cisco 836 email problem
hallo
man hat mich beaftragt ein cisco router zu konfigurieren
leider kenne ich mich mit cisco ueberhaupt nicht
habe also den router ueber sdm express konfiguriert
das einzige problemm das ich noch habe ist das etwas die abgehende emails blockiert
hier mein konfiguration
P.S. der ist wieder von mein netzwerk raus
SH RUN
Building configuration...
Current configuration : 2282 bytes
version 12.3
no service pad
service timestamps debug datetime msec
service timestamps log datetime msec
service password-encryption
hostname *************
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5 ***********
clock timezone PCTime 2
clock summer-time PCTime date Mar 30 2003 3:00 Oct 26 2003 4:00
no aaa new-model
ip subnet-zero
--More-- !
ip domain name *********
ip ips po max-events 100
no ftp-server write-enable
interface Ethernet0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-Ethernet 10/100$$ES_LAN$$FW_INSIDE$
ip address *****************
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
interface BRI0
no ip address
shutdown
--More-- interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
description $ES_WAN$$FW_OUTSIDE$
pvc 8/35
pppoe-client dial-pool-number 1
interface FastEthernet1
no ip address
duplex auto
speed auto
interface FastEthernet2
no ip address
duplex auto
speed auto
interface FastEthernet3
no ip address
--More-- duplex auto
speed auto
interface FastEthernet4
no ip address
duplex auto
speed auto
interface Dialer0
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname *******
ppp chap password 7 ********
ppp pap sent-username ******** password 7 *************
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
--More-- ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
access-list 1 remark INSIDE_IF=Ethernet0
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.168.16.0 0.0.0.255
dialer-list 1 protocol ip permit
control-plane
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
no modem enable
line aux 0
line vty 0 4
privilege level 15
--More-- login local
transport input telnet ssh
scheduler max-task-time 5000
end
ciscorouter#
Ich sehe da nicht gerade ein Fehler.
Kannst Du aber normal auf das Internet? Surfen ohne Probleme?
Wenn ja, versuche mal ein Telnet von PC aus auf den Mailserver mit folgendem Befehl
telnet [ip mailserver] 25
mfg mtf
