Eine SQL Frage
Hallo Leute,
könnte einer von euch mir bei der Frage helfen, bin mir bei der antwort nicht sicher!
Ich tendiere auf B (es über die Spalte zu suchen),
was meint ihr so?
You are a database developer for Company.com You are designing a query that calculates the
number of orders that were made on October 27, 2005.
The Orders table is designed as shown in the following display.
OderID (PK) OrderDate …
int datetime …
An index is defined on the OrderDate column. You need to design the query to provide the fastest
performance.
Which Transact-SQL query should you use?
A. SELECT COUNT(*) FROM OrdersWHERE OrderDate BETWEEN '2005-10-26T00:00:00'
AND '2005-10-28T00:00:00'
B. SELECT COUNT(*) FROM OrdersWHERE CONVERT(CHAR(8), OrderDate, 112) =
'20051027'
C. SELECT COUNT(*) FROM OrdersWHERE YEAR(OrderDate) = 2005 AND
MONTH(OrderDate) = 10
AND DAY(OrderDate) = 27
D. SELECT COUNT(*) FROM OrdersWHERE DATEDIFF(day, OrderDate, '20051027') = 0
SELECT COUNT(*) FROM OrdersWHERE OrderDate >= '20051027' AND OrderDate <
'20051028'
Vielen Danke!!!!
