automatische Updates - Dienst wird beendet
Hallo!
Ich habe einen W2k3 Server (incl. WSUS) mit 2k und XP Clients im Einsatz.
Alle 2k Clients und auch der 2k3 Server übernehmen die Einstellungen der GPO und installieren die Updates. An den XP Clients bekomme ich im Log folgende Fehlermeldung (wirklich alle XP Clients):
2005-06-22 09:42:18+0200 1224 c98 Service Main starts
2005-06-22 09:42:18+0200 1224 c98 Using BatchFlushAge = 20878.
2005-06-22 09:42:18+0200 1224 c98 Using SamplingValue = 900.
2005-06-22 09:42:18+0200 1224 c98 Successfully loaded event namespace dictionary.
2005-06-22 09:42:18+0200 1224 c98 Successfully loaded client event namespace descriptor.
2005-06-22 09:42:18+0200 1224 c98 Successfully initialized local event logger. Events will be logged at C:\WINDOWS\SoftwareDistribution\ReportingEvents.log.
2005-06-22 09:42:18+0200 1224 c98 Successfully initialized NT event logger.
2005-06-22 09:42:18+0200 1224 c98 Successfully initialized event uploader 0.
2005-06-22 09:42:18+0200 1224 c98 Reopened existing event cache file at C:\WINDOWS\SoftwareDistribution\EventCache\{E09ABEFA-A1A4-4BA0-B01C-48D41911BF15}.bin for writing.
2005-06-22 09:42:18+0200 1224 c98 Successfully initialized event uploader 1.
2005-06-22 09:42:18+0200 1224 c98 Client call recorder fails to init with error 0x80004015
2005-06-22 09:42:18+0200 1224 c98 WU client with version 5.4.3790.2182 failed to initialize with error 0x80004015 from component agent
2005-06-22 09:42:18+0200 1224 c98 Failed to initialize WU client: 0x80004015
2005-06-22 09:42:19+0200 1224 c98 WUAUENG ServiceMain exits. Exit code is 0x80004015
2005-06-22 09:43:40+0200 1224 a6c Service Main starts
2005-06-22 09:43:40+0200 2388 960 Failed to get agent interface pointers, hr=80070005
2005-06-22 09:43:40+0200 1224 a6c Using BatchFlushAge = 20878.
2005-06-22 09:43:40+0200 1224 a6c Using SamplingValue = 900.
2005-06-22 09:43:40+0200 1224 a6c Successfully loaded event namespace dictionary.
2005-06-22 09:43:40+0200 1224 a6c Successfully loaded client event namespace descriptor.
2005-06-22 09:43:40+0200 1224 a6c Successfully initialized local event logger. Events will be logged at C:\WINDOWS\SoftwareDistribution\ReportingEvents.log.
2005-06-22 09:43:40+0200 1224 a6c Successfully initialized NT event logger.
2005-06-22 09:43:40+0200 1224 a6c Successfully initialized event uploader 0.
2005-06-22 09:43:40+0200 1224 a6c Reopened existing event cache file at C:\WINDOWS\SoftwareDistribution\EventCache\{E09ABEFA-A1A4-4BA0-B01C-48D41911BF15}.bin for writing.
2005-06-22 09:43:40+0200 1224 a6c Successfully initialized event uploader 1.
2005-06-22 09:43:40+0200 1224 a6c Client call recorder fails to init with error 0x80004015
2005-06-22 09:43:40+0200 1224 a6c WU client with version 5.4.3790.2182 failed to initialize with error 0x80004015 from component agent
2005-06-22 09:43:40+0200 1224 a6c Failed to initialize WU client: 0x80004015
2005-06-22 09:43:40+0200 1224 a6c WUAUENG ServiceMain exits. Exit code is 0x80004015
Liegt mein Fehler in der GPO, daß ich den XP Clients was anderes mitteilen muss als den 2k?!? Soweit ich weiß nicht.
Schon mal vielen Dank fürs durchlesen!
meit
Hallo zusammen,
also bei uns im Unternehmen tritt derselbe Fall auf.
Die Windows 2000 Clients synchronisieren sich alle korrekt.
Jedoch funktionieren die XP-Clients nur nach manuellem Anstoß.
Vielleicht hilft ja der Beitrag von TheFlyer im MCSE-Forum.
Bei mir klappt das einwandfrei. Ich habe einfach die Dateien
* wuauclt.exe
* wuaucpl.cpl
* wuaueng.dll
* wuaueng1.dll
* winhttp.dll
* wuauserv.dll
* wuau.adm
aus dem Verzeichnis %windir%\inf bzw. %windir%\system32 von dem WSUS-Server auf die entsprechenden Rechner kopiert, und schon läuft das einwandfrei. Nach dem Einstellen der GPO's noch mit
wuauclt.exe /resetauthorization /detectnow
den Client anstossen, und schon ist alles in Butter!
