Monitoring
Hallo zusammen
Monitore einen Windows 2003 Server
Kriege nun folgende Fehlermeldung:
The store.exe process is allocating more memory than usual.
Check to see if you are having problems with e-mail. If so, stop and then restart the Microsoft Exchange Information Store service.
You can disable this alert or change its threshold by using the Change Alert Notifications task in the Server Management Monitoring and Reporting taskpad.
Was mache ich nun
Danke
Hans-Jörg
