tomtom2 10 Geschrieben 19. September 2005 Melden Geschrieben 19. September 2005 Hi, über eine Pix 501 soll auch VoIP gemacht werden. Habe leider über das Thema VoIP nicht so viel Ahnung. Wäre nett, wenn jemand die Config auf VoIP-tauglichkeit checken könnte. Bin für jede Idee dankbar. Gruß Tom nameif ethernet0 outside security0 nameif ethernet1 inside security100 enable password encrypted passwd encrypted hostname pix domain-name abc.de fixup protocol ftp 21 fixup protocol http 80 fixup protocol h323 h225 1720 fixup protocol h323 ras 1718-1719 fixup protocol ils 389 fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol smtp 25 fixup protocol sqlnet 1521 fixup protocol sip 5060 fixup protocol skinny 2000 names !! hieran wird natürlich noch gearbeitet :-)) access-list inside permit ip any any access-list outside permit ip any any pager lines 24 logging console debugging logging monitor debugging logging host inside 10.10.10.10 interface ethernet0 10baset interface ethernet1 10baset mtu outside 1500 mtu inside 1500 ip address outside 10.xx.xx.9 255.255.254.0 ip address inside 10.xx.xx.2 255.255.255.252 ip audit info action alarm ip audit attack action alarm pdm location 10.xx.xx.12 255.255.255.252 outside pdm history enable arp timeout 300 static (inside,outside) 10.0.0.0 10.0.0.0 netmask 255.0.0.0 0 0 static (inside,outside) 172.0.0.0 172.0.0.0 netmask 255.0.0.0 0 0 access-group outside in interface outside access-group inside in interface inside route inside route outside 10.xx.xx.12 255.255.255.252 10.xx.xx.xx 1 timeout xlate 3:00:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server RADIUS protocol radius aaa-server LOCAL protocol local http server enable http 0.0.0.0 0.0.0.0 inside snmp-server host inside 10.xx.xx.xx no snmp-server location snmp-server community public snmp-server enable traps floodguard enable sysopt noproxyarp outside sysopt noproxyarp inside no sysopt route dnat telnet 0.0.0.0 0.0.0.0 inside telnet timeout 5 ssh 0.0.0.0 0.0.0.0 inside ssh timeout 5 terminal width 80 Zitieren
kroliczku 10 Geschrieben 19. September 2005 Melden Geschrieben 19. September 2005 Hi, was hast du genau vor? und wie willst du VoIP über PIX501 machen?? Gruß Kroliczku Zitieren
s21it21 10 Geschrieben 20. September 2005 Melden Geschrieben 20. September 2005 Hallo! Ob Du eine PIX 501 oder eine 535er PIX nimmst ist völlig egal, die Software an und für sich ist die selbe. Die PIX kommt mit VoIP (fixup) klar... lg martin Zitieren