Bei uns erscheint folgender Code im WindowsUpdate-Log:
2005-06-22	06:59:01	1832	118	Misc	===========  Logging initialized (build: 5.8.0.2469, tz: +0200)  ===========
2005-06-22	06:59:01	1832	118	Misc	  = Process: C:\WINDOWS\System32\svchost.exe
2005-06-22	06:59:01	1832	118	Misc	  = Module: C:\WINDOWS\system32\wuaueng.dll
2005-06-22	06:59:01	1832	118	Service	*************
2005-06-22	06:59:01	1832	118	Service	** START **  Service: Service startup
2005-06-22	06:59:02	1832	118	Agent	  * WU client version 5.8.0.2469
2005-06-22	06:59:02	1832	118	Agent	  * SusClientId = 'd46bf771-0677-4b67-bdc0-c99bdbe3408a'
2005-06-22	06:59:02	1832	118	Agent	  * Base directory: C:\WINDOWS\SoftwareDistribution
2005-06-22	06:59:03	1832	118	Agent	  * Access type: No proxy
2005-06-22	06:59:03	1832	118	Agent	  * Network state: Connected
2005-06-22	06:59:03	1832	118	Agent	FATAL: Client call recorder fails to init with error 0x80004015
2005-06-22	06:59:03	1832	118	Agent	  * FATAL: Failed to initialize with error 0x80004015 from component Agent
2005-06-22	06:59:03	1832	118	Service	FATAL: Failed to initialize WU client: 0x80004015
2005-06-22	06:59:03	1832	118	Service	*********
2005-06-22	06:59:03	1832	118	Service	**  END  **  Service: Service exit [Exit code = 0x80004015]
2005-06-22	06:59:03	1832	118	Service	*************
Der Update auf WU-Client V6 half bei den XP-Clients mal auf jeden Fall nix.
Gruß Markus
Hei meit,
hast du bereits eine Lösung gefunden?
Also ich hab mal versucht in der Registry den Key wuauserv zu löschen und
anschließend via Ordner %windir%/inf
au.inf --> rechte Maustaste --> installieren
den Dienst komplett neu zu installieren, jedoch funzt es jetzt auch noch nicht 100%
:confused:
Markus
nein habe noch keine lösung :(
das komische ist, dasss jetzt ein xp client urplötzlich registriert ist, aber keinen bericht abliefert :confused: ... ich habe aber überall den gleichen clon drauf!! also bis auf sid ip und pc-namen sind die rechner komplett identisch :shock:
Hallo zusammen,
hab' die Lösung bei unseren XP-Clients gefunden.
Das Problem war, dass die Clients nicht auf die WSUS-Verwaltungs-Site zugreifen konnten.
Wir setzen einen SBS 2K3 ein und ich habe den WSUS via Port 8530 installiert.
Die Clients hatten keine Möglichkeit ihren Status abzugeben,
da
http://Servername:8530/ReportingWebService/ReportingWebService.asmx
nicht erreichbar war.
--> Lösung Sharepoint-Zentralverwaltung und WSUS-Verwaltungssite einrichten.
:wink2:
Markus
Also so langsam verzweifel' ich hier mit den Kisten.
Der Dienst hängt sich trotzdem immer noch auf. :(
2005-06-23	18:50:11	1836	 f8	AU	  # Will interact with non-admins (Non-admins are elevated)
2005-06-23	18:50:11	1836	 f8	AU	  # AU is paused, not initializing any handlers
2005-06-23	18:50:11	1836	 f8	AU	  # WARNING: Exit code = 0x80004015
2005-06-23	18:50:11	1836	 f8	AU	AU Restart required....
2005-06-23	18:50:18	1836	 f8	Service	*********
2005-06-23	18:50:18	1836	 f8	Service	**  END  **  Service: Service exit [Exit code = 0x240001]
2005-06-23	18:50:18	1836	 f8	Service	*************
Bin für jeden Tip dankbar.
mfg
Markus
Hallo Markus,
den Fehler hatte ich auch gerade. Das sich der Dienst nicht starten ließ. Als ich im Dienstmanager mir die Eigenschaften ansah, sah ich folgenden Pfad eingetragen "\SystemRoot\C:\WINDOWS\system32\svchost.exe -k netsvcs". Sieht es bei dir genauso oder ähnlich aus? Ich habe in der Registry den Eintrag ImagePath geändert und den PC rebootet.
Gruß Esta
das scheint mir ein Problem des BITS Dienstes zu sein. Hast du in deiner GPO die Dienste konfiguriert? Wenn man per Richtlinie den Status auf automatisch setzt muss man noch "Network Service" hinzufügen,am besten auf Full Access setzten. Unter Windows 2000 gab es diesen Dienst nicht noch nicht, deswegen läuft es da unter dem System account. Das hat sich aber unter Windows XP und 2003 geändert.
Grüße
hekmek
The problem is that you ran the IIS Lockdown tool wich disables .exe files. You need to edit Urlscan.ini to remove .exe from being blocked.
After you edit this file, you must restart both IIS and the WSUS server. You can find the Urlscan.ini file in the \WINNT\System32\Inetserv\Urlscan folder on the boot drive of your computer.
To edit the Urlscan.ini file
1.Open Urlscan.ini in a text editor.
2.Remove ".exe" from the [DenyExtensions] section.
3.Ensure that the following settings appear under the [AllowVerbs] section:
·GET
·HEAD
·POST
·OPTIONS
You can also remove the IIS Lockdown tool but this may delete your IIS configuration. If you do this you will need to reinatall WSUS and any other websites on IIS.
Probier mal, sag ma bescheid. ;)
Gruß, xtra.
Hallo zusammen,
konnte mich bisher leider nicht um das Problem kümmern.
@xtragood --> Unser SBS 2K3 besitzt leider keine URLSCAN.INI :nene: :nene:
@hekmek --> Ich habe die Dienste nicht in meiner GPO. Werde mich mal dahinterklemmen.
Danke für eure Tipps! :thumb1:
@Esta --> Hallo Esta, ja meine Fehlermeldungen beinhalten auch den von dir erwähnten Code. Und was hast du an der Reg. dann gedreht? :confused:
Markus
