Dienst: Anmelden als
ok hier nun die ausgabe von netdiag.... :D :D
hf :D
>NETDIAG
Computer Name: thisserver
DNS Host Name: thisserver.XXX.XXX
System info : Microsoft Windows Server 2003
Processor : x86 Family 15 Model 4 Stepping 1, GenuineIntel
List of installed hotfixes :
Netcard queries test . . . . . . . : Passed
[WARNING] The net card 'Asynchroner RAS-Adapter' may not be working because it
has not received any packets.
GetStats failed for 'Parallelanschluss (direkt)'. [ERROR_NOT_SUPPORTED]
[WARNING] The net card 'WAN-Miniport (PPTP)' may not be working because it h
[WARNING] The net card 'WAN-Miniport (PPPOE)' may not be working because it
[WARNING] The net card 'WAN-Miniport (IP)' may not be working because it has
[WARNING] The net card 'WAN-Miniport (Netzwerkmonitor)' may not be working b
ecause it has not received any packets.
GetStats failed for 'WAN-Miniport (L2TP)'. [ERROR_NOT_SUPPORTED]
Per interface results:
Adapter : LAN-Verbindung
Netcard queries test . . . : Passed
Host Name. . . . . . . . . : thisserver.XXX.XXX
IP Address . . . . . . . . : 000.000.000.999
Subnet Mask. . . . . . . . : 255.888.255.255
Default Gateway. . . . . . : iuo.ß9u.098.oiz
Dns Servers. . . . . . . . : 878.878.hgf.544
180.9i9.nbv.mnb
AutoConfiguration results. . . . . . : Passed
Default gateway test . . . : Passed
NetBT name test. . . . . . : Passed
[WARNING] At least one of the <00> 'WorkStation Service', <03> 'Messenge
r Service', <20> 'WINS' names is missing.
WINS service test. . . . . : Skipped
There are no WINS servers configured for this interface.
Global results:
Domain membership test . . . . . . : Passed
NetBT transports test. . . . . . . : Passed
List of NetBt transports currently configured:
NetBT_Tcpip_{DDAA7FCE-92B1-492A-97DD-1E79B6B5BC7C}
1 NetBt transport currently configured.
Autonet address test . . . . . . . : Passed
IP loopback ping test. . . . . . . : Passed
Default gateway test . . . . . . . : Passed
NetBT name test. . . . . . . . . . : Passed
[WARNING] You don't have a single interface with the <00> 'WorkStation Servi
ce', <03> 'Messenger Service', <20> 'WINS' names defined.
Winsock test . . . . . . . . . . . : Passed
DNS test . . . . . . . . . . . . . : Passed
Redir and Browser test . . . . . . : Passed
List of NetBt transports currently bound to the Redir
The redir is bound to 1 NetBt transport.
List of NetBt transports currently bound to the browser
The browser is bound to 1 NetBt transport.
DC discovery test. . . . . . . . . : Passed
DC list test . . . . . . . . . . . : Passed
Trust relationship test. . . . . . : Passed
Secure channel for domain 'XXX' is to '\\DC.XXX.XXX'.
Kerberos test. . . . . . . . . . . : Passed
LDAP test. . . . . . . . . . . . . : Passed
Bindings test. . . . . . . . . . . : Passed
WAN configuration test . . . . . . : Skipped
No active remote access connections.
Modem diagnostics test . . . . . . : Passed
IP Security test . . . . . . . . . : Skipped
Note: run "netsh ipsec dynamic show /?" for more detailed information
The command completed successfully
OK, 2. Versuch ;)
hier die Ausgabe von Netdiag auf einem DC, mit etwas vertändlicheren Adressen...
hf :D
Computer Name: EXMAIL
DNS Host Name: DC.XXX.XXX
System info : Microsoft Windows Server 2003 (Build 3790)
Processor : x86 Family 15 Model 2 Stepping 9, GenuineIntel
KB831464
Q147222
Netcard queries test . . . . . . . : Failed
GetStats failed for 'WAN-Miniport (PPTP)'. [ERROR_INVALID_FUNCTION]
GetStats failed for 'WAN-Miniport (PPPOE)'. [ERROR_INVALID_FUNCTION]
GetStats failed for 'WAN-Miniport (IP)'. [ERROR_INVALID_FUNCTION]
GetStats failed for 'WAN-Miniport (Netzwerkmonitor)'. [ERROR_INVALID_FUNCTIO
N]
GetStats failed for 'Intel® PRO/1000 MT Desktop Adapter'. [ERROR_INVALID_F
UNCTION]
[FATAL] - None of the netcard drivers provided satisfactory results.
Netcard queries test . . . : Failed
NetCard Status: UNKNOWN
Host Name. . . . . . . . . : DC
IP Address . . . . . . . . : 1.1.1.17
Subnet Mask. . . . . . . . : 1.1.1.0
Default Gateway. . . . . . : 1.1.1.9
Dns Servers. . . . . . . . : 1.1.1.14
1.1.10.15
1.1.1.8
Global results:
NetBT_Tcpip_{20E256A2-3CA9-4FDD-85DD-90FDB827C1CA}
PASS - All the DNS entries for DC are registered on DNS server '1.1.1.1
4' and other DCs also have some of the names registered.
5' and other DCs also have some of the names registered.
[WARNING] The DNS entries for this DC are not registered correctly on DNS se
rver '192.168.10.8'. Please wait for 30 minutes for DNS server replication.
Secure channel for domain 'XXX' is to '\\pdc.XXX.XXX'.
Domänenmitglieder sollten als bevorzugten DNS-Server immer einen haben, auf dem die SRV-Ressource Records der DCs registriert sind (also der Server, an dem sich auch der DC dynamisch registriert) , da sonst die dienstspezifischen Abfragen fehlschlagen ...
Hui....!!!
Ich glaub das war die Lösung. :D :D
Als bevorzugter DNS war ein Linux-DNS Server eingetragen.
Ich habe das nun auf einen W2K3 DNS, der gleichzeitig auch DC ist, umgestellt.
Und siehe da,...es klappt. Keine Fehlermeldung mehr!!! :D :D
@IThome: Vielen Dank. Die letzte Info war entscheidend!
Merci :D und biszum nächsten Problem..... ;)
Wie gesagt habe ich heute morgen den DNS Server eintrag umgestellt, und anstatt des bevorzugten DNS auf Linux-Basis, einen DNS W2K3 DC eingetragen. Das mit den Dienst ausführen als... hat hervorragend geklappt, aber nun hat die Namensauflösung für 2 Systeme nicht mer funktioniert.
1x RH 7.1
1x HP-UX
Habt ihr n Tipp woran das liegen könnte. Was brauchen diese System für einträge die auf einem Linux DNS vorhanden sind und auf einem Windows DNS nicht??
Es gibt noch andere Linux-Server im Netzwerk auf die das DNS noch funktioniert.
