AreoPag 10 Geschrieben 11. Oktober 2005 Melden Geschrieben 11. Oktober 2005 Hallo zusammen! Bei meiner folgenden Konfiguration funktioniert das IP NAT INSIDE nicht, d.h. Das zum Beispiel von extern port 80 auf intern port 80 weitergeleitet wird. Wenn ich einen port scan auf meine öffentliche ip (fix) mache sind nur 3 ports geöffnet: 23,25 und 110 Konfiguration: version 12.3 no service pad service timestamps debug uptime service timestamps log uptime service password-encryption ! hostname Router1 ! boot-start-marker boot-end-marker ! ! no aaa new-model ip subnet-zero ! ! ip audit po max-events 100 no ftp-server write-enable ! ! ! ! no crypto isakmp enable ! ! ! interface Loopback1 ip address 80.123.x.x 255.255.255.255 ip broadcast-address 0.0.0.0 ! interface Ethernet0 ip address 172.16.116.250 255.255.0.0 ip broadcast-address 0.0.0.0 ip nat inside no cdp enable hold-queue 100 out ! interface ATM0 no ip address ip broadcast-address 0.0.0.0 load-interval 30 no atm ilmi-keepalive dsl operating-mode auto pvc 0/16 ilmi ! ! interface ATM0.864 point-to-point ip broadcast-address 0.0.0.0 pvc 8/64 encapsulation aal5mux ppp dialer dialer pool-member 1 ! ! interface Dialer1 ip address negotiated ip broadcast-address 0.0.0.0 ip nat outside encapsulation ppp dialer pool 1 dialer-group 1 ppp authentication chap callin ppp chap hostname yyyy ppp chap password 7 yyyy ! ip classless ip route 0.0.0.0 0.0.0.0 Dialer1 no ip http server no ip http secure-server ip nat inside source list 1 interface Loopback1 overload ip nat inside source static tcp 172.16.116.100 20 80.123.x.x 20 extendable ip nat inside source static tcp 172.16.116.100 21 80.123.x.x 21 extendable ip nat inside source static tcp 172.16.116.100 25 80.123.x.x 25 extendable ip nat inside source static tcp 172.16.116.100 80 80.123.x.x 80 extendable ip nat inside source static tcp 172.16.116.100 110 80.123.x.x 110 extendable ! ! access-list 1 permit 172.16.0.0 0.0.255.255 dialer-list 1 protocol ip permit snmp-server location aaa bbb snmp-server enable traps tty no cdp run ! control-plane ! ! line con 0 exec-timeout 120 0 no modem enable transport preferred all transport output all stopbits 1 line aux 0 transport preferred all transport output all line vty 0 4 access-class 23 in exec-timeout 120 0 login local length 0 transport preferred all transport input all transport output all ! scheduler max-task-time 5000 ! end Ich hoffe Ihr könnt mir helfen, bin schon am verzweifeln! MfG, Areopag Zitieren
rob_67 10 Geschrieben 12. Oktober 2005 Melden Geschrieben 12. Oktober 2005 Hi, das port 25 und 110 funzen, zeigt doch aber, dass das statische NAT funktioniert, telnet ist auch OK, da LOOPbackinterface direkt auf den Router. Wenn port 80 nicht geht, deutet das eher darauf hin, dass entweder der webserver nicht läuft (lokal testen) oder seitens des providers ports geblockt werden, am router debuggen (ip packet bzw. ip nat detailed), was am router ankommt und was übersetzt wird... Gruss rob Zitieren
AreoPag 10 Geschrieben 12. Oktober 2005 Autor Melden Geschrieben 12. Oktober 2005 Der Webserver ist im lokalen Netz über Port 80 erreichbar Ich habe auch einen Mailserver laufen, der port 25 und 110 verwendet, aber ist dieser auch nicht von extern erreichbar, obwohl anscheinend port 25 und 100 offen sind. Das der Provier den Port 80 gesperrt hat glaube ich auch nich, da es schon mal funktioniert hat, leider kann ich nicht mehr genau sagen wie ich den router damals konfiguiert habe. MfG, Areopag Zitieren
rob_67 10 Geschrieben 12. Oktober 2005 Melden Geschrieben 12. Oktober 2005 was sagt denn das debugging auf dem router, sieht er die entsprechenden icoming pakete? Zitieren
AreoPag 10 Geschrieben 20. Oktober 2005 Autor Melden Geschrieben 20. Oktober 2005 Hallo! Beim debuggen ist fast nichts zu erkennen, aber es kommen anforderungen von außen rein. Wieso hat mein Router noch eine IP-Adresse im selben Address kreis... ****** Cisco, das wiedert mich an... mfg, Areopag Zitieren
tom12 10 Geschrieben 20. Oktober 2005 Melden Geschrieben 20. Oktober 2005 Hi, starte am Server einen Sniffer und versuch von aussen mit http auf die öffentliche ip zuzugreifen, dann weisst du, ob die PAkete ankommen (telnet 80.123.x.x 80) ansonsten würde ich am Provider mal kurz nachfragen oder IOS wechseln.. Grüsse Thomas Zitieren
