w2k3, sp1 installation bricht ab
hi,
ich versuche mich gerade am sp1. das bricht aber kommentarlos ab:
3.626: ================================================================================
3.626: 2005/07/30 09:07:07.317 (local)
3.626: C:\SP1\i386\update\update.exe (version 5.6.1013.0)
3.626: Das Service Pack wurde mit folgender Befehlszeile gestartet:
3.896: Return Value From OnACPower = 1
3.896: OnACPower returned value( 0x1 ) which is Equal To 0x1
3.896: Condition succeeded for section OnACPower.Section in Line 1 of PreRequisite
3.896: InternalFileName of C:\WINNT\system32\HAL.DLL is Not Equal To halcmpx.dll
3.896: Condition succeeded for section CustomHalUnisysBlock.Section in Line 2 of PreRequisite
3.896: InternalFileName of C:\WINNT\system32\HAL.DLL is Not Equal To Unisys CMP Server ACPI HAL
3.896: First Condition in CustomHalUniSysBlock.Section2 Succeeded
3.896: Condition succeeded for section CustomHalUniSysBlock.Section2 in Line 3 of PreRequisite
3.896: InternalFileName of C:\WINNT\system32\HAL.DLL is Not Equal To HALSRAAC.DLL
3.896: Condition succeeded for section CustomHalStratusBlock.Section in Line 4 of PreRequisite
3.896: InternalFileName of C:\WINNT\system32\HAL.DLL is Not Equal To halce52.dll
3.896: Condition succeeded for section CustomHalMarathonBlock.Section in Line 5 of PreRequisite
3.906: Service SpUpdSvc Not Registered in SCM 0x424
3.906: Condition succeeded for section SpUpdSvcBlock.Section in Line 6 of PreRequisite
3.906: Start is Present
3.906: SYSTEM\CurrentControlSet\Services\MSDTC\Start is Not Equal To Specified Value
3.906: Second Condition in MSDTC.Not.Disabled Succeeded
3.906: Condition succeeded for section MDSTC.Check.Disabled in Line 7 of PreRequisite
12.549: DoInstallation: CleanPFR failed: 0x2
12.549: SetProductTypes: InfProductBuildType=BuildType.Sel
12.569: SetAltOsLoaderPath: No section uses DirId 65701; done.
12.779: DoInstallation: FetchSourceURL for c:\sp1\i386\update\update.inf failed
19.018: DoInstallation:SetupOpenInfFile for OldUninstallInf file C:\WINNT\$NtServicePackUninstall$\spuninst\spuninst.inf not found: 0x3
19.018: CreateUninstall = 1,Directory = C:\WINNT\$NtServicePackUninstall$
62.050: BuildCabinetManifest: update.url absent
62.080: Starting AnalyzeComponents
62.090: AnalyzePhaseZero used 10 ticks
62.090: SetupFindFirstLine in LoadExclusionList Failed with error: 0xe0000102
73.196: OEM file scan used 11106 ticks
83.170: AnalyzePhaseOne: used 21080 ticks
83.170: AnalyzeComponents: Hotpatch analysis disabled; skipping.
83.170: AnalyzeComponents: Hotpatching is disabled.
83.170: FindFirstFile c:\winnt\$hf_mig$\*.*
83.340: Service Pack 1 Setup hat folgenden Fehler festgestellt: Die Datei update.ver ist nicht richtig.
83.410: Failed to open c:\winnt\$hf_mig$\KB901214\update\updatebr.inf
...fortsetzung nächster beitrag
83.410: Analyzing Devices...
83.410: Enumerating Devices of display, GUID {4d36e968-e325-11ce-bfc1-08002be10318}
83.671: Enumerating Devices of hdc, GUID {4D36E96A-E325-11CE-BFC1-08002BE10318}
83.941: Enumerating Devices of media, GUID {4D36E96C-E325-11CE-BFC1-08002BE10318}
84.212: Enumerating Devices of Processor, GUID {50127DC3-0F36-415e-A6CC-4CB3BE910B65}
84.542: Enumerating Devices of System, GUID {4D36E97D-E325-11CE-BFC1-08002BE10318}
85.724: Enumerating Devices of Unknown, GUID {4D36E97E-E325-11CE-BFC1-08002BE10318}
86.815: AnalyzeDevices used 3405 ticks
87.717: AnalyzePhaseTwo used 902 ticks
87.717: AnalyzePhaseThree used 0 ticks
87.717: AnalyzePhaseFive used 0 ticks
87.757: AnalyzePhaseSix used 40 ticks
92.604: AnalyzeComponents used 30524 ticks
92.604: Downloading 0 files
92.604: bPatchMode = FALSE
92.614: Inventory complete: ReturnStatus=0, 79835 ticks
92.614: Num Ticks for invent : 79835
93.094: CheckRegistryValue: Registry - Inf integer values mismatch
93.094: CheckRegistryValue: RegOpenKeyEx for SYSTEM\CurrentControlSet\Services\IAS KeyName failed :0x2
93.104: Conditional load of section Mpeg2Data.Reg.Install.Condition succeeded
93.104: CheckRegistryValue: RegOpenKeyEx for AppID\{A9E69610-B80D-11D0-B9B9-00A0C922E750} KeyName failed :0x2
93.104: CheckRegistryValue: RegOpenKeyEx for AppID\{62B8CCBE-5A45-4372-8C4A-6A87DD3EDD60} KeyName failed :0x2
93.104: CheckRegistryValue: RegOpenKeyEx for AppID\{119817C9-666D-4053-AEDA-627D0E25CCEF} KeyName failed :0x2
93.104: CheckRegistryValue: RegOpenKeyEx for AppID\{61738644-F196-11D0-9953-00C04FD919C1} KeyName failed :0x2
93.114: Conditional load of section WindowsFirewall.Reg.Install.Condition succeeded
93.114: Allocation size of drive C: is 512 bytes, free space = 8663232512 bytes
162.744: Drive C: free 8261MB req: 650MB w/uninstall 1045MB
162.744: CabinetBuild complete
162.744: Num Ticks for Cabinet build : 70130
162.744: Starting process: c:\sp1\i386\\update\nv4prep.exe
und das war's dann auch schon.
hab's auch schon mal lokal entpackt und die netzwerkverbindungen deaktiviert - dto.
danke für jeden tipp
ciao
tom
