juergenbauer 10 Geschrieben 23. Februar 2006 Melden Geschrieben 23. Februar 2006 Hi everyone, developing a Web Part that is copying an entry from a list to another list (both Issue Lists) I currently faced to a problem: I have two list items - one is a already existing issue (the 'currentItem'), the other one is a new entry (the 'newRequestItem') to be created in an other list. I already copied the field values and now i would like to get the attachments as well. ... some code ... SPAttachmentCollection currentAttachments = currentItem.Attachments; SPAttachmentCollection newRequestAttachments = newRequestItem.Attachments; int nofAttachments = currentAttachments.Count; output.Write(SPEncode.HtmlEncode("nofAttachments: "+ nofAttachments) + "<BR>"); // number of attachments is correctly dispayed string urlString = currentAttachments.UrlPrefix; output.Write(SPEncode.HtmlEncode("attachment URL: "+ urlString) + "<BR>"); // the URL is also correctly dispayed string fileName; string fileUrl; for (int p = 0; p < nofAttachments; p++) { fileName = currentAttachments[p]; fileUrl = currentAttachments.UrlPrefix + fileName; output.Write(SPEncode.HtmlEncode("File to get: "+ fileUrl) + "<BR>"); // the URL+Filename is correctly dispayed string attachFileString = changeRequestSite.GetFileAsString(fileUrl); output.Write(SPEncode.HtmlEncode("String from File: "+ attachFileString) + "<BR>"); // no problem to get the content of the file SPFile attachFile = changeRequestSite.GetFile(fileUrl); // ERROR: Value does not fall within the expected range. byte[] binFile = attachFile.OpenBinary(); // code not executed newRequestAttachments.Add(fileName, binFile); // code not executed } newRequestItem.Update(); // code not executed ... some more code ... As described under the 'SPWeb'-class in the SDK-Reference the public method 'GetFile' should return the file object (SPFile) located at the URL specified in the provided parameter string. However, the hard I try no SPFile is returned. Is there something wrong with my code or is there a mistake in the SDK?
