domi974 10 Geschrieben 25. Oktober 2005 Autor Melden Teilen Geschrieben 25. Oktober 2005 ok, ich hab mal frsdiag laufen lassen. beim auswählen des 2. dc erhalte ich folgende meldung: ------------------------------------------------------------ FRSDiag v1.7 on 25.10.2005 14:32:33 .\srv on 2005-10-25 at 14.32.33 ------------------------------------------------------------ Detecting this machine's domain role ... Could not check DomainRole, will just treat it like a Domain Controller. The exception message was: Der RPC-Server ist nicht verfügbar. Processing ntfrsutl ds....NTFRSUTL ERROR - Cannot RPC to computer, srv; 000006be (1726)... Make sure you are logged on as a Domain Admin! Skipping! Processing ntfrsutl sets....NTFRSUTL ERROR - Cannot RPC to computer, srv; 000006be (1726)... Make sure you are logged on as a Domain Admin! Skipping! Processing ntfrsutl configtable....NTFRSUTL ERROR - Cannot RPC to computer, srv; 000006be (1726)... Make sure you are logged on as a Domain Admin! Skipping! Processing ntfrsutl inlog....NTFRSUTL ERROR - Cannot RPC to computer, srv; 000006be (1726)... Make sure you are logged on as a Domain Admin! Skipping! Processing ntfrsutl outlog....NTFRSUTL ERROR - Cannot RPC to computer, srv; 000006be (1726)... Make sure you are logged on as a Domain Admin! Skipping! Processing ntfrsutl stage....NTFRSUTL ERROR - Cannot RPC to computer, srv; 000006be (1726)... Make sure you are logged on as a Domain Admin! Skipping! dann noch: Checking for errors in Directory Service Event Log .... NTDS Replication 19.10.2005 15:56:10 Error 2426919 Active Directory konnte den folgenden DNS-Hostnamen des Quelldomänencontrollers nicht zu einer IP-Adresse auflösen. WARNING: Found Directory Service Errors in the past 15 days! FRS Depends on AD so Check AD Replication!<-- WIE? zu guter letzt: Checking Repadmin Showreps for errors... CN=Schema,CN=Configuration,DC=domain,DC=local \SBS via RPC Der Domänencontroller für diese Domäne wurde nicht gefunden. Last success @ 2005-10-25 13:49.23. 1 consecutive failure(s). DC=DomainDnsZones,DC=domain,DC=local \SBS via RPC Der Domänencontroller für diese Domäne wurde nicht gefunden. Last success @ 2005-10-25 13:49.23. 1 consecutive failure(s). DC=ForestDnsZones,DC=domain,DC=local \SBS via RPC Der Domänencontroller für diese Domäne wurde nicht gefunden. Last success @ 2005-10-25 13:49.23. 1 consecutive failure(s). hilfe...... warum finden die sich plötzlich nicht mehr? Zitieren Link zu diesem Kommentar
