VPN Problem
habe ein Router to VPN ´Client VPN. Klappt auch alles. Wenn ich mich einwähle kann ich den Cisco Router anpingen nur alles was dahinter ist ist nicht erreichbar woran kann das liegen?
Anbei meine Config:
version 12.3
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $1$PUN1$HBgGDWxf6jbV6kGzW7IX40
aaa new-model
aaa authentication login userauthen local
aaa authorization network groupauthor local
aaa session-id common
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
no ip ips deny-action ips-interface
vpdn enable
vpdn ip udp ignore checksum
vpdn-group pppoe
request-dialin
protocol pppoe
ip mtu adjust
no ftp-server write-enable
username cisco password 0 cisco1234
crypto isakmp policy 3
encr 3des
authentication pre-share
group 2
no crypto isakmp ccm
crypto isakmp client configuration group 3000client
key xxxxxxxxx
pool ippool
crypto ipsec transform-set myset esp-3des esp-sha-hmac
crypto dynamic-map dynmap 10
set transform-set myset
crypto map clientmap client authentication list userauthen
crypto map clientmap isakmp authorization list groupauthor
crypto map clientmap client configuration address respond
crypto map clientmap 10 ipsec-isakmp dynamic dynmap
interface FastEthernet0/0
description T-dsl
no ip address
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
fair-queue
interface FastEthernet0/1
description LAN
ip address 192.168.0.253 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/0/0
interface FastEthernet0/0/1
interface FastEthernet0/0/2
interface FastEthernet0/0/3
interface Vlan1
no ip address
interface Dialer1
description WAN
bandwidth 2048
ip address negotiated
ip access-group 101 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip nat outside
encapsulation ppp
ip route-cache flow
ip tcp adjust-mss 1452
no ip mroute-cache
dialer pool 1
dialer idle-timeout 0
dialer persistent
dialer-group 1
fair-queue
no cdp enable
ppp authentication chap callin
ppp chap hostname xxxxxxxxxxxxxxxxxxxxxxxxxx@t-online.de
ppp chap password xxxxxxxxxxxxxxx
ppp ipcp dns request
ip local pool ippool 14.1.1.100 14.1.1.200
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer1 overload
ip nat inside source list 2 interface Dialer1 overload
ip nat inside source list 3 interface Dialer1 overload
ip nat inside source list 101 interface Dialer1 overload
ip nat inside source static tcp 192.168.0.1 21 interface Dialer1 21
ip nat inside source static tcp 192.168.0.1 20 interface Dialer1 20
ip nat inside source static udp 192.168.0.1 20 interface Dialer1 20
ip nat inside source static udp 192.168.0.1 21 interface Dialer1 21
ip dns server
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 2 permit 192.168.0.0 0.0.0.255
access-list 3 permit 0.0.0.0 255.255.255.0
dialer-list 1 protocol ip permit
snmp-server community public RO
snmp-server enable traps tty
control-plane
line con 0
line aux 0
line vty 0 4
end
Ich glaub das liegt an den NATs, die sehn ja aus wie Kraut und Rueben :) Und wenn du wo weiter kommst, kannst du das bitte in alten Post weiterfuehren? Ich bin sicher, dass ich nicht der einzige bin der am Montag alle Posts von unten nach oben abarbeitet und sich dann b***d vorkommt fuer geloeste Probleme Antworten zu suchen :suspect:
interface Dialer1
101 existiert nicht, 2 und 1 ist dasselbe und 3 dann auch wieder n Witz.
Also nimm erst mal die 101 aus dem Dialer, dann die 101 NAT Regel raus, am besten die anderen 3 auch weg. Dann machste
access-list 100 deny ip 192.168.0.0 0.0.0.255 14.1.1.0 0.0.0.255
access-list 100 deny ip 192.168.1.0 0.0.0.255 14.1.1.0 0.0.0.255
access-list 100 permit ip 192.168.0.0 0.0.0.255 any
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
ip nat inside source list 100 interface Dialer1 overload
So in etwa sollte das aussehn.
Hallo danke erstmal! Habe meine access-list mal aufgeräumt. Und jetzt müsste auch alles andere was hinter dem Router liegt über den VPN tunnel erreichbar sein?
Habe leider im moment keinen der sich einwählen könnte...
Meine Config sieht jetzt so aus:
Current configuration : 3192 bytes
version 12.3
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $1$TccG$wyS7OKZtudIYJ45n8SQVC0
aaa new-model
resource policy
no mmi pvc
ip subnet-zero
ip cef
encr 3des
group 2
key cisco123
pool ippool
description T-dsl
no ip address
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
pppoe enable
fair-queue
description LAN
ip nat inside
duplex auto
speed auto
interface Vlan1
no ip address
interface Dialer1
description WAN
bandwidth 2048
ip ddns update hostname cobradirk.no-ip.info
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip nat outside
encapsulation ppp
ip route-cache flow
no ip mroute-cache
dialer pool 1
dialer persistent
dialer-group 1
fair-queue
no cdp enable
ppp chap hostname 0004906756665200356675920001@t-online.de
ppp chap password 0 03216705
ip classless
ip route 14.1.1.0 255.255.255.0 FastEthernet0/0
ip http server
ip dns server
control-plane
line con 0
line aux 0
line vty 0 4
end
Das da gehoert eigentlich raus, das weiss die Cisco schon selbst. Wenns nicht geht, probier mal die crypto map noch aufs interne IF zu haengen. Bin mir da nie ganz sicher ...
Ok ... Aber auf der Seite wo ich mich mit den VPN client einwähle existiert ein 192.168.1.0 Netz wie kann ich das dann von meinen Cisco aus erreichen wie sehe die Route aus?
192.168.1.0 255.255.255.0 fastethernet 0/0 <--- so?
Aber als ich mich gestern von der Firma aus per Cisco VPN Client eingewählt habe konnte ich nur von der Firma aus den Cisco erreichen also die 192.168.0.253. Vom Cisco aus Konnte ich nichts aus dem Firmennetz erreichen oder lag das alles wirklich an meinen zich NAT listen ;) ?
Cisco ist im 192.168.0.0 Netz habe mich dann von woanders wo ein 192.168.1.0 Netz existiert eingewählt. Konnte von dem 1.0 Netz dann nur den Cisco erreichen vom Cisco jedoch konnte ich keinen Rechner aus dem 1.0 Netz pingen.
