WM 5.0 und Exchange ActiveSync
Verdammt hilfreich bei der Einrichtung von Windows Mobile 5.0 und dem Exchange Server:
Und ich habs getestet, es geht!!!
1. Go to http://www.modaco.com/INFO_Decert_SIM_Unlock_C550-t222786.html.
2. Download the HTC-signed "regeditSTG.zip" and move it to your smartphone.
IMPORTANT: Put it on the phone, not on a memory card - this was my first
sticking point.
3. Extract the zip file using Explorer on the device (if it's a WM5 device).
4. Run the Regedit exe and follow the instructions on the page above for
registry changes to make. It was also suggested by a Microsofty a few posts
down to change 00001017 (4119) to 144 (in the same part of the registry),
although I'm not sure what each entry does. I did all three. :-)
5. Download SDA_ApplicationUnlock.exe from
http://www.modaco.com/Motorola_MPx220_and_Audiovox_SMT6500_app_locked...,
connect the device, run this app, click "Unlock" or whatever, then restart
the device.
6. Export the root certificate from the Certificate Authority in your domain
(in DER format), copy it to the phone (again NOT the memory card) and simply
run it from Explorer. Bob's yer uncle.
In case you don;t know how to export the root cert, follow these
instructions:
1. Run MMC on the CA server.
2. File, Add/Remove Snap-in.
3. Add... select Certification Authority, and select Local Computer.
4. Finish, Close, OK.
5. In MMC, right-click the CA, select Properties. View Certificate, go to
Details tab, select Copy to File...
6. Next, make sure DER encoded binary is selected, Next, put something like
"c:\rootcert".
7. Finish and you're done. Copy it to the phone, run it and you're done.
