Übersicht über 50 WinXP Shortcuts
Dann halt so . Ist jetzt aber nicht mehr so hübsch...
WIN => Opens the Start menu
WIN + E => Opens My Computer in Windows Explorer
WIN + Pause/Break => Opens the System Properties dialog box
WIN + U => Opens the Utility Manager
WIN + R => Opens the Run… prompt
WIN + F => Opens the Search for Files and Folder window
WIN + Ctrl + F => Opens the search for computers on the network
WIN + M => Minimize all windows
WIN + Shift + M => Maximize all windows (after minimizing them)
WIN + D => Minimize all windows to the desktop, and then restore all Windows
WIN + L => Lock Computer
WIN + Tab => Cycle through the open programs on the Taskbar
WIN + B => "Selects the first item in the System Tray; use the arrow keys to cycle through the items and use the Enter key to open a selected item in the SysTray"
Alt + Tab => Switch between open programs
Alt + F4 (in a program) => Closes the active window
Alt + F4 (from desktop) => Opens the Windows Shutdown/Restart dialog box
Alt + Enter => Opens the Properties page of a selected item
Alt + Esc => Cycle between open programs in the order that they were opened
Alt + Spacebar => "In the active window, this brings up the corner dialog box for Move, Size, Minimize, Maximize, or Close"
Shift + Insert CD/DVD => Inserts a CD/DVD without triggering Autoplay or Autorun
Shift + Delete => Permanently deletes an item (rather than sending it to the Recycle Bin)
Ctrl + Shift + Esc => Opens the Windows Task Manager
Ctrl + drag an icon => Copies that item
Ctrl + Shift WIN + drag icon => Creates a shortcut for the item
Right-click + drag a file => Brings up a menu to copy, move, or create a shortcut
PrtScn => "Takes a screen shot of the entire screen; go into a photo program (the Windows program ""Paint"" will also work) and hit Paste to edit and save the
screen shot"
Alt + PrtScn => "Takes a screen shot of only the active Window; hit Paste in a photo program to edit and save the screen shot"
F1 => Opens the Windows XP Help
F2 => Rename selected item
F3 => Opens Windows search for files and folders
F5 => Refresh Internet Explorer page, or refresh any other window
F6 => "Cycle through the different types of elements that can be selection on a screen
or window"
F10 => "Selects the menu bar in the active program (usually ""File"") so that you can use
the arrow keys to navigate through the menus and the Enter key to select"
Shift + F10 => For a selected item, this does the same thing as a right-click with the mouse
Tab => Move through the different elements on a page or the fields in a form
Shift + Tab => Move backward through the different elements on a page or the fields in a form
Ctrl + A => Select All
Ctrl + C => Copy
Ctrl + X => Cut
Ctrl + V => Paste
Ctrl + Z => Undo
Ctrl + Y => Redo
Ctrl + P => Print
Ctrl + O => Open
Ctrl + Esc => Opens the Start menu
Ctrl + Backspace => Deletes the entire word to the left
Ctrl + Delete => Deletes the entire word to the right
Ctrl + Right arrow => Moves the cursor to the beginning of the next word
Ctrl + Left arrow => Moves the cursor to the beginning of the previous word
Ctrl + Down arrow => Moves the cursor to the beginning of the next paragraph
Ctrl + Up arrow => Moves the cursor to the beginning of the previous paragraph
Ctrl + Shift + Arrow keys => Highlight a block of text
Click Shift 5 times => Turns StickyKeys on or off
"Hold down the right Shift key for 8 seconds" => Turns FilterKeys on or off
Hold down Num Lock for 5sec => Turns ToggleKeys on or off
"Make your own custom keystroke for a program" => "Right-click on the icon of a program or shortcut; go to Properties; click on the Shortcut tab; enter your custom keystroke combination in the ""Shortcut key"" field (it will only let you assign key combos that aren't already taken)"
Quelle: TechRepublic.com (genauer Ort nicht mehr bekannt)
Neues Benutzerkonto erstellen
Anmelden
