Printservermigration schlägt fehl
ich versuche Drucker von 2000 auf 2003 zu migrieren. Backup läuft ohne Fehler (laut LOG) und alle 237 Drucker werden gesichert.
Beim Restore auf den 2003 werden nur 87 Drucker importiert. Das ganz führe ich mit Print Migrator 3.1 von Microsoft durch.
Woran könnte das liegen? Gibt es vielleicht noch ein anderes Tool?
tott
Hi,
ja hab ich.
Hier ein Auszug:
2006:08:16 09:58:33 WARNING: Kernel Mode drivers (version 2) are blocked on the target machine. Disable Kernel Mode driver blocking and re-run Printer Migrator. Ignoring this warning (Cancel button) will result in driver installation, but because they are kernel mode drivers - a serious problem with any dependent print queue could potentially bring down the system. Selecting OK will result in restore termination.
2006:08:16 09:59:02 The administrator has chosen to install Kernel Mode drivers on the target even though the 'Dissallow installation of printers using kernel-mode drivers' policy is enabled on the target.
2006:08:16 09:59:03 Added version 2 driver: Brother HL-1250 series
2006:08:16 09:59:03 Added version 2 driver: Brother HL-1470N series
2006:08:16 09:59:03 Added version 2 driver: Brother HL-2060 series
2006:08:16 09:59:03 Added version 2 driver: HP 2000C
2006:08:16 09:59:16 Bad version 2 driver: HP DeskJet 1220C Printer
2006:08:16 09:59:16 winerror.h - 3014
2006:08:16 09:59:16 Added version 2 driver: HP DeskJet 660C
2006:08:16 09:59:16 Added version 2 driver: HP DeskJet 690C
2006:08:16 09:59:16 Added version 2 driver: HP DeskJet 850C
2006:08:16 09:59:16 Added version 2 driver: HP DeskJet 890C
2006:08:16 09:59:16 Added version 2 driver: HP DeskJet 895Cxi
2006:08:16 09:59:17 Added version 2 driver: HP LaserJet 2100 Series PCL 6
2006:08:16 09:59:18 Added version 2 driver: HP LaserJet 2300 Series PCL6
2006:08:16 09:59:18 Added version 2 driver: HP LaserJet 4
2006:08:16 09:59:18 Added version 2 driver: HP LaserJet 6P
2006:08:16 09:59:18 Added version 2 driver: IBM Network Printer 12 (PCL)
2006:08:16 09:59:19 Added version 2 driver: OKI C7200 (PCL)
2006:08:16 09:59:19 Copying W32X86 version 3 files to target ...
2006:08:16 09:59:19 Done.
2006:08:16 09:59:19 Driver "AGFA-AccuSet v52.3": the file AGACCST1.PPD is missing from the CAB
Es muss irgendwie mit der Warnungsmeldung zusammenhängen, aber ich kann damit nichts so richtig anfangen.
tott
Du solltest in der Gruppenrichtlinie die Installation von Kernelmode-Druckertreibern erlauben.
Edit: Kannst du nach der Installation auch wieder verbieten...
Ich kann dir so nicht sagen, welches bei dir das richtige GPO ist... wenn es ein Domänencontroller ist, eben die Richtlinie für Domänencontroller, wenn nicht, dann eben eine für die entsprechende OU...
Du kannst es auch lokal einstellen für den einzelnen Rechner, mit gpedit.msc. Wird aber u.U. eben von einer anderen Richtlinie dann überschrieben.
Ach ja: die Einstellung an sich befindet sich unter Administrative Vorlagen/Drucker
Ich setze generell die Einstellung wegen den Kerneltreibern damit auch User sich Netzwerkdrucker mounten können.
In den OU's findest du es hier:
Computer Conf. \ Adm.Templates \ Printers
--> Disallow installation of printers using kernel-mode drivers : Disabled
zusätzlich konfiguriere ich dann immer die Point & Print Beschränkungen
User Conf. \ Adm.Templates \ Control Panel / Printers
--> Point and Print Restictions : Disabled
Gruß Siebenburg
also das mit dem Kernel-Mode-Drivers hat sich erledigt. :)
Jetzt habe ich das Problem das Druckertreiber vorhanden sind, die nicht mit 2003 kompatibel sind. Diese werden nicht mit importiert.
Wie kann ich das am besten umgehen? Ich brauche diese Drucker auch auf dem neuen Printserver. Muss ich diese jetzt alle manuell ändern? :confused:
tott
hab heue morgen einen Drucker mit einem Treiber für 2000/2003 installiert. Dann nochmals gesichert und zurückgespielt. Ergebnis: Der Drucker wird immer noch nicht auf dem neuen Server installiert.
tott
