wir haben hier in der Fa. einige Laptops die Probleme mit WSUS haben.
Im Windowsupdatelog werden die folgenden Einträge geschrieben:
Misc =========== Logging initialized (build: 5.8.0.2469, tz: +0100) ===========
2006-01-09 17:16:47 1080 9e0 Misc = Process: D:\WINNT\System32\svchost.exe
2006-01-09 17:16:47 1080 9e0 Misc = Module: D:\WINNT\system32\wuaueng.dll
2006-01-09 17:16:47 1080 9e0 Service *************
2006-01-09 17:16:47 1080 9e0 Service ** START ** Service: Service startup
2006-01-09 17:16:47 1080 9e0 Agent * WU client version 5.8.0.2469
2006-01-09 17:16:47 1080 9e0 Agent * SusClientId = '3bb79cbd-89b6-4b30-a6e4-3b7d246c088c'
2006-01-09 17:16:47 1080 9e0 Agent * Base directory: D:\WINNT\SoftwareDistribution
2006-01-09 17:16:47 1080 9e0 Agent * Access type: No proxy
2006-01-09 17:16:47 1080 9e0 Agent * Network state: Connected
2006-01-09 17:17:32 1080 9e0 Agent *********** Agent: Initializing Windows Update Agent ***********
2006-01-09 17:17:32 1080 9e0 Agent *********** Agent: Initializing global settings cache ***********
2006-01-09 17:17:32 1080 9e0 Agent * WSUS server: http://WSUS'>http://WSUS'>http://WSUS
2006-01-09 17:17:32 1080 9e0 Agent * WSUS status server: http://WSUS
2006-01-09 17:17:32 1080 9e0 Agent * Target group: (Unassigned Computers)
2006-01-09 17:17:32 1080 9e0 Agent * Windows Update access disabled: No
2006-01-09 17:17:33 1080 9e0 DnldMgr Download manager restoring 0 downloads
2006-01-09 17:17:33 1080 9e0 Agent * Failed to load persisted download calls, error = 0x80004002
2006-01-09 17:17:33 1080 9e0 DnldMgr FATAL: DM:CAgentDownloadManager::RestoreDownloadJobs: GetSession failed with 0x80004002.
2006-01-09 17:17:33 1080 9e0 DnldMgr FATAL: DM:CAgentDownloadManager::DelayedInit: RestoreDownloadJobs failed with 0x00000000.
2006-01-09 17:17:33 1080 9e0 AU ########### AU: Initializing Automatic Updates ###########
2006-01-09 17:17:33 1080 9e0 AU AU setting next detection timeout to 2006-01-09 16:17:33
2006-01-09 17:17:33 1080 9e0 AU # WSUS server: http://WSUS
2006-01-09 17:17:33 1080 9e0 AU # Detection frequency: 1
2006-01-09 17:17:33 1080 9e0 AU # Approval type: Scheduled (Policy)
2006-01-09 17:17:33 1080 9e0 AU # Scheduled install day/time: Every day at 18:00
2006-01-09 17:17:33 1080 9e0 AU # Auto-install minor updates: Yes (Policy)
2006-01-09 17:17:33 1080 9e0 AU FATAL: Failed to get session from datastore, error = 0x80004002
2006-01-09 17:17:33 1080 9e0 AU FATAL: Failed to Unserialize from data store, error = 0x80004002
2006-01-09 17:17:33 1080 9e0 AU # WARNING: Exit code = 0x80004002
2006-01-09 17:17:33 1080 9e0 AU WARNING: InitAUComponents Failed, will restart AU in 30 mins, error = 0x80004002
2006-01-09 17:17:33 1080 9e0 AU AU Restart required....
2006-01-09 17:17:33 1080 1c8 DnldMgr FATAL: DM:CAgentDownloadManager::CheckAllCallDownloadStates: GetSession failed with 0x80004002.
Ein Versuch mit wuauclt /resetauthorization und wuau /detectnow
schlug Fehl. Auch diverse Versuche mit
- Dienst für AutoUpdates anhalten
- %windir%\SoftwareDistribution umbenennen
- Ausführen von WinUpdRestore.exe
- regsvr qmgr.dll
- regsvr qmgrprxy.dll
- Dienst für AutoUpdates starten.
haben nicht geholfen - beim Versuch, regsvr aufzurufen kam der folgende Fehler:
LoadLibrary("qvgr.dll") fehlgeschlagen - Das angegebene Modul wurde nicht gefunden.
Im Syslog sind die Meldungen zu finden, die auf den hochgeladenen Grafiken dargestellt sind. Was mich verwundert, das geht so im Minutentakt - wird gestartet, wird beendet und munter soweiter.
