xyCruiseryx 10 Geschrieben 19. April 2006 Melden Geschrieben 19. April 2006 Moin ich brauche mal eine kurze Definitionshilfe vom Begriff: VTP und DTP VTP: Vlan trunking protokoll: Mitteilen der Vlan Informationen (vom Server) an alle Clients DTP: Dynamic trunking protokoll: Austomatisches Aushandeln von "MLTs oder Etherchannels auf jedem Port. Default ist DTP eingeschaltet. Status: on, desirable, auto Ist das so IO ???? kann mir einer den Unterschied zwischen den 3 Staus optionen erklären. ich hab noch nie was mit dem DTP zutun gehabt. THX
daking 10 Geschrieben 20. April 2006 Melden Geschrieben 20. April 2006 Hola, das sollte helfen: Trunking Mode Characteristics COS = on IOS = mode trunk Trunking is on for these links. They will also send DTP signals that attempt to initiate a trunk with the other side. This will form a trunk with other ports in the states on, auto, or desirable that are running DTP. A port that is in on mode always tags frames sent out the port. --------------------------------------------------------------------------------------- COS = desirable IOS = mode dynamic desirable These links would like to become trunk links and will send DTP signals that attempt to initiate a trunk. They will only become trunk links if the other side responds to the DTP signal. This will form a trunk with other ports in the states on, auto, or desirable that are running DTP. This is the default mode for the 6000 running Supervisor IOS. -------------------------------------------------------------------------------------- COS = auto IOS = mode dynamic auto These links will only become trunk links if they receive a DTP signal from a link that is already trunking or desires to trunk. This will only form a trunk with other ports in the states on or desirable. This is the default mode for COS switches. ---------------------------------------------------------------------------------------- COS = off IOS = no switchport mode trunk This option sets trunking and DTP capabilities off. This is the recommended setting for any access port because it will prevent any dynamic establishments of trunk links. ----------------------------------------------------------------------------------------- If you want to enable trunking and not send any DTP signaling, use the option nonegotiate for switches that support that function. If you want to disable trunking completely, use the off option for a COS switch or the no switchport mode trunk command on an IOS switch. Ciao
xyCruiseryx 10 Geschrieben 20. April 2006 Autor Melden Geschrieben 20. April 2006 Besten Dank dafür :) ab welcher IOS Version wird die Funktion unterstützt ? Welche Geräte können das heute schon ?
