Wireless Monitor snap-in - wo zu finden
ichg suche den Wirelees Monitor,
der soll angeblich folgende Funktionenhaben:
Wireless Monitor allows you to view details about access points and wireless clients. You can use this information to troubleshoot your wireless service. The Wireless Configuration service logs information in Wireless Monitor that allows you to:
• Identify service configuration changes.
• Check the events logged in the Wireless Configuration service log that are generated from outside of your network, such as media event notifications, 802.1X events, and timer expiration events.
• Check how the Wireless Configuration service reacts to external events by following transitions, as they are reflected in the log.
If you want to enable or disable logging of client information then right-click the Wireless Client Information node and make the appropriate selection. This should comply with the company security monitoring requirements.
Und soll von Microsoft sein. Ich finde den aber nicht, wollte ihn schon über Software nachinstalieren, da gibt es aber auch nichts.
Wie finde ich den
Neues Benutzerkonto erstellen
Anmelden
