running config ändern?
hallo,
ich möchte meine running config ändern. bisher steht dieses drin:
Current configuration : 1587 bytes
version 12.3
no service pad
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname xxxx
boot-start-marker
boot system flash
boot system flash c800-y6-mw.123-5d.bin
boot-end-marker
enable secret 5 xxxx
enable password xxxx
username xxxx password 7 xxxx
username xxxx password 0 xxxx
no aaa new-model
ip subnet-zero
no ip source-route
no ip routing
isdn switch-type basic-net3
interface Ethernet0
ip address 192.168.2.1 255.255.255.0
no ip proxy-arp
no ip route-cache
interface BRI0
ip address 10.83.180.100 255.255.0.0
encapsulation ppp
no ip route-cache
shutdown
dialer-group 1
isdn answer1 48
ppp authentication chap callin
ppp chap hostname xxxx
ppp chap password 0 xxxx
ip classless
ip route 0.0.0.0 0.0.0.0 10.83.10.150
ip http server
map-class dialer DialClass
access-list 121 deny udp any eq netbios-dgm any
access-list 121 deny udp any eq netbios-ns any
access-list 121 deny udp any eq netbios-ss any
access-list 121 deny tcp any eq 137 any
access-list 121 deny tcp any eq 138 any
access-list 121 deny tcp any eq 139 any
access-list 121 permit ip any any time-range TIME
dialer-list 1 protocol ip permit
line con 0
exec-timeout 120 0
transport preferred all
transport output all
stopbits 1
line vty 0 4
exec-timeout 0 0
password xxxx
login local
transport input all
no rcapi server
time-range TIME
periodic daily 0:00 to 23:59
end
eigentlich soll nur dieses drin stehen:
Current configuration : 1432 bytes
version 12.3
no service pad
hostname xxxx
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
no ip source-route
interface Ethernet0
no ip proxy-arp
interface BRI0
encapsulation ppp
dialer-group 1
isdn answer1 48
ip classless
ip http server
line con 0
exec-timeout 120 0
stopbits 1
line vty 0 4
exec-timeout 0 0
login local
transport input all
no rcapi server
time-range TIME
end
Hallo
Am besten Du löschst mit write erase die startup-config und lädst dann
über einen tftp Server die neue konfig / copy tftp start /
Danach kannst Du den Router neu starten (aber nicht nochmal abspeichern)
Jetzt sollte der Router mit der neuen Konfig funktionieren.
mfg
  • 2 Wochen später...
was hindert dich.
in den Enable Modus wechseln
conf t eingeben und los gehts
M.f.G.
Hallo adorik,
Ganz so einfach ists nicht - da läufst Du Gefahr eine sog. Merge-Config zu bekommen. :suspect:
Erstmal alte running löschen macht da schon mehr Sinn. :D
Grüsse aus Berlin
Hola,
@IWS-Germany
was meinst du mit alte running-config löschen? eher alte startup-config löschen! wenn du die "alte" "aktuelle " Config im Speicher (DRAM) löscht ist das Device platt => bis zum Reboot (da die NVRAM Config ja noch da ist). Merged Config gibts in diesem Fall (startup überschreiben) nicht. Nur bei Copy n Paste Helden passiert das.
=> mmuelleh
so solltedas klappen, falls die config vorher getestet wurde!
Ciao
Neues Benutzerkonto erstellen
Anmelden
