w2k3: Prozess php.exe auf 25% begrenzt, wie ändern?
Apache Environment
Variable Value
HTTP_HOST x.x.x.x
HTTP_USER_AGENT Mozilla/5.0 (Windows; U; Windows NT 5.2; de; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1
HTTP_ACCEPT text/xml,application/xml,application/xhtml+xml,text/html;q=0.9,text/plain;q=0.8,image/png,*/*;q=0.5
HTTP_ACCEPT_LANGUAGE de-de,de;q=0.8,en-us;q=0.5,en;q=0.3
HTTP_ACCEPT_ENCODING gzip,deflate
HTTP_ACCEPT_CHARSET ISO-8859-1,utf-8;q=0.7,*;q=0.7
HTTP_KEEP_ALIVE 300
HTTP_CONNECTION keep-alive
HTTP_CACHE_CONTROL max-age=0
PATH C:\Perl\bin\;C:\Programme\Support Tools\;C:\Programme\Windows Resource Kits\Tools\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Programme\MySQL\MySQL Server 4.1\bin
SystemRoot C:\WINDOWS
COMSPEC C:\WINDOWS\system32\cmd.exe
PATHEXT .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH
WINDIR C:\WINDOWS
SERVER_SIGNATURE <address>Apache Server at x.x.x.x Port 80</address>
SERVER_SOFTWARE Apache
SERVER_NAME x.x.x.x
SERVER_ADDR x.x.x.x
SERVER_PORT 80
REMOTE_ADDR x.x.x.x
DOCUMENT_ROOT E:/public_html
SERVER_ADMIN a@a.de
SCRIPT_FILENAME E:/public_html/test/index.php
REMOTE_PORT 4183
GATEWAY_INTERFACE CGI/1.1
SERVER_PROTOCOL HTTP/1.1
REQUEST_METHOD GET
QUERY_STRING no value
REQUEST_URI /test/
SCRIPT_NAME /test/index.php
HTTP Headers Information
HTTP Request Headers
HTTP Request GET /test/ HTTP/1.1
Host x.x.x.x
User-Agent Mozilla/5.0 (Windows; U; Windows NT 5.2; de; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1
Accept text/xml,application/xml,application/xhtml+xml,text/html;q=0.9,text/plain;q=0.8,image/png,*/*;q=0.5
Accept-Language de-de,de;q=0.8,en-us;q=0.5,en;q=0.3
Accept-Encoding gzip,deflate
Accept-Charset ISO-8859-1,utf-8;q=0.7,*;q=0.7
Keep-Alive 300
Connection keep-alive
Cache-Control max-age=0
HTTP Response Headers
X-Powered-By PHP/4.4.2
Keep-Alive timeout=15, max=98
Connection Keep-Alive
Transfer-Encoding chunked
Content-Type text/html
bcmath
BCMath support enabled
calendar
Calendar support enabled
com
Directive Local Value Master Value
com.allow_dcom Off Off
com.autoregister_casesensitive On On
com.autoregister_typelib Off Off
com.autoregister_verbose Off Off
com.typelib_file no value no value
ctype
ctype functions enabled
ftp
FTP support enabled
mysql
MySQL Support enabled
Active Persistent Links 0
Active Links 0
Client API version 3.23.49
mysql.allow_persistent On On
mysql.connect_timeout 60 60
mysql.default_host no value no value
mysql.default_password no value no value
mysql.default_port no value no value
mysql.default_socket no value no value
mysql.default_user no value no value
mysql.max_links Unlimited Unlimited
mysql.max_persistent Unlimited Unlimited
mysql.trace_mode Off Off
odbc
ODBC Support enabled
Active Links 0
ODBC library Win32
odbc.allow_persistent On On
odbc.check_persistent On On
