Probleme mit Cisco 1721 und BRI-Interface
Global ISDN Switchtype = basic-net3
ISDN BRI0 interface
dsl 0, interface ISDN Switchtype = basic-net3
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
Layer 2 NOT Activated
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x80000003
Total Allocated ISDN CCBs = 0
Das liefert bei einem weiteren Verbindungsversuch folgenden Output:
May 19 11:17:00.019: ISDN LIFd: l3_timer: timer Expiry (0x82763D08), timer_type (0x1313)
May 19 11:17:00.019: ISDN BR0 Q931d: L3_Go: source 0x0300, event 0x1313, call id 0x int id 0x10
May 19 11:17:00.019: ISDN BR0 Q931d: L3_Go: event 0x1313 cr_len 0 cr 0
May 19 11:17:00.019: ISDN BR0 Q931d: L3_Go: call_id 0x8010 cr 0x10 state 1 event 0x1313 ces 1
May 19 11:17:00.019: ISDN BR0 Q931d: L3_ProcessEvent: callref = 0x0010 T303_EXPIRY:U1_T303Expiry(nlcb)
May 19 11:17:00.019: ISDN BR0 Q931d: srl_send_l3_pak:
source_id = Q.931 0x0300, dest_id = Q.921 0x0000, prim = DL_DATA_REQ 0x0240
priv_len = 4 int_id = 0x8203843C datasize = 24
May 19 11:17:00.023: ISDN BR0 Q931d: data =
May 19 11:17:00.023: 8203843C000003000240040D00010806
May 19 11:17:00.023: 0801105A080280E6
May 19 11:17:00.023: ISDN BR0 Q931d: L3_state_change: callref 0x0010 old CALL_INIT, new NULL_STATE
May 19 11:17:00.023: ISDN BR0 PACKET: handle_mail: received:
dest_id = 0, source_id = 768, prim = 240
priv_ln = 4, int_id = -2113698756, datasize = 24
May 19 11:17:00.023: ISDN BR0 PACKET: L2IF_DispPak: packet - start(3167038), size (24)
May 19 11:17:00.027: 0801105A080280E60015F90DE144574E
May 19 11:17:00.027: F3C600090F0209E5
May 19 11:17:00.027: ISDN BR0 PACKET: handle_mail: received data =
May 19 11:17:00.027: ISDN BR0 Q921d: L2_GetDLCB: ces 1
May 19 11:17:00.027: ISDN BR0 Q921d: NOP: DLCB state 1 EventIndex 1 L2_Event 576 Tei 255 DSL_Chan 0 ces 1 SAPI 0
May 19 11:17:00.027: ISDN BR0 Q921d: L2_FreeDLCB
May 19 11:17:00.031: ISDN LIFd: isdn_L3_timer_process: event_count (1)
May 19 11:17:00.031: ISDN BR0 CC: CCBRI_Go: source id 0x300, state 1, call id 0x8010, event 0x341
May 19 11:17:00.031: ISDN BR0 CC: CCBRI_Go: call id 0x8010 call ref 0x10 state 6 event 0x91 Src->L3
May 19 11:17:00.031: ISDN BR0 TGRM: get_tgrm_avail_state: idb 0x8203843C bchan 1 service_state 0 call_state 0 false busy 0x0 dsl 0
May 19 11:17:00.031: ISDN BR0 TGRM: update_tgrm_call_status: idb 0x8203843C bchan 1 availability state 1 call state(prev,new) (1,0), dsl 0
May 19 11:17:00.035: ISDN BR0 TGRM: update_tgrm_call_status: Calling TGRM with tgrm_call_isdn_update: idb 0x8203843C bchan 1 call state 0 call type 0 call dir 1
May 19 11:17:00.035: ISDN EVENTd: cc_clear_free_list freed 0x8278A118
May 19 11:17:00.035: ISDN BR0 EVENT: process_rxstate: ces/callid 1/0x8010 calltype 1 HOST_DISCONNECT_ACK
May 19 11:17:00.035: ISDN BR0 PACKET: process_rxstate:
May 19 11:17:00.035: 060001801000
May 19 11:17:00.035: ISDN BR0 EVENTd: calltrkr_call_cleared: isdn_info=0x820397D8, call_id=0x8010
May 19 11:17:00.039: ISDN BR0 EVENTd: calltrkr_call_cleared: hndl=0l, cause=0, Unknown cause value
May 19 11:17:00.039: ISDN BR0 **ERROR**: host_disconnect_ack: Unfound B-channel on Disconnect_Ack call id 0x8010
May 19 11:17:22.072: ISDN BR0 EVENT: UserIdle: callid 0x8010 received ISDN_HANGUP (0x1)
May 19 11:17:22.072: ISDN BR0 EVENTd: process_disconnect: call id 0x8010, call type is DATA, b_idb 0x8203843C, ces 1, cause Normal call clearing(0x10)
May 19 11:17:22.072: ISDN BR0 EVENTd: calltrkr_call_disconnected: isdn_info=0x820397D8, call_id=0x8010
May 19 11:17:22.072: ISDN BR0 EVENTd: process_disconnect: Raw Release Message
May 19 11:17:22.072: 0500018010040802FF9008028090
May 19 11:17:22.072: ISDN BR0 CC: CCBRI_Go: source id 0x500, state 0, call id 0x0, event 0x5
May 19 11:17:22.072: ISDN BR0 CCd: CCBRI_Go: Host PkgInfo:
May 19 11:17:22.076: 0500018010040802FF9008028090
May 19 11:17:22.076: ISDN BR0 **ERROR**: CCBRI_Go: NO CCB Src->HOST call id 0x8010, event 0x5 ces 1
May 19 11:17:22.076: ISDN BR0 EVENT: process_rxstate: ces/callid 1/0x8010 calltype 1 HOST_QUERY_RESPONSE
May 19 11:17:22.076: ISDN BR0 PACKET: process_rxstate:
May 19 11:17:22.076: 0B0001801003140100
der versteht sich nicht mit dem switch, also entweder ein ios problem oder der telekom switch hat ein problem, als letztes kannst du nocheinmal versuchen, 1. router ausschalten, reset am nt (netz raus und wieder ein), dann router wieder an... komisch ist bloss, daß an der telefonanlage das gleiche problem war... was wiederum mehr in richtung router sw weist
Ich glaube fast weniger, daß es hilft, aber versuche mal folgendes:
Mache den Router mal komplett nackig, will heißen, außer der Konfig:
isdn switch-type basic-net3
interface BRI0
no ip address
und dem normalen default-Kram (wr erase + reload) sollte nichts weiter drauf sein.
Und dann probiers nochmal mit dem Debugging:
debug isdn q921
debug isdn q931
(ggf. ergänzt durch die bereits angesprochenen: "deb isdn l2" und "deb isdn events")
und dem hier:
isdn test call interface bri0 <Telefonnummer>
Statt <Telefonnummer> nimmst du einfach deine eigene Nummer, also die des ISDN-Anschlusses, an dem du gerade mit deinem Router steckst.
Die Ausgabe des Debuggings kannst du ja mal posten.
Hintergrund des Ganzen: Eventuell hinderliche Konfig-Teile als Fehlerursache auszuschließen.
Obwohl auch andere das schon vor mir getan haben, muß ich trotzdem auch nochmal dämlich nachfragen: Das Kabel ist wirklich in Ordnung?
