dcdiag schwerwiegende fehler am dc w 2003
Hallo liebe Forumsteilnehmer.
Wir haben auf unserem PDC schwerwiegende Fehler seitdem sich ein ****ing Trojaner breitmachte. Darf man so Hacker eigentlich erschießen?
Nun zum Problem:
rpc server antwortet nicht.
ich mache dcdiag mit folgendem Ergebnis:
C:\>dcdiag
Domain Controller Diagnosis
Performing initial setup:
Done gathering initial info.
Doing initial required tests
Testing server: de-53113-adenaueralle77\SERVER001
Starting test: Connectivity
The host 2ff435a2-1e6b-4d80-804b-f6624013aef3._msdcs.eurojuridicumag.lo
cal could not be resolved to an
IP address. Check the DNS server, DHCP, server name, etc
Although the Guid DNS name
(2ff435a2-1e6b-4d80-804b-f6624013aef3._msdcs.eurojuridicumag.local)
couldn't be resolved, the server name
(server001.eurojuridicumag.local) resolved to the IP address
(192.168.10.21) and was pingable. Check that the IP address is
registered correctly with the DNS server.
......................... SERVER001 failed test Connectivity
Doing primary tests
Skipping all tests, because server SERVER001 is
not responding to directory service requests
Running partition tests on : ForestDnsZones
Starting test: CrossRefValidation
......................... ForestDnsZones passed test CrossRefValidation
Starting test: CheckSDRefDom
......................... ForestDnsZones passed test CheckSDRefDom
Running partition tests on : DomainDnsZones
......................... DomainDnsZones passed test CrossRefValidation
......................... DomainDnsZones passed test CheckSDRefDom
Running partition tests on : Schema
......................... Schema passed test CrossRefValidation
......................... Schema passed test CheckSDRefDom
Running partition tests on : Configuration
......................... Configuration passed test CrossRefValidation
......................... Configuration passed test CheckSDRefDom
Running partition tests on : eurojuridicumag
......................... eurojuridicumag passed test CrossRefValidatio
n
......................... eurojuridicumag passed test CheckSDRefDom
Running enterprise tests on : eurojuridicumag.local
Starting test: Intersite
......................... eurojuridicumag.local passed test Intersite
Starting test: FsmoCheck
......................... eurojuridicumag.local passed test FsmoCheck
C:\>
wer weis rat?
Vielen Dank,
Daniel
sorry, aber da fehlt das netdiag:
C:\>netdiag
Computer Name: SERVER001
DNS Host Name: server001.eurojuridicumag.local
System info : Windows 2000 Server (Build 3790)
Processor : x86 Family 15 Model 2 Stepping 7, GenuineIntel
List of installed hotfixes :
KB898715
Q147222
Netcard queries test . . . . . . . : Passed
GetStats failed for 'Parallelanschluss (direkt)'. [ERROR_NOT_SUPPORTED]
[WARNING] The net card 'WAN-Miniport (IP) - Paketplaner-Miniport' may not be
working because it has not received any packets.
GetStats failed for 'WAN-Miniport (PPTP)'. [ERROR_NOT_SUPPORTED]
GetStats failed for 'WAN-Miniport (PPPOE)'. [ERROR_NOT_SUPPORTED]
[WARNING] The net card 'WAN-Miniport (IP)' may not be working because it has
GetStats failed for 'WAN-Miniport (L2TP)'. [ERROR_NOT_SUPPORTED]
Per interface results:
Adapter : onboard-intern01
Netcard queries test . . . : Passed
Host Name. . . . . . . . . : server001
IP Address . . . . . . . . : 192.168.10.21
Subnet Mask. . . . . . . . : 255.255.255.0
Default Gateway. . . . . . : 192.168.10.1
Dns Servers. . . . . . . . : 192.168.10.1
192.168.10.21
AutoConfiguration results. . . . . . : Passed
Default gateway test . . . : Passed
NetBT name test. . . . . . : Passed
WINS service test. . . . . : Skipped
There are no WINS servers configured for this interface.
Global results:
Domain membership test . . . . . . : Passed
NetBT transports test. . . . . . . : Passed
List of NetBt transports currently configured:
NetBT_Tcpip_{8E2933C4-00EA-4618-BF20-550682EF48CB}
1 NetBt transport currently configured.
Autonet address test . . . . . . . : Passed
IP loopback ping test. . . . . . . : Passed
Default gateway test . . . . . . . : Passed
NetBT name test. . . . . . . . . . : Passed
Winsock test . . . . . . . . . . . : Passed
DNS test . . . . . . . . . . . . . : Failed
[WARNING] Cannot find a primary authoritative DNS server for the name
'server001.eurojuridicumag.local.'. [RCODE_SERVER_FAILURE]
The name 'server001.eurojuridicumag.local.' may not be registered in
DNS.