odbc.default_db no value no value
odbc.default_pw no value no value
odbc.default_user no value no value
odbc.defaultbinmode return as is return as is
odbc.defaultlrl return up to 4096 bytes return up to 4096 bytes
odbc.max_links Unlimited Unlimited
odbc.max_persistent Unlimited Unlimited
overload
User-Space Object Overloading Support enabled
pcre
PCRE (Perl Compatible Regular Expressions) Support enabled
PCRE Library Version 6.2 01-Aug-2005
session
Session Support enabled
Registered save handlers files user
session.auto_start Off Off
session.bug_compat_42 On On
session.bug_compat_warn On On
session.cache_expire 180 180
session.cache_limiter nocache nocache
session.cookie_domain no value no value
session.cookie_lifetime 0 0
session.cookie_path / /
session.cookie_secure Off Off
session.entropy_file no value no value
session.entropy_length 0 0
session.gc_divisor 100 100
session.gc_maxlifetime 1440 1440
session.gc_probability 1 1
session.name PHPSESSID PHPSESSID
session.referer_check no value no value
session.save_handler files files
session.save_path no value no value
session.serialize_handler php php
session.use_cookies On On
session.use_only_cookies Off Off
session.use_trans_sid Off Off
standard
Regex Library Bundled library enabled
Dynamic Library Support enabled
Internal Sendmail Support for Windows enabled
assert.active 1 1
assert.bail 0 0
assert.callback no value no value
assert.quiet_eval 0 0
assert.warning 1 1
auto_detect_line_endings 0 0
default_socket_timeout 60 60
safe_mode_allowed_env_vars PHP_ PHP_
safe_mode_protected_env_vars LD_LIBRARY_PATH LD_LIBRARY_PATH
url_rewriter.tags a=href,area=href,frame=src,form=,fieldset= a=href,area=href,frame=src,form=,fieldset=
user_agent no value no value
tokenizer
Tokenizer Support enabled
wddx
WDDX Support enabled
WDDX Session Serializer enabled
xml
XML Support active
XML Namespace Support active
EXPAT Version 1.95.6
zlib
ZLib Support enabled
Compiled Version 1.2.3
Linked Version 1.2.3
zlib.output_compression Off Off
zlib.output_compression_level -1 -1
zlib.output_handler no value no value
Additional Modules
Module Name
Environment
Variable Value
ALLUSERSPROFILE C:\Dokumente und Einstellungen\All Users
ClusterLog C:\WINDOWS\Cluster\cluster.log
CommonProgramFiles C:\Programme\Gemeinsame Dateien
COMPUTERNAME WEBSERVER-1
ComSpec C:\WINDOWS\system32\cmd.exe
FP_NO_HOST_CHECK NO
NUMBER_OF_PROCESSORS 4
OS Windows_NT
Path C:\Perl\bin\;C:\Programme\Support Tools\;C:\Programme\Windows Resource Kits\Tools\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Programme\MySQL\MySQL Server 4.1\bin
PROCESSOR_ARCHITECTURE x86
PROCESSOR_IDENTIFIER x86 Family 15 Model 4 Stepping 1, GenuineIntel
PROCESSOR_LEVEL 15
PROCESSOR_REVISION 0401
SystemDrive C:
TEMP C:\WINDOWS\TEMP
TMP C:\WINDOWS\TEMP
USERPROFILE C:\Dokumente und Einstellungen\Default User
