menkee 10 Geschrieben 19. Juli 2006 Autor Melden Geschrieben 19. Juli 2006 Ich habe jetzt das Netdiag.exe aus dem Supporttol laufen lassen und das hier erhalten: Computer Name: LONDON DNS Host Name: london.company.local System info : Windows 2000 Server (Build 3790) Processor : x86 Family 6 Model 8 Stepping 10, GenuineIntel Netcard queries test . . . . . . . : Passed GetStats failed for 'Parallelanschluss (direkt)'. [ERROR_NOT_SUPPORTED] GetStats failed for 'WAN-Miniport (PPTP)'. [ERROR_NOT_SUPPORTED] GetStats failed for 'WAN-Miniport (PPPOE)'. [ERROR_NOT_SUPPORTED] [WARNING] The net card 'WAN-Miniport (IP)' may not be working because it has not received any packets. GetStats failed for 'WAN-Miniport (L2TP)'. [ERROR_NOT_SUPPORTED] Per interface results: Adapter : LAN-Verbindung Netcard queries test . . . : Passed Host Name. . . . . . . . . : london IP Address . . . . . . . . : 192.168.1.30 Subnet Mask. . . . . . . . : 255.255.255.0 Default Gateway. . . . . . : 192.168.1.1 Primary WINS Server. . . . : 192.168.1.30 Dns Servers. . . . . . . . : 127.0.0.1 AutoConfiguration results. . . . . . : Passed Default gateway test . . . : Passed NetBT name test. . . . . . : Passed [WARNING] At least one of the <00> 'WorkStation Service', <03> 'Messenger Service', <20> 'WINS' names is missing. WINS service test. . . . . : Passed Global results: Domain membership test . . . . . . : Passed NetBT transports test. . . . . . . : Passed List of NetBt transports currently configured: NetBT_Tcpip_{F40806C5-C425-49C7-B0F3-A2026822EF60} 1 NetBt transport currently configured. Autonet address test . . . . . . . : Passed IP loopback ping test. . . . . . . : Passed Default gateway test . . . . . . . : Passed NetBT name test. . . . . . . . . . : Passed [WARNING] You don't have a single interface with the <00> 'WorkStation Service', <03> 'Messenger Service', <20> 'WINS' names defined. Winsock test . . . . . . . . . . . : Passed DNS test . . . . . . . . . . . . . : Failed [WARNING] Cannot find a primary authoritative DNS server for the name 'london.company.local.'. [RCODE_SERVER_FAILURE] The name 'london.company.local.' may not be registered in DNS. [WARNING] The DNS entries for this DC are not registered correctly on DNS server '127.0.0.1'. Please wait for 30 minutes for DNS server replication. [FATAL] No DNS servers have the DNS records for this DC registered. Redir and Browser test . . . . . . : Passed List of NetBt transports currently bound to the Redir NetBT_Tcpip_{F40806C5-C425-49C7-B0F3-A2026822EF60} The redir is bound to 1 NetBt transport. List of NetBt transports currently bound to the browser NetBT_Tcpip_{F40806C5-C425-49C7-B0F3-A2026822EF60} The browser is bound to 1 NetBt transport. DC discovery test. . . . . . . . . : Passed DC list test . . . . . . . . . . . : Passed Trust relationship test. . . . . . : Skipped Kerberos test. . . . . . . . . . . : Passed LDAP test. . . . . . . . . . . . . : Passed Bindings test. . . . . . . . . . . : Passed WAN configuration test . . . . . . : Skipped No active remote access connections. Modem diagnostics test . . . . . . : Passed IP Security test . . . . . . . . . : Skipped Note: run "netsh ipsec dynamic show /?" for more detailed information The command completed successfully Zitieren
