PoE-Lampe blinkt .. faulty
Seit einiger Zeit blinkt die PoE-Lampe am Switch (3750). Laut dem Cisco Network Assistent ist der Port Fa1/0/9 bei dem Power-State dafür verantworlich. Der zeigt nämlich "faulty" an. Ich habe das Kabel mal rausgezogen, doch es blinkt immer weiter. Weiß jemand, ob das jetzt schlimm ist oder er sich von selber beruhigt ?
danke
http://http//www.cisco.com/en/US/products/hw/switches/ps5023/products_installation_guide_chapter09186a00801f2705.html ...
PoE mode LED blinks amber
Note When the PoE mode is selected, a green PoE LED means that the port status LEDs show the PoE status. At least one PoE port has a fault, or power has been denied to at least one of the PoE ports.
Caution PoE faults are caused when noncompliant cabling or powered devices are connected to a PoE port. Only standard-compliant cabling can be used to connect Cisco pre-standard IP Phones and wireless access points or IEEE 802.3af-compliant devices to PoE ports. A cable or device that causes a PoE fault must be removed from the network.
Use the Mode button to show the PoE status for all ports. The affected port LEDs blink amber or alternate green and amber.
If a port LED blinks amber, there is a PoE fault. A cable or device that causes a PoE fault must be removed from the network.
If a port status LED is alternating green and amber, connect the powered device to an external AC power source.
Gruss
Robert
