Cisco801 Arcor Einwahl funkt. nicht mehr
Hallo zusammnen,
seid gestern funkt. die Einwahl bei Arcor nicht mehr. Der Router wählt zwar legt aber direkt wieder auf.
Hier mal ein Debug ppp auth.
01:19:26: BR0:1 PPP: Authorization NOT required
01:19:26: BR0:1 CHAP: I CHALLENGE id 217 len 32 from "dialoutuser"
01:19:26: BR0:1 CHAP: Using hostname from interface CHAP
01:19:26: BR0:1 CHAP: Using password from interface CHAP
01:19:27: BR0:1 CHAP: O RESPONSE id 217 len 26 from "arcor"
01:19:27: BR0:1 CHAP: I SUCCESS id 217 len 4.
01:19:120259084288: %ISDN-6-CONNECT: Interface BRI0:1 is now connected to 000192
0785 dialoutuser
01:19:120267465916: %ISDN-6-DISCONNECT: Interface BRI0:1 disconnected from 0001
920785 dialoutuser, call lasted 1 seconds
01:19:120259084288: %LINK-3-UPDOWN: Interface BRI0:1, changed state to down
01:19:120259084971: %DIALER-6-UNBIND: Interface BR0:1 unbound from profile Di1.
Success rate is 0 percent (0/5)
arcor#
01:19:146028888064: %LINK-3-UPDOWN: Interface BRI0:1, changed state to up
01:19:146037270028: %DIALER-6-BIND: Interface BR0:1 bound to profile Di1
01:19:34: BR0:1 PPP: Treating connection as a callout
01:19:34: BR0:1 PPP: Authorization NOT required
01:19:34: BR0:1 CHAP: I CHALLENGE id 103 len 32 from "dialoutuser"
01:19:34: BR0:1 CHAP: Using hostname from interface CHAP
01:19:34: BR0:1 CHAP: Using password from interface CHAP
01:19:34: BR0:1 CHAP: O RESPONSE id 103 len 26 from "arcor"
01:19:35: BR0:1 CHAP: I SUCCESS id 103 len 4
01:19:150323855360: %ISDN-6-CONNECT: Interface BRI0:1 is now connected to 000192
0785 dialoutuser
01:19:150332236988: %ISDN-6-DISCONNECT: Interface BRI0:1 disconnected from 0001
01:19:150323855360: %LINK-3-UPDOWN: Interface BRI0:1, changed state to down
01:19:154618823339: %DIALER-6-UNBIND: Interface BR0:1 unbound from profile Di1
arcor#sh run
Building configuration...
Current configuration : 3912 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
no service password-encryption
hostname arcor
boot system flash c800-y6-mw.122-8.T10.bin
enable secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxxx
username arcor password 0 internet
ip subnet-zero
no ip domain-lookup
ip name-server 194.25.2.129
ip name-server 145.253.2.11
isdn switch-type basic-net3
interface Ethernet0
description TEST
ip address 192.1xx.xxx.xxx 255.2xx.xxx.0
ip access-group 112 in
ip nat inside
no cdp enable
interface BRI0
no ip address
encapsulation ppp
dialer pool-member 1
no cdp enable
ppp authentication pap chap callout
ppp chap hostname arcor
ppp chap password 0 internet
ppp pap sent-username arcor password 0 internet
ppp multilink
interface Dialer1
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer idle-timeout 180 either
dialer string 0001920785 (Wir wählen eine "00" fürs Amt)
dialer hold-queue 10
dialer load-threshold 10 either
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp multilink
ip nat inside source list 1 interface Dialer1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 172.xxx.xxx.xxx 255.255.255.255 192.xxx.xxx.xxx
ip route 188.xxx.xxx.xxx 255.255.xxx.xxx 192.xxx.xxx.xxx
no ip http server
logging 188.xxx.xxx.xxx
access-list 1 remark ****** NAT-LIST ******
access-list 1 permit 10.x.x.x x.x.x.x
access-list 1 permit 192.x.x.x x.x.x.x
access-list 1 permit 188.x.x.x x.x.x.x
access-list 102 permit ip any any
dialer-list 1 protocol ip list 102
no cdp run
line con 0
stopbits 1
line vty 0 4
exec-timeout 15 0
password xxxx
login
no rcapi server
end
arcor#
Jemand ne Idee worans liegen könnte?
Danke + Gruß
Osirus
Neues Benutzerkonto erstellen
Anmelden
