dcdiag
dcdiag bringt mit oben wine warnung!
was heißt die
C:\Dokumente und Einstellungen\Administrator>dcdiag
Domain Controller Diagnosis
Performing initial setup:
Done gathering initial info.
Doing initial required tests
Testing server: Standardname-des-ersten-Standorts\SERVER
Starting test: Connectivity
*** Warning: could not confirm the identity of this server in
the directory versus the names returned by DNS servers.
If there are problems accessing this directory server then
you may need to check that this server is correctly registered
with DNS
......................... SERVER passed test Connectivity
Doing primary tests
Starting test: Replications
......................... SERVER passed test Replications
Starting test: NCSecDesc
......................... SERVER passed test NCSecDesc
Starting test: NetLogons
......................... SERVER passed test NetLogons
Starting test: Advertising
......................... SERVER passed test Advertising
Starting test: KnowsOfRoleHolders
......................... SERVER passed test KnowsOfRoleHolders
Starting test: RidManager
......................... SERVER passed test RidManager
Starting test: MachineAccount
......................... SERVER passed test MachineAccount
Starting test: Services
......................... SERVER passed test Services
Starting test: ObjectsReplicated
......................... SERVER passed test ObjectsReplicated
Starting test: frssysvol
......................... SERVER passed test frssysvol
Starting test: frsevent
......................... SERVER passed test frsevent
Starting test: kccevent
......................... SERVER passed test kccevent
Starting test: systemlog
......................... SERVER passed test systemlog
Starting test: VerifyReferences
......................... SERVER passed test VerifyReferences
Running partition tests on : ForestDnsZones
Starting test: CrossRefValidation
......................... ForestDnsZones passed test CrossRefValidation
Starting test: CheckSDRefDom
......................... ForestDnsZones passed test CheckSDRefDom
Running partition tests on : DomainDnsZones
......................... DomainDnsZones passed test CrossRefValidation
......................... DomainDnsZones passed test CheckSDRefDom
Running partition tests on : Schema
......................... Schema passed test CrossRefValidation
......................... Schema passed test CheckSDRefDom
Running partition tests on : Configuration
......................... Configuration passed test CrossRefValidation
......................... Configuration passed test CheckSDRefDom
Running partition tests on : eiche-berlin
......................... eiche-berlin passed test CrossRefValidation
......................... eiche-berlin passed test CheckSDRefDom
Running enterprise tests on : eiche-berlin.dyndns.org
Starting test: Intersite
......................... eiche-berlin.dyndns.org passed test Intersite
Starting test: FsmoCheck
......................... eiche-berlin.dyndns.org passed test FsmoCheck
heute sieht dcdiag mal anders aus
bei kccevent ist eine meldung!
Doing primary tests
An Error Event occured. EventID: 0x0000168E
Time Generated: 12/06/2005 08:03:38
(Event String could not be retrieved)
Time Generated: 12/06/2005 08:03:39
Time Generated: 12/06/2005 08:03:40
......................... SERVER failed test systemlog
  • 3 Monate später...
Ich hatte folgenden Fehler beim ausführen von DCDIAG:
        An Error Event occured.  EventID: 0xC0040075
           Time Generated: 03/27/2006   09:05:07
        ......................... SRV001 failed test systemlog
Danach habe ich den WINS installiert und DCDIAG nochmal ausgeführt. Der Fehler war behoben. War das Zufall? Oder besteht da tatsächlich ein zusammenhang?
  • 7 Monate später...
Oh Danke :D
Ich galub ich hab deine Antwort bis heute nie gelesen. Nun hatte ich gerade wiede das selbe Problem und hab mich dumm und **** gesucht und wiede rnichts gefunden und dann mal hier geschaut udn finde meinen eigenenn alten Beitrag...
Stimmt der Fehler wurde nicht mehr angezeigt nachdem ich das Systemlog gelöscht hatte.
Danke :D
Weisst du zufällig noch wie du das mal herausgefunden hast?