windir C:\WINDOWS
AP_PARENT_PID 1408
PHP Variables
Variable Value
_SERVER["HTTP_HOST"] x.x.x.x
_SERVER["HTTP_USER_AGENT"] Mozilla/5.0 (Windows; U; Windows NT 5.2; de; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1
_SERVER["HTTP_ACCEPT"] text/xml,application/xml,application/xhtml+xml,text/html;q=0.9,text/plain;q=0.8,image/png,*/*;q=0.5
_SERVER["HTTP_ACCEPT_LANGUAGE"] de-de,de;q=0.8,en-us;q=0.5,en;q=0.3
_SERVER["HTTP_ACCEPT_ENCODING"] gzip,deflate
_SERVER["HTTP_ACCEPT_CHARSET"] ISO-8859-1,utf-8;q=0.7,*;q=0.7
_SERVER["HTTP_KEEP_ALIVE"] 300
_SERVER["HTTP_CONNECTION"] keep-alive
_SERVER["HTTP_CACHE_CONTROL"] max-age=0
_SERVER["PATH"] C:\\Perl\\bin\\;C:\\Programme\\Support Tools\\;C:\\Programme\\Windows Resource Kits\\Tools\\;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\Programme\\MySQL\\MySQL Server 4.1\\bin
_SERVER["SystemRoot"] C:\\WINDOWS
_SERVER["COMSPEC"] C:\\WINDOWS\\system32\\cmd.exe
_SERVER["PATHEXT"] .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH
_SERVER["WINDIR"] C:\\WINDOWS
_SERVER["SERVER_SIGNATURE"] <address>Apache Server at x.x.x.x Port 80</address>
_SERVER["SERVER_SOFTWARE"] Apache
_SERVER["SERVER_NAME"] x.x.x.x
_SERVER["SERVER_ADDR"] x.x.x.x
_SERVER["SERVER_PORT"] 80
_SERVER["REMOTE_ADDR"] x.x.x.x
_SERVER["DOCUMENT_ROOT"] E:/public_html
_SERVER["SERVER_ADMIN"] a@a.de
_SERVER["SCRIPT_FILENAME"] E:/public_html/test/index.php
_SERVER["REMOTE_PORT"] 4183
_SERVER["GATEWAY_INTERFACE"] CGI/1.1
_SERVER["SERVER_PROTOCOL"] HTTP/1.1
_SERVER["REQUEST_METHOD"] GET
_SERVER["QUERY_STRING"] no value
_SERVER["REQUEST_URI"] /test/
_SERVER["SCRIPT_NAME"] /test/index.php
_SERVER["PHP_SELF"] /test/index.php
_SERVER["PATH_TRANSLATED"] E:/public_html/test/index.php
_SERVER["argv"]
Array
_SERVER["argc"] 0
_ENV["ALLUSERSPROFILE"] C:\\Dokumente und Einstellungen\\All Users
_ENV["ClusterLog"] C:\\WINDOWS\\Cluster\\cluster.log
_ENV["CommonProgramFiles"] C:\\Programme\\Gemeinsame Dateien
_ENV["COMPUTERNAME"] WEBSERVER-1
_ENV["ComSpec"] C:\\WINDOWS\\system32\\cmd.exe
_ENV["FP_NO_HOST_CHECK"] NO
_ENV["NUMBER_OF_PROCESSORS"] 4
_ENV["OS"] Windows_NT
_ENV["Path"] C:\\Perl\\bin\\;C:\\Programme\\Support Tools\\;C:\\Programme\\Windows Resource Kits\\Tools\\;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\Programme\\MySQL\\MySQL Server 4.1\\bin
_ENV["PATHEXT"] .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH
_ENV["PROCESSOR_ARCHITECTURE"] x86
_ENV["PROCESSOR_IDENTIFIER"] x86 Family 15 Model 4 Stepping 1, GenuineIntel
_ENV["PROCESSOR_LEVEL"] 15
_ENV["PROCESSOR_REVISION"] 0401
_ENV["ProgramFiles"] C:\\Programme
_ENV["SystemDrive"] C:
_ENV["SystemRoot"] C:\\WINDOWS
_ENV["TEMP"] C:\\WINDOWS\\TEMP
_ENV["TMP"] C:\\WINDOWS\\TEMP
_ENV["USERPROFILE"] C:\\Dokumente und Einstellungen\\Default User
_ENV["windir"] C:\\WINDOWS
_ENV["AP_PARENT_PID"] 1408
  • 2 Monate später...
