gismo 10 Geschrieben 19. Mai 2003 Melden Geschrieben 19. Mai 2003 Gibt es unter windows ein kommandzeilen mail programm? Zitieren
real_tarantoga 11 Geschrieben 19. Mai 2003 Melden Geschrieben 19. Mai 2003 im script repository zu w2k3 stehen diese beiden scripte. vielleicht als übergangslösung ;) Send Email without Installing the SMTP Service Description Demonstration script that uses CDO to send email from a computer where the SMTP Service has not been installed. Designed to work on Microsoft's corporate network. Script Code Set objEmail = CreateObject("CDO.Message") objEmail.From = "admin1@fabrikam.com" objEmail.To = "admin2@fabrikam.com" objEmail.Subject = "Server down" objEmail.Textbody = "Server1 is no longer accessible over the network." objEmail.Configuration.Fields.Item _ ("http://schemas.microsoft.com/cdo/configuration/sendusing") = 2 objEmail.Configuration.Fields.Item _ ("http://schemas.microsoft.com/cdo/configuration/smtpserver") = _ "smarthost" objEmail.Configuration.Fields.Item _ ("http://schemas.microsoft.com/cdo/configuration/smtpserverport") = 25 objEmail.Configuration.Fields.Update objEmail.Send The System Administration Scripting Guide, part of the Windows .NET Server Resource Kit. For more information, contact scripter@microsoft.com. Send Email from a Script Description Demonstration script that uses CDO to send email from a computer where the SMTP Service has been installed. Script Code Set objEmail = CreateObject("CDO.Message") objEmail.From = "monitor1@fabrikam.com" objEmail.To = "admin1@fabrikam.com" objEmail.Subject = "Atl-dc-01 down" objEmail.Textbody = "Atl-dc-01 is no longer accessible over the network." objEmail.Send The System Administration Scripting Guide, part of the Windows .NET Server Resource Kit. For more information, contact scripter@microsoft.com. Zitieren
gismo 10 Geschrieben 20. Mai 2003 Autor Melden Geschrieben 20. Mai 2003 soory bin noch newbie in den scripten was mache ich damit es ein ausfühbares skript wird? Zitieren
real_tarantoga 11 Geschrieben 20. Mai 2003 Melden Geschrieben 20. Mai 2003 im ersten fall brauchst du eigentlich nur zeilen 2-5 anpassen - allerdings könnte eine firewall dir probleme bereiten :suspect: im zweiten fall die gleichen zeilen, allerdings ist hier vorausgestzt, dass du einen funktionierenden smtp server besitzt. ehrlich gesagt habe ich das erste script noch nie zum laufen bekommen :rolleyes: - falls er nicht von selbst auftaucht, dann schick doch mal eine pn an blub - scheint ein "script hirsch" zu sein ;) Zitieren
gismo 10 Geschrieben 20. Mai 2003 Autor Melden Geschrieben 20. Mai 2003 ja danke das verstehe ich aber wie gesagt newbie wie speicher ich das fertige script weiter denn txt ist ja kein ausfühbares script kenne nur die endung .cmd und das klapt bei dem hier glaub ich nicht Zitieren
real_tarantoga 11 Geschrieben 20. Mai 2003 Melden Geschrieben 20. Mai 2003 ah, tschuldigung!!! speicher alles in eine .vbs datei diese kannst du dann über cscript [oder wscript] aufrufen. hinweise zu den befehlen erhälst du über cscript /? Zitieren
gismo 10 Geschrieben 20. Mai 2003 Autor Melden Geschrieben 20. Mai 2003 Mein Allergrößten Respect real_tarantoga hast mir sehr geholfen kannst mir ne paar links geben über skripte scheint so als müßte ich mich damit beschäftigen Danke Zitieren
gismo 10 Geschrieben 20. Mai 2003 Autor Melden Geschrieben 20. Mai 2003 hast nee idee wie ich nee .exe , .cmd oder ne .bat schreiben um das skript zu starten Zitieren
real_tarantoga 11 Geschrieben 20. Mai 2003 Melden Geschrieben 20. Mai 2003 wofür brauchst du es denn genau? generell klingt doch "geplante tasks" immer gut, oder? ;) als .cmd/.bat kannst du den befehl immer mit /b ausführen. dann vermeidest du hängende scripte durch wsh/vb-fehlermeldungen: @echo off REM e-mail an admin cscript /b email.vbs ::exit-befehl ist in der regel nicht nötig!!! ::exit zu den hilfen - also, sehr gut finde ich drei bücher, die allerdings richtig geld kosten: - michael kofler: vb 6 oder vb.net (programmers' choice serie) - holger schwichtenberg: windows- und backoffice-scripting (glaube ich keine neue auflage verfügbar - addison-wesley) - günter born: inside windows scripting host (mspress) ps: ich selbst bin auch nur scriptadaptierer - versteh die teile, aber könnte sie nicht selbst schreiben, kein bock und keine zeit :rolleyes: gruss, r_t Zitieren
gismo 10 Geschrieben 20. Mai 2003 Autor Melden Geschrieben 20. Mai 2003 na ich versuche gerade ne Wichtiges problem zu lösen auf meinen Server werden andauernt wichtige Dienste beendet die man ein fach wieder neustarten muß. Leider sitze ich nicht den ganzen Tag davor und schaue in den Diensten rein nun war meine Überlegung bei den Optionen für dei einzelnen Dienste kann man einstellen was er bei einem Fehlschlag machen soll unteranderen auch eine Datei ausführen daher dachte ich ein skript ausfüren das dir nee Mail schickt wenn der Dienst ausfällte klappt aber nicht wirklich. daher brauchte ich die cmd datei. Eine Andere möglichkeit fällt mir persönlich jetzt nicht ein Zitieren
real_tarantoga 11 Geschrieben 20. Mai 2003 Melden Geschrieben 20. Mai 2003 heute gibt's gerade bei pc-welt vb.net in 21 tagen als pdf download für 2 €uro. bei amazon gibt's leider nur eine einzige leserkritik dazu. vielleicht sagt es dir ja zu?!? Zitieren
