romeo310 10 Geschrieben 16. August 2005 Melden Geschrieben 16. August 2005 Moinsen, hab einen 1720 Vollaustattung und versuche gerade einen T-DSL Business Zugang mit Fester IPeinzurichten. Mein SMC Router läuft mit den Daten, nur der 1720 nicht ! Irgendwas stimmt hier nicht mit der IP, muss was simples sein, sehe es aber nicht !!!! Log von debug ppp authentication: c1720r#debug ppp authentication0r#conf telost carrier. Enter PPP authentication debugging is one. End with CNTL/Z. 00:30:23: Vi1 PPP: Using dialer call direction 00:30:23: Vi1 PPP: Treating connection as a callout 00:30:23: Vi1 PPP: Session handle[9C000003] Session id[0] 00:30:23: Vi1 PPP: Authorization required 00:30:23: Vi1 PPP: No remote authentication for call-out 00:30:24: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up 00:30:24: Vi1 PPP: No authorization without authentication 00:30:24: Vi1 PAP: Using hostname from interface PAP 00:30:24: Vi1 PAP: Using password from interface PAP 00:30:24: Vi1 PAP: O AUTH-REQ id 1 len 46 from "feste-ip/TB0xxxxxxxx@t-online-c om.de" 00:30:24: Vi1 PPP: Authorization required 00:30:24: Vi1 PPP: No remote authentication for call-out 00:30:25: Vi1 PPP: No authorization without authentication 00:30:25: Vi1 CHAP: I CHALLENGE id 27 len 29 from "H-LNS-B1" 00:30:25: Vi1 CHAP: Using hostname from interface CHAP 00:30:25: Vi1 CHAP: Using password from interface CHAP 00:30:25: Vi1 CHAP: O RESPONSE id 27 len 58 from "feste-ip/TBxxxxxxxxx@t-online -com.de" 00:30:25: Vi1 CHAP: I FAILURE id 27 len 48 msg is "0021 PSHNO001 xxxxxxx no v alid ip address" 00:30:25: %DIALER-6-UNBIND: Interface Vi1 unbound from profile Di1 00:30:25: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to down 00:30:45: %PQUICC_ETHER-1-LOSTCARR: Unit 0, lost carrier. Transceiver problem? Hier die Conf: ! interface Dialer1 description connected to Internet ip address negotiated ip access-group 103 in ip mtu 1492 ip nat outside ip inspect FastEthernet_0 out encapsulation ppp dialer pool 1 dialer-group 2 ppp authentication chap pap callin ppp chap hostname feste-ip/TBxxxxxxx@t-online-com.de ppp chap password 7 xxxxxxxx ppp pap sent-username feste-ip/TBxxxxxxx@t-online-com.de password 7 xxxxxxx ! THX for Fast Help !!! Zitieren
ShiningStar 10 Geschrieben 16. August 2005 Melden Geschrieben 16. August 2005 da fehlt doch der chap username... kann das sein? Zitieren
thorgood 10 Geschrieben 16. August 2005 Melden Geschrieben 16. August 2005 Hi, wenn dein T-DSL Business eine feste IP hat solltest du diese auch angeben. interface Dialer1 ip address 123.123.123.123 255.255.255.252 thorgood Zitieren
ShiningStar 10 Geschrieben 16. August 2005 Melden Geschrieben 16. August 2005 sieht aus als macht er ne Verbindung... ich mein Du brauchst noch das chap password das er Dich auch authen kann Zitieren
romeo310 10 Geschrieben 18. August 2005 Autor Melden Geschrieben 18. August 2005 thx jungs....die beiden Einträüge waren es ! :thumb1: Zitieren
