aysyxc 10 Geschrieben 20. Juli 2005 Melden Teilen Geschrieben 20. Juli 2005 Hallo zusammen, ich habe es geschafft alle Fehler aus meinem Log rauszubekommen!!! Allerdings klappt das Update immer noch nicht! Mein Content Ordner ist auch leer, wie fülle ich diesen? Hier ist mein Log ich hoffe mir kann jemand weiterhelfen: AU Triggering AU detection through DetectNow API AU ############# AU ## START ## AU: Search for updates AU ######### AU <<## SUBMITTED ## AU: Search for updates [CallId = {B72EF550-4B14-49D4-B48B-0C30C2C841D3}] Agent ************* Agent ** START ** Agent: Finding updates [CallerId = AutomaticUpdates] Agent ********* Setup *********** Setup: Checking whether self-update is required *********** Setup * Inf file: C:\WINNT\SoftwareDistribution\SelfUpdate\Default\wusetup.inf Setup Update NOT required for C:\WINNT\system32\cdm.dll: target version = 5.8.0.2469, required version = 5.8.0.2469 Setup Update NOT required for C:\WINNT\system32\iuengine.dll: target version = 5.8.0.2469, required version = 5.8.0.2469 Setup Update NOT required for C:\WINNT\system32\wuapi.dll: target version = 5.8.0.2469, required version = 5.8.0.2469 Setup Update NOT required for C:\WINNT\system32\wuauclt.exe: target version = 5.8.0.2469, required version = 5.8.0.2469 Setup Update NOT required for C:\WINNT\system32\wuauclt1.exe: target version = 5.8.0.2469, required version = 5.8.0.2469 Setup Update NOT required for C:\WINNT\system32\wuaucpl.cpl: target version = 5.8.0.2469, required version = 5.8.0.2469 Update NOT required for C:\WINNT\system32\wuaueng.dll: target version = 5.8.0.2469, required version = 5.8.0.2469 Update NOT required for C:\WINNT\system32\wuaueng1.dll: target version = 5.8.0.2469, required version = 5.8.0.2469 Update NOT required for C:\WINNT\system32\wucltui.dll: target version = 5.8.0.2469, required version = 5.8.0.2469 Update NOT required for C:\WINNT\system32\wups.dll: target version = 5.8.0.2469, required version = 5.8.0.2469 Update NOT required for C:\WINNT\system32\wups2.dll: target version = 5.8.0.2469, required version = 5.8.0.2469 Update NOT required for C:\WINNT\system32\wuweb.dll: target version = 5.8.0.2469, required version = 5.8.0.2469 * IsUpdateRequired = No PT +++++++++++ PT: Synchronizing server updates +++++++++++ PT + ServiceId = {3DA21691-E39D-4DA6-8A4B-B43877BCB1B7}, Server URL = http://DAVID/ClientWebService/client.asmx Agent * Found 0 updates and 8 categories in search Agent ********* Agent ** END ** Agent: Finding updates [CallerId = AutomaticUpdates] Agent ************* >>## RESUMED ## AU: Search for updates [CallId = {B72EF550-4B14-49D4-B48B-0C30C2C841D3}] # 0 updates detected ######### ## END ## AU: Search for updates [CallId = {B72EF550-4B14-49D4-B48B-0C30C2C841D3}] ############# AU setting next detection timeout to 2005-07-20 08:54:12 REPORT EVENT: {6DDEE302-9764-4866-8E17-7DC088A59077} 2005-07-20 09:55:23+0200 1 147 101 {00000000-0000-0000-0000-000000000000} 0 0 AutomaticUpdates Success Software Synchronization Agent has finished detecting items. REPORT EVENT: {FBE97B05-07F7-4463-B88E-43EC10E922F4} 2005-07-20 09:55:23+0200 1 153 101 {00000000-0000-0000-0000-000000000000} 0 0 AutomaticUpdates Success Pre-Deployment Check Reporting client status. Zitieren Link zu diesem Kommentar
Necron 71 Geschrieben 20. Juli 2005 Melden Teilen Geschrieben 20. Juli 2005 Mein Content Ordner ist auch leer, wie fülle ich diesen? Hi, den WSUS-Server mit den MS Updateservern im Internet synchronisieren. :suspect: Vielleicht solltest du dir mal folgende Dokus durch lesen: http://www.microsoft.com/downloads/details.aspx?FamilyID=3BA03939-A5A9-407B-A4B0-1290BA5182F8&displaylang=de http://www.microsoft.com/downloads/details.aspx?FamilyId=E99C9D13-63E0-41CE-A646-EB36F1D3E987&displaylang=en Zitieren Link zu diesem Kommentar
aysyxc 10 Geschrieben 20. Juli 2005 Autor Melden Teilen Geschrieben 20. Juli 2005 Danke, für den Tip die Dokumentation kenne ich schon. Synchronisiert habe ich den Server auch schon, habe ca 400 Updates genehmigt. aber der Content bleibt leer. Zitieren Link zu diesem Kommentar
Necron 71 Geschrieben 20. Juli 2005 Melden Teilen Geschrieben 20. Juli 2005 Dann schau mal nach ob unter Optionen->Synchronisierungsoptionen->Daten und Sprachen eingestellt ist: Updatedateien lokal auf dem Server speichern Zitieren Link zu diesem Kommentar
aysyxc 10 Geschrieben 20. Juli 2005 Autor Melden Teilen Geschrieben 20. Juli 2005 Welchen Haken nimmst du da? den für Expressinstallationsdateien? Zitieren Link zu diesem Kommentar
Necron 71 Geschrieben 20. Juli 2005 Melden Teilen Geschrieben 20. Juli 2005 Den anderen, genehmigte Updates speichern. Zitieren Link zu diesem Kommentar
aysyxc 10 Geschrieben 20. Juli 2005 Autor Melden Teilen Geschrieben 20. Juli 2005 Ich habe die Lösung gefunden jetzt läuft alles reibungslos. Letzter Beitrag aus diesem Thred http://www.mcseboard.de/showthread.php?t=65621 Zitieren Link zu diesem Kommentar
Necron 71 Geschrieben 20. Juli 2005 Melden Teilen Geschrieben 20. Juli 2005 Danke für's Feedback! Zitieren Link zu diesem Kommentar