[WARNING] The DNS entries for this DC are not registered correctly on DNS se
rver '192.168.10.1'. Please wait for 30 minutes for DNS server replication.
rver '192.168.10.21'. Please wait for 30 minutes for DNS server replication.
[FATAL] No DNS servers have the DNS records for this DC registered.
Redir and Browser test . . . . . . : Passed
List of NetBt transports currently bound to the Redir
The redir is bound to 1 NetBt transport.
List of NetBt transports currently bound to the browser
The browser is bound to 1 NetBt transport.
DC discovery test. . . . . . . . . : Passed
DC list test . . . . . . . . . . . : Passed
Trust relationship test. . . . . . : Skipped
Kerberos test. . . . . . . . . . . : Passed
LDAP test. . . . . . . . . . . . . : Passed
Bindings test. . . . . . . . . . . : Passed
WAN configuration test . . . . . . : Skipped
No active remote access connections.
Modem diagnostics test . . . . . . : Passed
IP Security test . . . . . . . . . : Skipped
Note: run "netsh ipsec dynamic show /?" for more detailed information
The command completed successfully
C:\>
Hallo rdsbonn,
wenn Du sicher bist, dass Euer Produktiv-PDC gehackt wurde - dann mach ihn neu! Um die Domäne funktionsfähig zu erhalten, kommt es jetzt auf sorgfältige Planung an.
Wann wurde der Rechner gehackt - gibt es eine saubere Sicherung? Habt Ihr weitere DCs laufen - und sind die noch sauber? Wenn ja, hast Du eine gute Basis, den PDC schlicht zu demoten und das System neu zu installieren, weil die AD durch die Replikation erhalten wird.
Ein einmal von Trojanern kompromittiertes System ist grundsätzlich nicht mehr als sicher zu betrachten. Ich sehe keine Alternative - das wäre viel zu gefährlich. Ich verweise ansonsten mal auf meinen Beitrag HIER und die zitierten Threads, falls Du noch zögerst, die Neuinstallation in Angriff zu nehmen.
Gruss Jan
also der server wurde bereits 2003 aufgesetzt. es wurde auch ein exchge 2k3 drauf installiert.
zur zeit muss er also repariert werden, erst ab august gibt es neu server.
ich bin mir aber 100 %ig sicher, das alle trojaner entfernt wurden. der rechner ist bis auf den fehler absolut sauber.
er steht zudem hinter einer symantec enterprise firewall, welche im log ein perfektes verhalten bestätigt.
einzig der dc spinnt, ich km darauf, weil sich keine rpc mehr starten ließen. der remotedesktop funkt nicht mehr, eine msde ließ sich ebenso nicht installieren.
kannst du mir bei dem dns problem helfen?
gruß, daniel
Die für das Unternehmen sicherste Reparatur ist die Neuinstallation des DC, und dafür brauchst Du keinen neuen Server. Reparaturen an den bestehenden Symptomen wachsen sich schnell zur Frickelei aus.
Das möchte ich Dir ja gerne glauben, nur vom Sicherheitsstandpunkt aus ist gerade das unklug. Kein Tool findet alles, Du KANNST eben nicht sicher sein. PS: Welche Trojaner hast Du identifiziert und mit welchen Tools? Wann war das? Wie lange waren die auf dem System aktiv, bevor Du die Infektion bemerkt und die Trojaner gelöscht hast?
Du schreibst selbst: alle Trojaner - das klingt für mich nach mehrfacher und anwachsender Infektion, wenn ein Hacker sich erst Zugriff verschafft und den dann zügig ausgebaut hat. Das ist also nicht sofort bemerkt worden und der/die Hacker haben sich richtig schön austoben können?
Was heisst denn hier perfektes Verhalten? Keine ungewöhnlichen offenen Ports vielleicht, OK. Hoffentlich aber nicht, dass ein Hackertool z. B. Passwortdumpdateien all Eurer Mitarbeiter über den ganz normalem FTP Port 21 versendet? Bedenke: diese Firewall hat Euch vor dem Angriff nicht schützen können - es sei denn, der Angreifer kam von innen!
Nein, ich sehe nicht, wo es da genau hakt. Ausser Abarbeiten der ganz normalen DNS-Checklisten (gibt's bei Microsoft) als erster Schritt fällt mir im Moment nix ein. Vielleicht hat ja ein anderer unserer User eine Idee dazu.
Gruss Jan
