Exmerge Problem
Microsoft Exchange Mailbox Merge Program, v6.5.7529.0
Start Logging:July 24, 2006 12:03:39
[12:03:39] Logging Level: Maximum
[12:03:39] The log file specified in the .INI file (C:\ExMerge.log) is invalid or inaccessible. Using this default log file instead.
[12:03:39] Reading settings from file 'E:\Exchange\bin\EXMERGE.INI'.
[12:03:39] Data directory name read from .INI file: 'C:\EXMERGEDATA'.
[12:03:39] Merge action read from .INI file: 0
[12:03:39] DomainControllerForSourceServer read from INI file: ''
[12:03:39] SrcServerLDAP-Port read from INI file: ''
[12:03:39] Source server name read from .INI file: 'COMPUTER'.
[12:03:39] Entered Routine: (CADRoutines::IdentifyFamilyOfExchangeRunningOnServer)
[12:03:39] Entered Routine: (CADRoutines::GetNamingContextData)
[12:03:39] BaseDN: 'LDAP://COMPUTER/rootDSE'
[12:03:44] Error 8007203a opening an LDAP connection. ('LDAP://COMPUTER/rootDSE') (CADRoutines::GetNamingContextData)
[12:03:44] Ending Routine: (CADRoutines::GetNamingContextData)
[12:03:44] Entered Routine: (CADRoutines::GetNamingContextData)
[12:03:44] BaseDN: 'LDAP://rootDSE'
[12:03:44] Default Naming Context: 'DC=kanalserver,DC=de'
[12:03:44] Accessing Domain Controller 'Kanal1'
[12:03:44] Entered Routine: (CADRoutines::GetExchangeServerNameInfo)
[12:03:44] BaseDN: 'LDAP://Kanal1/CN=Microsoft Exchange,CN=Services,CN=Configuration,DC=kanalserver,DC=de'
[12:03:44] Got IDirectorySearch interface
[12:03:44] Set search preferences
[12:03:44] Filter used: '(&(objectCategory=msexchExchangeServer)(cn=COMPUTER))'
[12:03:44] Successfully executed directory search
[12:03:44] Error! Server COMPUTER is not listed as an Exchange 2000 server in the Active Directory on server Kanal1. (CADRoutines::GetExchangeServerNameInfo)
[12:03:44] Ending Routine: (CADRoutines::GetExchangeServerNameInfo)
[12:03:44] Entered Routine: (CADRoutines::GetOrgSiteInfoUsingDAPI)
[12:03:46] Error getting organization and site information from server 'COMPUTER', using DAPI
[12:03:46] The specified server 'COMPUTER' is inaccessible. It is not an Exchange Server or a domain controller is unavailable or you do not have the necessary rights to access this server or the LDAP port specified in incorrect.
[12:03:46] Ending Routine: (CADRoutines::IdentifyFamilyOfExchangeRunningOnServer)
[12:03:46] DomainControllerForDestServer read from INI file: ''
[12:03:46] SrcServerLDAP-Port read from INI file: ''
[12:03:46] Destination server name read from .INI file: ''.
[12:03:46] Message selection start date read from .INI file: ''.
[12:03:46] Reading list of subjects for messages to be selected from file ''
[12:03:46] Subject string match criteria read from INI file: 0
[12:03:46] Reading list of attachment names for messages to be selected from file ''
[12:03:46] Attachment name string match criteria read from INI file: 1
[12:03:46] Folder process setting read from .INI file: 2
[12:03:46] Apply to sub folders setting, read from .INI file: 1
[12:03:46] List of folders to be ignored has been read. 0 folders in the list.
[12:03:46] Program will also ignore sub folders of selected folders.
[12:03:46] DelimiterUsedInMailboxFile setting read from .INI file: 0
[12:03:46] File containing list of mailboxes, read from .INI file: ''.
[12:03:46] Remove intermediate PST files setting read from .INI file: 1
[12:03:46] Date attribute read from .INI file: 0
[12:03:46] Data import method read from .INI file: 2
[12:03:46] ReplaceDataOnlyIfSourceItemIsMoreRecent setting read from .INI file: 1
[12:03:46] Copy user data setting read from .INI file: 1
[12:03:46] Copy associated folder data setting read from .INI file: 1
[12:03:46] Copy folder permissions setting read from .INI file: 1
[12:03:46] Copy dumpster items setting read from .INI file: 1
[12:03:46] UseThisPSTFileForAllMailboxes setting read from .INI file: ''
[12:03:46] MapFolderNameToLocalisedName setting read from .INI file: 1
[12:03:46] Folder names mapping to localised names is enabled.
[12:03:46] RenameFoldersBasedOnFolderMappings setting read from INI file: 0
[12:03:46] RenameSpecialFolders setting read from INI file: 1
[12:03:46] Default Locale read from INI file: 1031
[12:03:46] UseLastLogonLocaleID setting read from INI file: 0
[12:03:46] Current machine locale ID is 0x407
[12:03:46] Command line received:
[12:03:46] Processor architecture: Intel
[12:03:46] Operating System Version 5.2 (Build 3790)
[12:03:46] Personal Folders service name got from EXMERGE.INI file is 'Persönliche Ordner' (LocalisedPersonalFoldersServiceName entry in section [EXMERGE]).
[12:03:46] Exchange Server service name got from EXMERGE.INI file is 'Microsoft Exchange-Nachrichtenspeicher' (LocalisedExchangeServerServiceName entry in section [EXMERGE]).
[12:03:51] MAPI uninitialized.
Hi,
Das ist wohl dein Problem:
Das Konto, das Exmerge ausführt, braucht Receive As und Send As Berechtigungen auf die Mailboxen und die scheinen manchmal von Allow auf Deny gesetzt zu werden.
Siehe auch:
http://support.microsoft.com/default.aspx?scid=kb;en-us;Q323546
Christoph
Leider nein , habe das grad Probiert und Admin und Domainadmin hat Vollzugriff
Wo hast Du das nachgeschaut? Unter Exchange Erweitert/Postfach Berechtigungen? Wenn Du da Vollzugriff aktivierst, ist Receive As und Send As noch nicht aktiv: Es gibt noch die Sicherheitseinstellungen für das Userkonto. Da muss Receive As und Send As aktiviert werden.
Christoph
