar 1 18:12:51.653: ISDN BR1/2 Q931: RX <- BAD PACKET() *Mar 1 18:12:53.156: ISDN BR1/2 Q931: RX <- BAD PACKET() *Mar 1 18:12:55.011: ISDN BR1/2 Q931: RX <- BAD PACKET() *Mar 1 18:12:55.031: ISDN BR1/2 Q931: RX <- SETUP pd = 8 callref = 0x4E Bearer Capability i = 0x8890 Standard = CCITT Transfer Capability = Unrestricted Digital Transfer Mode = Circuit Transfer Rate = 64 kbit/s Channel ID i = 0x8A Calling Party Number i = 0x0080, '0123' Plan:Unknown, Type:Unknown Called Party Number i = 0x81, '3' Plan:ISDN, Type:Unknown Sending Complete Zitieren
Stadt-Tiger 10 Geschrieben 25. Mai 2005 Autor Melden Geschrieben 25. Mai 2005 . . . *Mar 1 18:13:58.771: ISDN BR1/1 EVENT: process_rxstate: ces/callid 1/0x83 callt ype 1 HOST_INCOMING_CALL *Mar 1 18:13:58.775: ISDN BR1/1 **ERROR**: host_incoming_call: DIALER ERROR 0x1 : b channel 0, call id 0x83 *Mar 1 18:13:58.779: ISDN BR1/1 EVENT: process_rxstate: ces/callid 1/0x83 callt ype 1 HOST_DISCONNECT_ACK *Mar 1 18:13:58.783: ISDN BR1/1 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xCD Cause i = 0x8095 - Call rejected *Mar 1 18:14:00.238: ISDN BR1/1 Q931: RX <- BAD PACKET() *Mar 1 18:14:01.736: ISDN BR1/1 Q931: RX <- BAD PACKET() *Mar 1 18:14:14.705: ISDN BR1/0 EVENT: UserIdle: callid 0x8009 received ISDN_HA NGUP (0x1) *Mar 1 18:14:14.705: ISDN BR1/0 **ERROR**: CCBRI_Go: NO CCB Src->HOST call id 0 x8009, event 0x5 ces 1 *Mar 1 18:14:14.705: ISDN BR1/0 EVENT: process_rxstate: ces/callid 1/0x8009 cal Zitieren
rob_67 10 Geschrieben 25. Mai 2005 Melden Geschrieben 25. Mai 2005 aber ein dialer events hast du jetzt noch nicht angehabt, versuch mal bitte ein deb isdn events + debug dialer events und schick nochmal ein sh int bri0 mit Zitieren
Stadt-Tiger 10 Geschrieben 25. Mai 2005 Autor Melden Geschrieben 25. Mai 2005 BRI1/0 is up, line protocol is up (spoofing) Hardware is BRI Description: Verbindung Dialer 1 MTU 1500 bytes, BW 64 Kbit, DLY 20000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation PPP, loopback not set Keepalive set (10 sec) DTR is pulsed for 1 seconds on reset Last input 00:00:07, output 00:00:07, output hang never Last clearing of "show interface" counters 19:03:07 Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: weighted fair Output queue: 0/1000/64/0 (size/max total/threshold/drops) Conversations 0/1/16 (active/max active/max total) Reserved Conversations 0/0 (allocated/max allocated) Available Bandwidth 48 kilobits/sec 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 8762 packets input, 39588 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 8606 packets output, 34842 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 output buffer failures, 0 output buffers swapped out 1 carrier transitions Zitieren
Stadt-Tiger 10 Geschrieben 25. Mai 2005 Autor Melden Geschrieben 25. Mai 2005 *Mar 1 19:04:52.405: ISDN BR1/1 Q931: RX <- BAD PACKET() *Mar 1 19:04:52.425: ISDN BR1/1 Q931: RX <- SETUP pd = 8 callref = 0x4D Bearer Capability i = 0x8890 Standard = CCITT Transfer Capability = Unrestricted Digital Transfer Mode = Circuit Transfer Rate = 64 kbit/s Channel ID i = 0x8A Calling Party Number i = 0x0080, '0123' Plan:Unknown, Type:Unknown Called Party Number i = 0x81, '3' Plan:ISDN, Type:Unknown Sending Complete *Mar 1 19:04:52.429: ISDN BR1/1 EVENT: process_rxstate: ces/callid 1/0x84 callt ype 1 HOST_INCOMING_CALL *Mar 1 19:04:52.433: Di1 DDR: Caller id: Callback server starting to xxx 0123 *Mar 1 19:04:52.433: Could not obtain author data from the previous call *Mar 1 19:04:52.437: ISDN BR1/1 **ERROR**: host_incoming_call: DIALER ERROR 0x1 : b channel 1, call id 0x84 *Mar 1 19:04:52.437: ISDN BR1/1 EVENT: process_rxstate: ces/callid 1/0x84 callt ype 1 HOST_DISCONNECT_ACK *Mar 1 19:04:52.441: ISDN BR1/1 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xCD Cause i = 0x8095 - Call rejected *Mar 1 19:04:53.895: ISDN BR1/1 Q931: RX <- BAD PACKET() *Mar 1 19:04:55.394: ISDN BR1/1 Q931: RX <- BAD PACKET() *Mar 1 19:04:57.229: ISDN BR1/0 Q931: RX <- BAD PACKET() *Mar 1 19:04:57.249: ISDN BR1/0 Q931: RX <- SETUP pd = 8 callref = 0x4E Bearer Capability i = 0x8890 Standard = CCITT Transfer Capability = Unrestricted Digital Transfer Mode = Circuit Transfer Rate = 64 kbit/s Channel ID i = 0x89 Calling Party Number i = 0x0080, '0123' Plan:Unknown, Type:Unknown Called Party Number i = 0x81, '2' Plan:ISDN, Type:Unknown Sending Complete Zitieren
Stadt-Tiger 10 Geschrieben 25. Mai 2005 Autor Melden Geschrieben 25. Mai 2005 *Mar 1 19:04:57.257: ISDN BR1/0 EVENT: process_rxstate: ces/callid 1/0x85 callt ype 1 HOST_INCOMING_CALL *Mar 1 19:04:57.257: Di1 DDR: callback to xxx already started *Mar 1 19:04:57.257: Could not obtain author data from the previous call *Mar 1 19:04:57.261: ISDN BR1/0 **ERROR**: host_incoming_call: DIALER ERROR 0x1 : b channel 0, call id 0x85 *Mar 1 19:04:57.261: ISDN BR1/0 EVENT: process_rxstate: ces/callid 1/0x85 callt ype 1 HOST_DISCONNECT_ACK *Mar 1 19:04:57.265: ISDN BR1/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xCE Cause i = 0x8095 - Call rejected *Mar 1 19:04:58.715: ISDN BR1/0 Q931: RX <- BAD PACKET() *Mar 1 19:05:00.214: ISDN BR1/0 Q931: RX <- BAD PACKET() *Mar 1 19:05:02.041: ISDN BR1/0 Q931: RX <- BAD PACKET() *Mar 1 19:05:02.061: ISDN BR1/0 Q931: RX <- SETUP pd = 8 callref = 0x4D Bearer Capability i = 0x8890 Standard = CCITT Transfer Capability = Unrestricted Digital Transfer Mode = Circuit Transfer Rate = 64 kbit/s Channel ID i = 0x8A Calling Party Number i = 0x0080, '03139630' Plan:Unknown, Type:Unknown Called Party Number i = 0x81, '3' Plan:ISDN, Type:Unknown Sending Complete Zitieren
rob_67 10 Geschrieben 25. Mai 2005 Melden Geschrieben 25. Mai 2005 also ich werd nicht so richtig schlau aus der ganzen geschichte, ich würde einfach mal ein anderes ios, wenn verfügbar, probieren Zitieren
Stadt-Tiger 10 Geschrieben 25. Mai 2005 Autor Melden Geschrieben 25. Mai 2005 Hallo Rob, leider habe ich kein weiteres IOS. Liebe Grüße Zitieren
rob_67 10 Geschrieben 25. Mai 2005 Melden Geschrieben 25. Mai 2005 Hallo Stadt Tiger, wie ist den jetzt der Stand, geht es sporadisch, dauert es sehr lange für den Verbindungsaufbau oder geht es gar nicht mehr? Zitieren
Stadt-Tiger 10 Geschrieben 25. Mai 2005 Autor Melden Geschrieben 25. Mai 2005 Hallo Rob, es geht jetzt garnicht mehr. :( Liebe Grüße Zitieren
rob_67 10 Geschrieben 25. Mai 2005 Melden Geschrieben 25. Mai 2005 boot doch mal den router, wenns dann wieder geht, wäre ein neues ios schon sinnvoll Zitieren
Stadt-Tiger 10 Geschrieben 25. Mai 2005 Autor Melden Geschrieben 25. Mai 2005 Neu gestartet habe ich den Router bereits und einwählen kann man sich, wenn man nicht gerade in einer der externen Stellen sitzt. Aber ich habe zum Glück gestern demonstriert, dass es läuft... Zitieren
