Cisco 1841
Hallo habe einen Cisco 1841 Router der sich auch mit dsl verbindet. Also der Router geht online nur die Rechner im Lan haben anscheinend keinen zugriff aufs Internet. Jedoch können sie den Router erreichen. Wo muss man was einstellen in den Acceslisten?
Hier die Config :
Router#sh run
Building configuration...
Current configuration : 2105 bytes
version 12.3
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
no ip ips deny-action ips-interface
no ip domain lookup
vpdn enable
vpdn ip udp ignore checksum
vpdn-group pppoe
request-dialin
protocol pppoe
no ftp-server write-enable
no crypto isakmp ccm
interface FastEthernet0/0
description LAN-Interface
ip address 192.168.0.254 255.255.255.0
speed auto
full-duplex
interface FastEthernet0/1
description T-dsl
no ip address
ip mtu 1492
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
interface FastEthernet0/0/0
interface FastEthernet0/0/1
interface FastEthernet0/0/2
interface FastEthernet0/0/3
interface Vlan1
no ip address
interface Dialer1
ip address negotiated
ip access-group outside in
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap chap callin
ppp chap hostname xxxxxxxxxxxxxxxxxxxxxxxxxxxxx@t-online.de
ppp chap password xxxxxxx
ppp pap sent-username xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx@t-online.de password xxxxxxx
ppp ipcp dns request
ppp ipcp wins request
no ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
no ip http secure-server
ip access-list extended outside
permit tcp host 192.168.0.1 any
permit icmp host 192.168.0.1 any
permit icmp any any
permit udp any any eq isakmp
permit esp any any
access-list 101 permit ip 192.168.0.0 0.0.0.255 any
access-list 120 remark INTERESTING TRAFFIC FOR DIALER
access-list 120 permit ip any any
dialer-list 1 protocol ip permit
snmp-server community public RO
snmp-server enable traps tty
control-plane
line con 0
line aux 0
line vty 0 4
login
end
ich würde sagen da ist kein NAT eingerichtet. Es sind zwar Interfaces für ip nat inside und outside festgelegt. Aber es feht ein "ip nat inside source ...." mit
einem "ip nat pool ... overload"
Das würde zumindest erklären, warum der Router selber rauskommt, aber keine Clients dahinter.
Fu
Danke erstmal für deine Hilfe. So müsste es doch jetzt laufen oder?
config :
version 12.3
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
no mmi pvc
ip subnet-zero
ip cef
no ip domain lookup
vpdn enable
vpdn-group pppoe
request-dialin
protocol pppoe
ip nat inside
speed auto
full-duplex
description T-dsl
no ip address
ip mtu 1492
ip nat inside
duplex auto
speed auto
pppoe enable
no cdp enable
interface Vlan1
no ip address
interface Dialer1
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp chap hostname xxxxxxxxxxxxxxxxxxxx@t-online.de
ppp chap password xxxxxxxxxxxxxxxx
ppp pap sent-username xxxxxxxxxxxxxxxxxxxxxxxxxxxxx@t-online.de password xxxxxxx
no ip classless
ip http server
ip nat inside source list 1 interface Dialer1 overload
permit icmp any any
permit esp any any
control-plane
line con 0
line aux 0
line vty 0 4
login
end
Ups da fehlte was ;)
ip http server
permit icmp any any
permit esp any any
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 1 remark IP Nat inside source list
So funktioniert jetzt also ich kann von meinen Rechner einen pc im Internet anpingen aber habe irgendwie keine dns auflösung :( Was muss ich denn da noch einstellen?
version 12.3
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
no mmi pvc
ip subnet-zero
ip cef
no ip domain lookup
vpdn enable
vpdn-group pppoe
request-dialin
protocol pppoe
ip nat inside
speed auto
full-duplex
description T-dsl
no ip address
ip mtu 1492
duplex auto
speed auto
pppoe enable
no cdp enable
interface Vlan1
no ip address
interface Dialer1
ip access-group 101 in
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp chap hostname xxxxxxxxxxxxxxxxxxxxxxxxxxxx1@t-online.de
ppp pap sent-username xxxxxxxxxxxxxxxxxxxxxxxxxx@t-online.de password xxxxxxxxx
no ip classless
ip http server
ip http access-class 1
ip dns server
permit icmp any any
permit esp any any
access-list 101 remark access group 101 in
access-list 101 permit udp any any eq ntp
access-list 101 permit icmp any any echo
access-list 101 permit icmp any any echo-reply
access-list 101 permit udp any any eq domain
access-list 101 permit tcp any any eq www
access-list 101 permit tcp any any eq ftp-data
access-list 101 permit tcp any any eq smtp
access-list 101 permit tcp any any eq pop3
access-list 101 permit tcp any any eq 443
control-plane
line con 0
line aux 0
line vty 0 4
login
end
Ja, das sieht besser aus. Kannst es ja mal ausprobieren und bescheid sagen.
Wichtig ist:
=> Damit ist das Netz 192.168.0.xxx abgedeckt.
Fu
Prima.
Jepp, weiß gerade nicht ob du die lokalen Adressen per DHCP bekommst oder fest eingetragen hast. Normalerweise übermittelt dir ja dein Provider die DNS Einträge. Macht aber nur Sinn, wenn du deinen Router die per DHCP verteilen lassen willst. Sonst solltest du dir die fest auf deinem Rechner eintragen.
Fu
