xxxomxxx 10 Geschrieben 12. Juni 2006 Melden Geschrieben 12. Juni 2006 Hi ich habe einmal netdiag laufen gelassen, da ich Offline Probleme habe..da habe ich plötzlich festgestellt, dass netdiag fehler auswirft: DNS test . . . . . . . . . . . . . : Failed [WARNING] Cannot find a primary authoritative DNS server for the name 'entserver.olivermueller.ch.'. [WSAEADDRNOTAVAIL ] The name 'entserver.olivermueller.ch.' may not be registered in DNS. [WARNING] Cannot find a primary authoritative DNS server for the name 'entserver.olivermueller.ch.'. [ERROR_TIMEOUT] The name 'entserver.olivermueller.ch.' may not be registered in DNS. [WARNING] Cannot find a primary authoritative DNS server for the name 'entserver.olivermueller.ch.'. [ERROR_TIMEOUT] The name 'entserver.olivermueller.ch.' may not be registered in DNS. [WARNING] Cannot find a primary authoritative DNS server for the name 'entserver.olivermueller.ch.'. [WSAEADDRNOTAVAIL ] The name 'entserver.olivermueller.ch.' may not be registered in DNS. [WARNING] Cannot find a primary authoritative DNS server for the name 'entserver.olivermueller.ch.'. [ERROR_TIMEOUT] The name 'entserver.olivermueller.ch.' may not be registered in DNS. [FATAL] Failed to fix: DC DNS entry _ldap._tcp.olivermueller.ch. re-registeration on DNS server '0.0.0.0' failed. DNS Error code: 0x00002741 [FATAL] Failed to fix: DC DNS entry _ldap._tcp.Default-First-Site-Name._sites.olivermueller.ch. re-registeration on DNS server '0.0.0.0' failed. DNS Error code: 0x00002741 [FATAL] Failed to fix: DC DNS entry _ldap._tcp.pdc._msdcs.olivermueller.ch. re-registeration on DNS server '0.0.0.0' failed. DNS Error code: 0x00002741 [FATAL] Failed to fix: DC DNS entry _ldap._tcp.gc._msdcs.olivermueller.ch. re-registeration on DNS server '0.0.0.0' failed. DNS Error code: 0x00002741 [FATAL] Failed to fix: DC DNS entry _ldap._tcp.Default-First-Site-Name._sites.gc._msdcs.olivermueller.ch. re-registeration on DNS server '0.0.0.0' failed. DNS Error code: 0x00002741 [FATAL] Failed to fix: DC DNS entry _ldap._tcp.52ac991d-574d-474c-a9a4-cfe799229aa6.domains._msdcs.olivermueller.ch. re-registeration on DNS server '0.0.0.0' failed. ..... DNS Error code: 0x00002741 [FATAL] Failed to fix: DC DNS entry olivermueller.ch. re-registeration on DNS server '0.0.0.0' failed. DNS Error code: 0x00002741 [FATAL] Failed to fix: DC DNS entry gc._msdcs.olivermueller.ch. re-registeration on DNS server '0.0.0.0' failed. DNS Error code: 0x00002741 [FATAL] Failed to fix: DC DNS entry DomainDnsZones.olivermueller.ch. re-registeration on DNS server '0.0.0.0' failed. DNS Error code: 0x00002741 [FATAL] Failed to fix: DC DNS entry ForestDnsZones.olivermueller.ch. re-registeration on DNS server '0.0.0.0' failed. DNS Error code: 0x00002741 [FATAL] Fix Failed: netdiag failed to re-register missing DNS entries for this DC on DNS server '0.0.0.0'. [FATAL] No DNS servers have the DNS records for this DC registered. eigentlich funktioniert alles bestens, auch das AD plugin startet schnell, aber irgendwo steckt hier ein Wurm drin...woher hat er den 0.0.0.0 Eintrag?? nebenbei: -dcdiag hat keine fehler - in ReplMon unter den Server Eigenschten bei TCP/IP ist noch ein alter Adpter aufgeführt: Adapter: NdisWan MAC Address: 00:53:45:00:00:00 IP Address: 192.168.1.101 IP Subnet: 255.255.255.255 WINS Scope ID: DHCP Enabled: False (könnte man diesen entfernen?) Zitieren
blub 115 Geschrieben 12. Juni 2006 Melden Geschrieben 12. Juni 2006 ist ein bekannter Bug: *.ch als Domänenendung läuft auf dieser Windowsversion einfach nicht stabil.... cu blub Zitieren
hh2000 10 Geschrieben 12. Juni 2006 Melden Geschrieben 12. Juni 2006 Hallo, poste doch mal ein ipconfig /all vom Server Gruß Kai Zitieren
xxxomxxx 10 Geschrieben 13. Juni 2006 Autor Melden Geschrieben 13. Juni 2006 ist ein bekannter Bug: *.ch als Domänenendung läuft auf dieser Windowsversion einfach nicht stabil.... cu blub ?? wieso den das? gibt ja nicht viele Alternativen ...müste man die lokale domäne .local nenen oder in die richtung gehen? Zitieren
xxxomxxx 10 Geschrieben 13. Juni 2006 Autor Melden Geschrieben 13. Juni 2006 Hallo, poste doch mal ein ipconfig /all vom Server Gruß Kai wie kann man das schon wieder in ein log printen? er gitb mir etwas viel aus wegen Ipv6: Host Name: entserver prim DNS Suffix: olivermueller.ch node typ: broadcast Ip Routing:yes WINS: yes IP Adress: 192.168.1.1 Subnet : 255.255.255.0 IP Adress (IPv6, sollte nicht stören, oder?): fe80::211:d8ff:fe3f:B222%4 DHCP 192.168.1.100 DNS: 192.168.1.1 fec0:0:0:ffff::1%1 fec0:0:0:ffff::2%1 fec0:0:0:ffff::3%1 Zitieren
