Metalhead 10 Geschrieben 19. Mai 2006 Melden Geschrieben 19. Mai 2006 Hallo, ich habe ein problem bei der tacacs+ authentication. ich will auch das enable pwd via tacacs abfragen, doch leider funktioniert das nicht. die pwds sind auf einem linux hobel im /etc/passwd file drinnen. der login funkt schon, nur der wechsel in den enable mode geht noch nicht. hat irgendwer eine idee? cisco conf: aaa new-model aaa authentication login default group tacacs+ enable local aaa authentication enable default group tacacs+ aaa authorization config-commands aaa authorization commands 0 default group tacacs+ if-authenticated aaa authorization commands 1 default group tacacs+ if-authenticated aaa authorization commands 15 default group tacacs+ if-authenticated aaa accounting exec default start-stop group tacacs+ aaa accounting exec exec start-stop group tacacs+ aaa accounting commands 15 default start-stop group tacacs+ aaa accounting network default start-stop group tacacs+ aaa accounting connection default start-stop group tacacs+ aaa accounting system default start-stop group tacacs+ conf file des tacacs: key = "xxx" # Set up accounting file if enabling accounting on NAS accounting file = /var/log/tac.log user = $enable$ { login = file /etc/passwd } group = admin { login = file /etc/passwd } group = operators { login = file /etc/passwd } user = aaaaa { default service = permit member = admin } user = bbbbb { default service = permit member = admin } user = ccccc { default service = permit member = admin } user = dddd{ member = operators cmd = show { permit .* } cmd = traceroute { permit .* } cmd = logout { permit .* } cmd = enable { permit .* } }
