crisirius 10 Geschrieben 31. Januar 2006 Melden Geschrieben 31. Januar 2006 Hallo zusammen, vielleicht kann mir jemand helfen ich habe folgendes Problem: Aufbau: Inet----Wic-1ENET---Cisco 1721 --- 10/100 Mbit Card----Lan Das Inet ist mit 8 MBit von Kabeldeutschland versorgt (kabelmodem). Der Download über den Cisco bleibt immer bei ca 550 KByt/s hängen schließe ich einen Rechner direkt an das Kabelmodem bekomme ich Downloadraten von 1 Mbyt/s Config: Current configuration : ! version 12.4 service config service timestamps debug datetime msec service timestamps log datetime msec service password-encryption ! hostname Router ! boot-start-marker boot-end-marker interface Ethernet0 ip address dhcp ip nat outside ip virtual-reassembly ip tcp adjust-mss 1452 no ip mroute-cache half-duplex ! interface FastEthernet0 ip address 192.168.0.5 255.255.255.0 secondary ip address 172.20.1.10 255.255.255.0 ip nat inside ip virtual-reassembly speed auto ! interface Serial0 no ip address shutdown ! interface Serial1 no ip address shutdown ! ip classless ip http server ip http secure-server ! ip nat translation timeout 120 ip nat translation tcp-timeout 1000 ip nat translation udp-timeout 30 ip nat translation icmp-timeout 30 ip nat translation max-entries 2500 ip nat inside source list 1 interface Ethernet0 overload access-list 1 permit 172.0.0.0 0.255.255.255 access-list 1 permit 192.0.0.0 0.255.255.255 Ethernet0 is up, line protocol is up Hardware is PQUICC Ethernet, address is 0004.dd0d.4eeb (bia 0004.dd0d.4eeb) Internet address is MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec, reliability 255/255, txload 5/255, rxload 3/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Half-duplex, 10BaseT ARP type: ARPA, ARP Timeout 04:00:00 Last input 00:00:00, output 00:00:00, output hang never Last clearing of "show interface" counters never Input queue: 3/75/356/0 (size/max/drops/flushes); Total output drops: 69 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 139000 bits/sec, 72 packets/sec 5 minute output rate 221000 bits/sec, 35 packets/sec 7731410 packets input, 855413253 bytes, 9 no buffer Received 7029267 broadcasts, 0 runts, 0 giants, 0 throttles 327 input errors, 120 CRC, 167 frame, 33 overrun, 7 ignored 0 input packets with dribble condition detected 738124 packets output, 410519984 bytes, 7 underruns 7 output errors, 66714 collisions, 6 interface resets 0 babbles, 0 late collision, 12869 deferred Hat jemand dazu eine Idee?? Grüße Crisirius Zitieren
Wordo 11 Geschrieben 1. Februar 2006 Melden Geschrieben 1. Februar 2006 327 input errors, 120 CRC, 167 frame, 33 overrun, 7 ignored 7 output errors, 66714 collisions, 6 interface resets Stell mal auf Full-Duplex und schau immer wieder mal mit sh int eth0 ob sich die Counter fuer die Errors erhoehen. Zitieren
czappb 10 Geschrieben 1. Februar 2006 Melden Geschrieben 1. Februar 2006 Ich würde sagen das Problem hängt mit der alten Karte zusammen, ein typisches Duplexproblem. "Die Karte kann keine Autonegotiation. Wenn die andere Seite damit arbeitet (ist heute quasi immer so) und keine Antwort erhält fällt sie in den Half-Duplex betrieb zurück." Bei dir ist jetzt ein ähnlicher Fall, du sendest Halb-Duplex bekommst aber die Daten mit Full-Duplex. Hat zur Folge das dein Modem sendet auch wenn es bereits Daten vom Cisco kriegt woraufhin der Cisco eine Kollision erkennt und das senden abbricht und erneut versucht. CSMA/CD halt... wann gibt endlich nurnoch 10Gb/s Ethernet.. Zitieren
crisirius 10 Geschrieben 2. Februar 2006 Autor Melden Geschrieben 2. Februar 2006 Hallo zusammen, nun folgendes Problem. Laut Cisco kann diese Krate auch im full-duplex betrieben werden. Wenn ich dies nun umstelle kann ich zwar Surfen aber Download von Seiten sind nicht möglich auch das Serven ist langsamer alsim half-duplex Betrieb. Kann sich dasJemand erklären?? Ps: Es sind keine Fehler mehr auf der Karte zu erkennen. Bin etwas Sprachlos Grüße Crisirius Zitieren
Wordo 11 Geschrieben 3. Februar 2006 Melden Geschrieben 3. Februar 2006 Vielleicht passt die MTU noch nicht so ganz. Keine Ahnung wie das bei Kabelmodem so ist, stell doch mal 1400 ein und ip tcp adjust-mss auf 1300, wenns besser geht dann nach oben anpassen, die Werte sind schon etwas niedrig. Zitieren
czappb 10 Geschrieben 3. Februar 2006 Melden Geschrieben 3. Februar 2006 Es ist vermutlich kein MTU Problem. Die TCPMSS ist normalerweise nur 20+20 byte (also 40byte (von IP und TCP Header - 60 mehr nur wenn noch IPSec drauf kommt ;))) kleiner als die IPMTU. falls du eine MTU einstellen möchtest solltest du eine IPMTU auf dem Dialerinterface einstellen und die TCPMSS 40 kleiner wählen. Das ist das andere Duplex-Problem das ich oben beschrieben habe. entweder hängst du einen managebaren Switch dazwischen auf dem du die Ports einstellen kannst aber viel einfacher wäre es das DSL-Modem mit an das interne LAN zu hängen und PPPoE über das 100MBit/s Interface zu machen. Dann solltest du keine Probleme mehr haben ;) Da der Verkehr eh getunnelt ist macht das auch keinen Sicherheitsunterschied. Zitieren
