MSDE Installation macht Rollback
Hallo zusammen,
ich wollte auf unserem Windows 2000 Server mit SP4 die MSDE installieren, da die ja Voraussetzung für die WSUS Installation ist.
Die MSDE Installation läuft auch ganz normal, bis kurz vor Schluss. Dann macht der Installer ein Rollback, ohne irgendwelche Fehlermeldungen.
Habe dann mal ein Logfile anfertigen lassen, welches so aussieht:
=== Verbose logging started: 07.07.2005 08:54:30 Build type: SHIP UNICODE 3.01.4000.2435 Calling process: C:\WINNT\system32\msiexec.exe ===
MSI © (C4:84) [08:54:30:203]: Resetting cached policy values
MSI © (C4:84) [08:54:30:203]: Machine policy value 'Debug' is 0
MSI © (C4:84) [08:54:30:203]: ******* RunEngine:
******* Product: C:\MSDERelA\Setup\SqlRun01.msi
******* Action:
******* CommandLine: **********
MSI © (C4:84) [08:54:30:203]: Machine policy value 'DisableUserInstalls' is 0
MSI © (C4:84) [08:54:30:906]: Cloaking enabled.
Starting custom action InstallPerfMon
Registering performance counters from sqlctr.ini
PerfmonLoad routine returned error code 6
Action ended 08:56:26: InstallFinalize. Return value 3.
MSI (s) (D0:88) [08:56:26:515]: User policy value 'DisableRollback' is 0
MSI (s) (D0:88) [08:56:26:515]: Machine policy value 'DisableRollback' is 0
Start custom action DeferProperties
?rfer Properties returns: 0
MSI (s) (D0:88) [08:56:43:390]: Executing op: End(Checksum=0,ProgressTotalHDWord=0,ProgressTotalLDWord=0)
MSI (s) (D0:88) [08:56:43:390]: Error in rollback skipped. Return: 5
MSI (s) (D0:88) [08:56:43:406]: Unlocking Server
MSI (s) (D0:88) [08:56:43:406]: PROPERTY CHANGE: Deleting UpdateStarted property. Its current value is '1'.
Action ended 08:56:43: INSTALL. Return value 3.
Property(S): UpgradeCode = {421A321C-2214-4713-B3EB-253F2FBCCE49}
Property(S): SqlCollation = Latin1_General_CI_AS
Property(S): SqlDataDir = C:\Programme\Microsoft SQL Server\
Property©: ACTION = INSTALL
=== Logging stopped: 07.07.2005 08:56:44 ===
MSI © (C4:84) [08:56:44:046]: Note: 1: 1708
MSI © (C4:84) [08:56:44:046]: Product: Microsoft SQL Server Desktop Engine -- Installation operation failed.
MSI © (C4:84) [08:56:44:062]: Grabbed execution mutex.
MSI © (C4:84) [08:56:44:062]: Cleaning up uninstalled install packages, if any exist
MSI © (C4:84) [08:56:44:062]: MainEngineThread is returning 1603
=== Verbose logging stopped: 07.07.2005 08:56:44 ===
Ich hab gelesen die Return Value 3 Stellen, sollen wichtig für die Fehlersuche sein.
Bin für jede Hilfe dankbar.
Gruss Sammer75