hh2000 10 Geschrieben 13. Juni 2006 Melden Geschrieben 13. Juni 2006 Moin, z.B. mit ipconfig /all > c:\a.txt (IPV6 kenne ich aber auch noch nicht) Hast Du mehrere Netzwerkkarten drin? (IP-Routing =yes) Gruß Kai Zitieren
xxxomxxx 10 Geschrieben 13. Juni 2006 Autor Melden Geschrieben 13. Juni 2006 anbei die config nachdem ich IPv6 wieder deinstalliert habe... offensichtlich ist das Pseudo-Interface hängengeblieben... es ist nur ein Netzwerk Controller installiert, aber es hatte mal zwei. (Wo könnte ich diesen alten Eintrag löschen? Windows IP Configuration Host Name . . . . . . . . . . . . : entserver Primary Dns Suffix . . . . . . . : olivermueller.ch Node Type . . . . . . . . . . . . : Unknown IP Routing Enabled. . . . . . . . : Yes WINS Proxy Enabled. . . . . . . . : Yes DNS Suffix Search List. . . . . . : olivermueller.ch Ethernet adapter LAN 192.168.1.1: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Broadcom NetXtreme Gigabit Ethernet Physical Address. . . . . . . . . : 00-11-**-3F-**-22 DHCP Enabled. . . . . . . . . . . : No IP Address. . . . . . . . . . . . : 192.168.1.1 Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . : 192.168.1.100 DNS Servers . . . . . . . . . . . : 192.168.1.1 Tunnel adapter Automatic Tunneling Pseudo-Interface: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Automatic Tunneling Pseudo-Interface Physical Address. . . . . . . . . : C0-**-01-01 DHCP Enabled. . . . . . . . . . . : No Default Gateway . . . . . . . . . : DNS Servers . . . . . . . . . . . : ? NetBIOS over Tcpip. . . . . . . . : Disabled Zitieren
hh2000 10 Geschrieben 14. Juni 2006 Melden Geschrieben 14. Juni 2006 Also wenn Du in Netzwerkverbindungen keinen Adapter zum Entfernen hast, dann evtl. im Gerätemanager und dort ausgeblendete Geräte anzeigen wählen. Kannst Du denn Namen auflösen z.B. mit "nslookup entserver", vom server oder auch von einer Workstation? auch schon netdiag /fix probiert? ansonsten netdiag /debug /test:dns zeigt Dir eine ausführlichere Fehlermeldung an. Gruß Kai Zitieren
xxxomxxx 10 Geschrieben 14. Juni 2006 Autor Melden Geschrieben 14. Juni 2006 ich erhalte immer fehlermeldungen zu einem DNS sderver auf der IP 0.0.0.0... [WARNING] The DNS entries for this DC are not registered correctly on DNS server '0.0.0.0'. Please wait for 30 minutes for DNS server replication. DNS test . . . . . . . . . . . . . : Failed Interface {BD08ABFC-5EC6-425A-8507-BE2C38E4F3F1} DNS Domain: DNS Servers: 0.0.0.0 IP Address: Expected registration with PDN (primary DNS domain name): Hostname: entserver.olivermueller.ch. [WARNING] Cannot find a primary authoritative DNS server for the name 'entserver.olivermueller.ch.'. [WSAEADDRNOTAVAIL ] The name 'entserver.olivermueller.ch.' may not be registered in DNS. Interface {48FCE3FC-EC30-E50E-F1A7-71172AEEE3AE} DNS Domain: DNS Servers: 0.0.0.0 IP Address: Expected registration with PDN (primary DNS domain name): Hostname: entserver.olivermueller.ch. [WARNING] Cannot find a primary authoritative DNS server for the name 'entserver.olivermueller.ch.'. [WSAEADDRNOTAVAIL ] The name 'entserver.olivermueller.ch.' may not be registered in DNS. Interface {6BD113CC-5EC2-7638-B953-0B889DA72014} DNS Domain: DNS Servers: IP Address: Expected registration with PDN (primary DNS domain name): Hostname: entserver.olivermueller.ch. [WARNING] Cannot find a primary authoritative DNS server for the name 'entserver.olivermueller.ch.'. [ERROR_TIMEOUT] The name 'entserver.olivermueller.ch.' may not be registered in DNS. Check the DNS registration for DCs entries on DNS server '0.0.0.0' ********** * ********** * ********** * ********** * ********** * * CHECK NAME _ldap._tcp.olivermueller.ch. on DNS server 0.0.0.0 usw. wie bringe ich den fehlerhaften eintrag eines DNS auf der IP 0.0.0.0 wieder raus? Zitieren
IThome 10 Geschrieben 14. Juni 2006 Melden Geschrieben 14. Juni 2006 Überprüfe mal die Bindungsreihenfolge und in der DNS-Serverkonsole, an welche IP-Adressen der Dienst gebunden ist ... Mit SET DEVMGR_SHOW_NONPRESENT_DEVICES=1 START DEVMGMT.MSC Unter Ansicht ausgeblendete Geräte anzeigen Kannst Du nicht mehr installierte Geräte anzeigen lassen und gegebenenfalls deinstallieren (mache vorher eine Systemstate-Sicherung) Zitieren
