Dr.Melzer 191 Geschrieben 14. Dezember 2005 Melden Geschrieben 14. Dezember 2005 Brandneu von heute Morgen: *********************************************** This Alert is to make you aware of the release of Microsoft Knowledge Base Article 912307, Synchronizing SUS 1.0 SP1 Servers with Windows Update after December 12, 2005 may cause previously approved updates to be unapproved. Microsoft is aware of an issue affecting Software Update Services 1.0 users where all previously approved updates, including security updates, have had the approvals removed and replaced with a status of 'updated'. Microsoft is currently investigating the issue and has found that Windows Server Update Services users are not affected. Microsoft has published a knowledge base article providing workaround information for customers who may be impacted by this issue. Microsoft will continue to investigate this issue to help ensure SUS administrators can deploy Windows updates properly. More information can be found at: http://support.microsoft.com/?kbid=912307 If you have any questions regarding this alert please contact your Technical Account Manager or Application Development Consultant. Thank you, Microsoft PSS Security Team Zitieren
