Max. Anzahl Dateien in einem Ordner
Reicht dir das nicht?:
ean:
Q: Is there an effective maximum number of files in a single folder / directory that that Windows 2000 Server can support? Or is there a threshold number of files per folder, after which point the performance of the server is seriously affected?
MS_Steve:
A: We have tested 20 million files / directories on NTFS5. Please note that most GUI applications will have an issue with this many files. This is limited by cluster size, drive size, and your MFT. Please see http://support.microsoft.com/defaul...Q100108&sd=tech for more information about the NTFS file system.
