rablu 10 Geschrieben 24. November 2005 Melden Geschrieben 24. November 2005 Ich habe hier einen deutschen SBS2003 Premium. Von den Premiumkomponenten wird nur der ISA Server 2000 als Firewall (ISA-Clients: SecureNAT- und WebProxy-Client) genutzt. Die SP1-Komponenten der ersten beiden CDs wurden erfolgreich installiert. Das ISA2004-Setup (CD3) beendet sich kurz nach dem Starten ohne weitere Meldung, es kommt nicht das erwartete Willkommens-Fenster. Das Setup-Log (%programfiles%\Microsoft Small Business Server\support\sbsisa2k4setuplog.txt) enthaelt diese Eintraege: 24.11.2005 15:55 H:\ISASETUP\SBSISA2K4SETUP.EXE, version 5.2.2893.0 SBSISA2K4SETUP: CoInitialize returned OK SBSISA2K4SETUP: Initializing the module returned OK SBSISA2K4SETUP: Detected SBS 2003 with service pack (1 or later). SBSISA2K4SETUP: Entering InstallISA2k4 SBSISA2K4SETUP: Entering IsISA2k4Installed IsISA2k4Installed returned FALSE SBSISA2K4SETUP: Creating setup completion event returned OK SBSISA2K4SETUP: Entering ProcessAndValidateCommandLine SBSISA2K4SETUP: Cmdline arguments are passed in SBSISA2K4SETUP: CommandLineToArgvW returned OK SBSISA2K4SETUP: ProcessAndValidateCommandLine returned OK SBSISA2K4SETUP: Processing command line arguments returned OK SBSISA2K4SETUP: Entering ReadPIDFromRegistry SBSISA2K4SETUP: RegOpenKeyEx returned OK SBSISA2K4SETUP: RegQueryValueEx returned OK SBSISA2K4SETUP: Copying the PID into the destination buffer returned OK SBSISA2K4SETUP: ReadPIDFromRegistry returned OK SBSISA2K4SETUP: Reading PID returned OK SBSISA2K4SETUP: Entering ValidatePID SBSISA2K4SETUP: Copying PID Into a new buffer returned OK SBSISA2K4SETUP: GetSysTemDirectory returned OK SBSISA2K4SETUP: PathAppend PIDGEN returned OK SBSISA2K4SETUP: LoadLibrary returned OK SBSISA2K4SETUP: GetProcAddress returned OK SBSISA2K4SETUP: Entering IsOEM SBSISA2K4SETUP: RegOpenKeyEx returned OK SBSISA2K4SETUP: RegQueryValueEx returned OK IsOem returned TRUE SBSISA2K4SETUP: Specified PID is valid ValidatePID returned TRUE SBSISA2K4SETUP: Reading the LAN NIC Guid returned OK SBSISA2K4SETUP: LoadImage for large bitmap returned OK SBSISA2K4SETUP: LoadImage for small bitmap returned OK SBSISA2K4SETUP: Entering InitializeWizard SBSISA2K4SETUP: CoCreateInstance for ChainWiz returned OK SBSISA2K4SETUP: Initializing ChainWiz returned OK SBSISA2K4SETUP: *** InitializeWizard returned ERROR 0x80040154 SBSISA2K4SETUP: *** Initializing the setup wizard returned ERROR 0x80040154 SBSISA2K4SETUP: Setting the event to signal post setup SBSISA2K4SETUP: *** InstallISA2k4 returned ERROR 0x80040154 SBSISA2K4SETUP: *** Installing ISA2k4 returned ERROR 0x80040154 SBSISA2K4SETUP: Exiting Die MS KB und google schweigen sich ueber den Fehler 0x80040154 beim SBS2003 aus. Weiss hier jemand genaueres? Zitieren
rablu 10 Geschrieben 27. November 2005 Autor Melden Geschrieben 27. November 2005 Ich versuche als Naechstes folgendes: - Reinstallation des ISA2000SP1 von der SBS2003 Premium CD6 - Reinstallation des SBS2003 spezifischen SP1 - Upgrade zum ISA2004 Zitieren
