Cisco 803 und Voip
habe mir einen 803 zugelegt und ihn dsl- fähig gemacht. Klappt soweit auch alles ganz gut. Nur kann meine Voip-Anlage sich nicht mehr mit dem Sip-Server von Gmx verbinden.
Wo habe ich was übersehen? Wer kann helfen?
Hier mal die Config (Auszug):
ip inspect udp idle-time 60
ip inspect dns-timeout 30
ip inspect tcp finwait-time 10
ip inspect tcp synwait-time 60
ip inspect name standard fragment maximum 256 timeout 5
ip inspect name standard ftp timeout 1800
ip inspect name standard udp timeout 1800
ip inspect name standard cuseeme timeout 1800
ip inspect name standard h323 timeout 1800
ip inspect name standard netshow timeout 1800
ip inspect name standard rcmd timeout 1800
ip inspect name standard realaudio timeout 1800
ip inspect name standard sqlnet timeout 1800
ip inspect name standard streamworks timeout 1800
ip inspect name standard vdolive timeout 1800
ip inspect name standard tcp timeout 1800
ip inspect name standard http java-list 2 timeout 1800
ip ssh break-string
vpdn enable
vpdn-group pppoe
request-dialin
protocol pppoe
isdn switch-type basic-net3
isdn voice-call-failure 0
interface Ethernet0
ip address 192.168.2.16 255.255.255.0
ip access-group FromInternal in
ip mtu 1500
ip nat inside
ip inspect standard in
ip tcp adjust-mss 1452
pppoe enable
pppoe-client dial-pool-number 10
interface BRI0
ip address negotiated
encapsulation ppp
shutdown
ppp pap sent-username MyISDNaccount password 0 MyISDNpassword
interface Dialer0
ip access-group FromExternal in
ip mtu 1454
ip nat outside
encapsulation ppp
load-interval 30
dialer pool 10
ppp authentication chap pap callin
ppp chap hostname frn6/xxxxxx
ppp chap password 0 xxx
ip nat translation finrst-timeout 120
ip nat translation syn-timeout 120
ip nat translation dns-timeout 120
ip nat translation icmp-timeout 120
ip nat inside source list NatToExternal interface Dialer0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http access-class 99
ip http authentication local
no ip http secure-server
ip access-list standard NatToExternal
permit 192.168.2.0 0.0.0.255
ip access-list standard NatToExternalt3
permit 212.227.15.197
ip access-list standard nat
ip access-list extended FromExternal
deny ip host 0.0.0.0 any log
deny ip 0.0.0.0 0.255.255.255 255.0.0.0 0.255.255.255 log
deny ip 1.0.0.0 0.255.255.255 255.0.0.0 0.255.255.255 log
deny ip 10.0.0.0 0.255.255.255 255.0.0.0 0.255.255.255 log
deny ip 19.255.0.0 0.0.255.255 255.255.0.0 0.0.255.255 log
deny ip 59.0.0.0 0.255.255.255 255.0.0.0 0.255.255.255 log
deny ip 127.0.0.0 0.255.255.255 255.0.0.0 0.255.255.255 log
deny ip 129.156.0.0 0.0.255.255 255.255.0.0 0.0.255.255 log
deny ip 169.254.0.0 0.0.255.255 255.255.0.0 0.0.255.255 log
deny ip 172.16.0.0 0.15.255.255 255.240.0.0 0.15.255.255 log
deny ip 192.0.2.0 0.0.0.255 255.255.255.0 0.0.0.255 log
deny ip 192.5.0.0 0.0.0.255 255.255.255.0 0.0.0.255 log
deny ip 192.9.200.0 0.0.0.255 255.255.255.0 0.0.0.255 log
deny ip 192.9.99.0 0.0.0.255 255.255.255.0 0.0.0.255 log
deny ip 192.168.0.0 0.0.255.255 255.255.0.0 0.0.255.255 log
deny ip 224.0.0.0 31.255.255.255 224.0.0.0 31.255.255.255 log
deny ip any 255.255.255.128 0.0.0.127 log
permit icmp any any packet-too-big
permit icmp any any administratively-prohibited
permit icmp any any parameter-problem
permit icmp any any time-exceeded
permit icmp any any echo-reply
permit udp host 134.76.10.46 eq ntp any eq ntp
permit tcp any any eq 22
deny ip any any log
ip access-list extended FromInternal
permit tcp any any
permit udp any any
permit icmp any any
access-list 2 remark CBAC java-inspection list
access-list 2 permit any
access-list 99 permit 10.0.0.5
dialer-list 10 protocol ip permit
Cisco803_DSL#
welches IOS Version nutzt Du ?
Habe auch das gleiche Problem auf meinem 2621. Mit IOS 12.3(12) läuft alles.
Mit 12.3 (18) registriert sich die FonBox ATA. Es kommt aber keine Telefonat zu stande.
Nutze daher das alte System ohne Probleme.
Welche Hardware nutzt Du ?
Eines kann ich Dir aber als TIP geben. Bei ging es erst, als ich die den Port 5060 auf meine FonBox gemappt hatte. ( der STUN Server sollte zwar eledigen, geht aber bei mir nicht )
_xymos.
