Active Sync und die Fehlermeldungen
Hallo!
Ich habe seit Wochen einen PDA der mit ActiveSync die Outlook Dateien syncronisieren soll. Nun habe ich allerdings eine Fehlermeldung, mit der ich nichts anfangen kann, stundenlanges suchen haben bisher nicht zum Ziel geführt. Bitte helft mir.
Hier die Meldung:
"Beim Ausführen van ActiveSync gab es ein Problem auf dem Desktop: Untzerstützungscode: 850 100 14"
Wer kann mr bei dem Problem helfen???
VG
Achim
Hi t-o-m,
wenn du nach "85010014" googlest bekommst du diese Antwort:
(hoffe dein Englisch ist gut :-))
Synchronization Error 85010014
ActiveSync reports a Synchronization Error code 85010014 because of one of the following reasons:
Synchronization Fails because Application Data Folder is Redirected
Synchronization Fails because Outlook is in Offline Mode
Synchronization Fails because of Outlook script blocking
Synchronization Fails because ActiveSync is incorrectly registered with Outlook
Application Data Folder Redirected:
If your Application Data folder under Documents & Settings folder is redirected to an external source, you will experience synchronization failures.
Please upgrade to ActiveSync 4.1 if you are experiencing this issue.
Outlook is in Offline Mode:
If you are attempting to set up synchronization or are synchronizing when Microsoft Outlook is in Offline mode or when you do not have connectivity to the Microsoft Exchange Server with Outlook, you may experience synchronization failures.
Please upgrade to ActiveSync 4.1 if you are experiencing these issues.
It is still recommended that you have Microsoft Outlook in the Online mode when synchronizing with your device.
Outlook Scripting Blocked:
Certain Desktop PC security applications may disable Outlook scripting which is required for ActiveSync too set up communications with Outlook to synchronize data.
Please ensure that script blocking for Outlook is not enabled to work around this issue. Please consult your PC security application documentation on how to disable script blocking for Microsoft Outlook.
Incorrect Outlook Registration:
Please see “Outlook needs to be Re-Installed or Repaired” section for details.
Ansonsten findest du noch andere Foren wo dieses Problem diskutiert wird. Du bist nicht allein.
Hier ein weiteres Forum:
http://www.mobilejoe.de/joeforums/archive/index.php?t-16299.html
joogy21
Neues Benutzerkonto erstellen
Anmelden