IThome 10 Geschrieben 19. Juli 2006 Melden Geschrieben 19. Juli 2006 DNS scheint Dein Problem zu sein. Welche Zonen existieren auf dem Server. Auf welche Schnittstelle/n ist der DNS-Serverdienst gebunden (kannst Du beides in der DNS-Konsole finden). Ändere den bevorzugten DNS-Server von 127.0.0.1 auf seine IP-Adresse ... Poste auch nochmal die aktuelle Ausgabe von IPCONFIG /ALL Zitieren
menkee 10 Geschrieben 19. Juli 2006 Autor Melden Geschrieben 19. Juli 2006 Mann bin ich ****....di Ip Konfiguration, war der DNS auf der 127.0.0.1 gesetzt. Habe den mal auf 192.168.1.30 geändert. wie kann ich den DNS komplett löschen und neu konfigurieren? Zitieren
IThome 10 Geschrieben 19. Juli 2006 Melden Geschrieben 19. Juli 2006 Brauchst Du nicht, wie ist der Name der Forward-Lookup Zone ? Zitieren
menkee 10 Geschrieben 19. Juli 2006 Autor Melden Geschrieben 19. Juli 2006 Name der Forward lookup zone: msdcs.company.local Windows-IP-Konfiguration Hostname . . . . . . . . . . . . : london Primäres DNS-Suffix . . . . . . . : company.local Knotentyp . . . . . . . . . . . . : Hybrid IP-Routing aktiviert . . . . . . : Nein WINS-Proxy aktiviert . . . . . . : Nein DNS-Suffixsuchliste . . . . . . . : company.local Ethernet-Adapter LAN-Verbindung: Verbindungsspezifisches DNS-Suffix: Beschreibung . . . . . . . . . . : Realtek RTL8139-Familie-PCI-Fast Ethernet -NIC Physikalische Adresse . . . . . . : 00-30-4F-0A-E8-25 DHCP aktiviert . . . . . . . . . : Nein IP-Adresse. . . . . . . . . . . . : 192.168.1.30 Subnetzmaske . . . . . . . . . . : 255.255.255.0 Standardgateway . . . . . . . . . : 192.168.1.1 DNS-Server . . . . . . . . . . . : 192.168.1.30 Primärer WINS-Server . . . . . . : 192.168.1.30 Zitieren
menkee 10 Geschrieben 19. Juli 2006 Autor Melden Geschrieben 19. Juli 2006 Meinst du ein Ordner der nur Company.local heisst? - Nein Unter der Forward Lookupzonen steht: msdcs.company.local dc domains gc pdc und dann kommt die reverse lookupzone - die ist leer Zitieren
IThome 10 Geschrieben 19. Juli 2006 Melden Geschrieben 19. Juli 2006 Dort musst Du eine Zone erstellen, die company.local heisst, die Active Directory integriert ist und Nur sichere Updates zulässt. Dann erstellst Du noch eine Reverse Lookup Zone , die ebenfalls Active Directory integriert ist und auch Nur Sichere Updates zulässt. Im Assistenten gibst Du die ersten 3 Zahlen Deiner IP-Adresse an (192.168.1). Danach führst Du IPCONFIG /REGISTERDNS und NETDIAG /FIX aus und überprüfst, ob Einträge geschrieben werden. Dann teste nochmal mit NETDIAG und poste das Ergebnis ... Zitieren
menkee 10 Geschrieben 19. Juli 2006 Autor Melden Geschrieben 19. Juli 2006 Netcard queries test . . . . . . . : Passed GetStats failed for 'Parallelanschluss (direkt)'. [ERROR_NOT_SUPPORTED] GetStats failed for 'WAN-Miniport (PPTP)'. [ERROR_NOT_SUPPORTED] GetStats failed for 'WAN-Miniport (PPPOE)'. [ERROR_NOT_SUPPORTED] [WARNING] The net card 'WAN-Miniport (IP)' may not be working because it has not received any packets. GetStats failed for 'WAN-Miniport (L2TP)'. [ERROR_NOT_SUPPORTED] Per interface results: Adapter : LAN-Verbindung Netcard queries test . . . : Passed Host Name. . . . . . . . . : london IP Address . . . . . . . . : 192.168.1.30 Subnet Mask. . . . . . . . : 255.255.255.0 Default Gateway. . . . . . : 192.168.1.1 Primary WINS Server. . . . : 192.168.1.30 Dns Servers. . . . . . . . : 192.168.1.30 AutoConfiguration results. . . . . . : Passed Default gateway test . . . : Passed NetBT name test. . . . . . : Passed [WARNING] At least one of the <00> 'WorkStation