Cisco 831-Router für VoIP fit machen
Hallo Leute,
ich würde gerne meinen 831er so einstellen, dass Sprachpakete in irgendeiner Art und Weise bevorzugt werden.
Da das IOS vom 831 wohl kein QoS kann (??) ist meine Frage, wie ich so etwas sonst hinkriegen kann?
Michael
#sh ver
Cisco IOS Software, C831 Software (C831-K9O3Y6-M), Version 12.4(1a), RELEASE SOFTWARE (fc2)
Technical Support: http://www.cisco.com/techsupport
Copyright © 1986-2005 by Cisco Systems, Inc.
Compiled Fri 27-May-05 23:56 by hqluong
ROM: System Bootstrap, Version 12.2(11r)YV3, RELEASE SOFTWARE (fc2)
cisco.net-waves.de uptime is 11 weeks, 5 days, 6 hours, 45 minutes
System returned to ROM by power-on
System restarted at 11:53:28 CEST Wed Sep 28 2005
System image file is "flash:c831-k9o3y6-mz.124-1a.bin"
This product contains cryptographic features and is subject to United
States and local country laws governing import, export, transfer and
use. Delivery of Cisco cryptographic products does not imply
third-party authority to import, export, distribute or use encryption.
Importers, exporters, distributors and users are responsible for
compliance with U.S. and local country laws. By using this product you
agree to comply with applicable laws and regulations. If you are unable
to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
If you require further assistance please contact us by sending email to
export@cisco.com.
Cisco C831 (MPC857DSL) processor (revision 0x500) with 58983K/6553K bytes of memory.
Processor board ID FCZ0924403L (4028769020), with hardware revision 0000
CPU rev number 7
3 Ethernet interfaces
4 FastEthernet interfaces
128K bytes of NVRAM.
12288K bytes of processor board System flash (Read/Write)
2048K bytes of processor board Web flash (Read/Write)
Configuration register is 0x2102
wat' zum Teufel bietet sich da an?? CW irgendwas?? LLQ?? Das hab' ich ja noch nie gehört!! ;-)
Scheint bestimmt irgend so eine Cisco-Erfindung zu sein... ;-)
Aber ich lasse mich da gerne belehren... ;-)
Beim zweiten Punkt liegst Du schon richtig, Asterisk wird in der DMZ benutzt.
Mein weiterer Aufbau der DMZ:
|         |       |   ASTARO  1  |       |               |       |   ASTARO  2  |       |         |
|  CISCO  |-------|SECURITY LINUX|-------|  ASTERISK     |-------|SECURITY LINUX|-------|   LAN   |
|   831   |       |     v6.102   |       |  z.Zt. v1.0.9 |       |     v6.102   |       |         |
Im LAN und WLAN dann die ETH+WLAN-Telefone.
Direkt (mit HFC-Karten) die ISDN-Telefone an den Asterisk.
Im LAN kann ich auf den Switches (bis auf einen) kein QoS oder ähnliches fahren.
Brauch' ich auch nicht, da auf'm LAN recht wenig Verkehr ist (ein bisl Nagios, ein bisl surfen, aber nicht mehr.
Die Astaro-Firewalls können auf jeden Fall QoS, ich weiss nicht, ob noch mehr oder noch andere Sachen.
In den Paketfiltern habe ich alle SIP und RTP Pakete schon so eingestellt, dass sie im Gegensatz zu anderen Paketen eine hohe Priorität haben, aber eben nicht über QoS-Bits.
Michael
Hola,
LLQ oder Low Latency Queuing generiert auf dem Router eine Priority Queue, sprich wird ein Paket in diese Queue gelegt wird diese Paket direkt auf den TX Ring (wird direkt gesendet) gelegt. Dies verhindert Delay, Jitter, Paket Loss. Den selben Effeckt hat auch Priority Queueing (brutal Queueuing => da immer nur ****e die priority queue abgearbeitet wird und alle anderen leiden müssen). Mit LLQ kannst du bestimmte Bandbreite für VoIP sichern, also nur "ein Teil der Verbindung" für VoIP reservieren. Der Anteil der Leitung sollte erfahrungsgemäß nicht 33% (15% für VoIP, 15% für Video) überschreiten; denke da laufen auch noch andere Anwendungen die nicht völlig verbachlässigt werden sollten.
Bei einem Cisco Router läuft der Einsatz von QOS Tools so ein:
1. interessanten Traffic erkennen (Classify)
2. den interessanten Traffic markieren (Marking)
3. markierten Traffic unterschiedlich behandeln (Queueing)
Denke mal du hast einen IAX2 Trunk konfiguriert. Im IAX Konfigfile kannst du DSCP Werte (oder TOS Werte) für die Kommunikation setzen. Hier ist 46 (oder 184) sinnvoll. Die Cisco Konfig würde dann so aussehen:
class-map VoIP
match ip dscp 46
policy-map siteQOS
class VoIP
priority percent 33
class class-default
fair-queue
interface <zum internet>
service-policy out siteQOS
Validation:
sh policy-map int <zum Internet>
Ciao
Hi daking,
danke für Deine Antwort, verstehe ich das richtig, dass also LLQ das Mittel der Wahl ist?
Gilt der Prozentwert auch für den Upstream von ADSL-Leitungen (bei mir sind es im upstream 576kBit/s). Ich bezweifle, dass für zwei gleichzeitige Gespräche 33% vom Upstream wirklich reichen, wie siehst Du das?
Okay, die andere Sache ist: Ich benutze keinen "waschechten" VoIP-Provider, der einen IAX2-Trunk anbietet. Ich bin bei sipgate - also SIP-Protokoll.
Wie würde das in dem Fall dann aussehen?
Michael
Hola,
ADSL ist für VoIP eher suboptimal!
Hier ein Vergleich zwischen den Codecs:
1. G.711 @ 20ms Coder Intervall (alle 20ms ein Paket = 50pps) mit pppoe
->voice payload = 160Bytes
->+RTP Header = 12 Bytes
->+UDP Header = 8 Bytes
->+IP Header = 20 Bytes
->+PPP protocol ID= 2Bytes
->+PPPoE header = 6Bytes
->+Ethernet Header = 28Bytes
=> Paketgrösse ist 236Byte * 50pps => 92 Kbit/s pro Gespräch
2. G.729 @ 20ms Coder Intervall (alle 20ms ein Paket = 50pps) mit pppoe
->voice payload = 20bytes
=>siehe oben
=>Paketgrösse ist 96Bytes * 50pps => 37,5 Kbit/s
Wichtig ist hier auch, dass du (denke ich) keine SLA mit dem Provider hast; prich Jitter Delay und Packet Loss sind im Provider Netz schwankend. Mit z.B. Arcor sind die Erfahrungen eher schlecht...
Da gehen die Pakete zwar "geordnet" raus. was damit im Provider Netz passiert ist dann nicht mehr zu beeinflussen..
Ciao
Hi daking,
ich bin bei TAL.DE. Mit den Mitarbeitern der Technik (das sind nur eine Hand voll, daher persönlicher Kontakt) bin ich bis jetzt sehr zufrieden, die haben Ihre Cisco's gut im Griff, und würden sonst auch Anpassungen für Kunden vornehmen.
Was ist SLA? Also ich habe für meinen ADSL-Anschluss schon vor einigen Monaten FastPath schalten lassen, im Hinblick halt auf die mögliche Anwendung von VoIP. Bin kein Gamer.
Michael
Neues Benutzerkonto erstellen
Anmelden