Service', <03> 'Messenger Service', <20> 'WINS' names is missing. WINS service test. . . . . : Passed Global results: Domain membership test . . . . . . : Passed NetBT transports test. . . . . . . : Passed List of NetBt transports currently configured: NetBT_Tcpip_{F40806C5-C425-49C7-B0F3-A2026822EF60} 1 NetBt transport currently configured. Autonet address test . . . . . . . : Passed IP loopback ping test. . . . . . . : Passed Default gateway test . . . . . . . : Passed NetBT name test. . . . . . . . . . : Passed [WARNING] You don't have a single interface with the <00> 'WorkStation Service', <03> 'Messenger Service', <20> 'WINS' names defined. Winsock test . . . . . . . . . . . : Passed DNS test . . . . . . . . . . . . . : Passed PASS - All the DNS entries for DC are registered on DNS server '192.168.1.30'. Redir and Browser test . . . . . . : Passed List of NetBt transports currently bound to the Redir NetBT_Tcpip_{F40806C5-C425-49C7-B0F3-A2026822EF60} The redir is bound to 1 NetBt transport. List of NetBt transports currently bound to the browser NetBT_Tcpip_{F40806C5-C425-49C7-B0F3-A2026822EF60} The browser is bound to 1 NetBt transport. DC discovery test. . . . . . . . . : Passed DC list test . . . . . . . . . . . : Passed Trust relationship test. . . . . . : Skipped Kerberos test. . . . . . . . . . . : Passed LDAP test. . . . . . . . . . . . . : Passed Bindings test. . . . . . . . . . . : Passed WAN configuration test . . . . . . : Skipped No active remote access connections. Modem diagnostics test . . . . . . : Passed IP Security test . . . . . . . . . : Skipped Note: run "netsh ipsec dynamic show /?" for more detailed information The command completed successfully Zitieren
IThome 10 Geschrieben 19. Juli 2006 Melden Geschrieben 19. Juli 2006 Na das sieht doch schnuckelig aus, hast Du in der Forward Zone auch einen grauen _MSDCS Eintrag ? Gib mal NSLOOKUP ein , gibt es einen Fehler ? Wenn beides passt, starte mal einen Client durch und melde Dich an (besser 2 oder 3 Mal) und prüfe , ob die Richtlinie greift ... Zitieren
menkee 10 Geschrieben 19. Juli 2006 Autor Melden Geschrieben 19. Juli 2006 In der Forward Lookupzone habe ich nur msdcs.company.local und darunter den company.local......nichts graues. GPO greift nicht....nachdem ich Benutzername und Passwort eigebe, dauert es bis zu 12 Sek bis er das Profil hochfährt - zulange. Zitieren
IThome 10 Geschrieben 19. Juli 2006 Melden Geschrieben 19. Juli 2006 Klick mal mit rechts auf company.local - Neue Delegierung - Weiter - _msdcs eingeben - Weiter - Hinzufügen - Durchsuchen - <Server> - Forward Lookup Zonen - company.local - london und dann Ok , Weiter , Fertigstellen ... Zitieren
menkee 10 Geschrieben 19. Juli 2006 Autor Melden Geschrieben 19. Juli 2006 Grauer mcdcs ist nun unter company.local ersichtlich. GPO greifen aber noch immer nicht........ Ich fühle es wir haben es fast geschaft :D Zitieren
Das Urmel 10 Geschrieben 19. Juli 2006 Melden Geschrieben 19. Juli 2006 Soweit ich mich erinnere Weiter - _msdcs eingeben ipconfig / [flushdns | registerdns] net stop netlogon, net start netlogon oder verwurstele ich nun was? Zitieren
IThome 10 Geschrieben 19. Juli 2006 Melden Geschrieben 19. Juli 2006 NSLOOKUP ist ohne Fehler gelaufen ? Firewall auf dem Server ist aus (auf dem Client auch) ? Bitte mal IPCONFIG /ALL des Clients und dort auch IPCONFIG /REGISTERDNS und NSLOOKUP ... Zitieren
