roxor 10 Geschrieben 15. September 2006 Melden Geschrieben 15. September 2006 Hey Leute Seit ich ein Programm namens PDFMerge testeshalber installiert hab, funzt in Cygwin so ziemlich nix mehr! Dies ist ein Command-Line tool, was, soviel ich sehen kann, auf Cygwin aufbaut...jedenfalls sind im Verzeichnis /bin dieses Programms einige cygwin-spezifische Dateien. Wenn ich nun cygwin starte, erscheinen folgende Fehlermeldungen: ************** 180 [main] ? (3864) c:\Documents and Settings\Administrator\My Documents\Stu dium\Skripte\Bsys2\PDFMerge\bin\id.exe: *** fatal error - c:\Documents and Setti ngs\Administrator\My Documents\Studium\Skripte\Bsys2\PDFMerge\bin\id.ex e: *** sy stem shared memory version mismatch detected - 0x75BE0084/0x75BE009C. This problem is probably due to using incompatible versions of the cygwin DLL. Search for cygwin1.dll using the Windows Start->Find/Search facility and delete all but the most recent version. The most recent version *should* reside in x:\cygwin\bin, where 'x' is the drive on which you have installed the cygwin distribution. Rebooting is also suggested if you are unable to find another cygwin DLL. 2316 [main] ? (376) c:\Documents and Settings\Administrator\My Documents\Stud ium\Skripte\Bsys2\PDFMerge\bin\tr.exe: *** fatal error - c:\Documents and Settin gs\Administrator\My Documents\Studium\Skripte\Bsys2\PDFMerge\bin\tr.ex e: *** sys tem shared memory version mismatch detected - 0x75BE0084/0x75BE009C. This problem is probably due to using incompatible versions of the cygwin DLL. Search for cygwin1.dll using the Windows Start->Find/Search facility and delete all but the most recent version. The most recent version *should* reside in x:\cygwin\bin, where 'x' is the drive on which you have installed the cygwin distribution. Rebooting is also suggested if you are unable to find another cygwin DLL. 1333 [main] ? (182 c:\Documents and Settings\Administrator\My Documents\Stu dium\Skripte\Bsys2\PDFMerge\bin\sed.exe: *** fatal error - c:\Documents and Sett ings\Administrator\My Documents\Studium\Skripte\Bsys2\PDFMerge\bin\sed.e xe: *** system shared memory version mismatch detected - 0x75BE0084/0x75BE009C. This problem is probably due to using incompatible versions of the cygwin DLL. Search for cygwin1.dll using the Windows Start->Find/Search facility and delete all but the most recent version. The most recent version *should* reside in x:\cygwin\bin, where 'x' is the drive on which you have installed the cygwin distribution. Rebooting is also suggested if you are unable to find another cygwin DLL. .... ..... ...... $ ************** Es scheint mir so, als ob durch das Ausführen dieses Programms die originalen cygwin1.dll und andere Dateien überschrieben wurden. Da dachte ich mir einfach, ich könnte diesen Ordner löschen und cygwin-base nochmals drüber installieren. *Komischerweise* wird bei diesem Schritt der *vorher gelöschte* Ordner 'PDFMerge' vom Cygwin-Setup wiederhergestellt und es werden höchstwahrscheinlich Verlinkungen mit diesen Dateien darin gemacht. Auch wenn ich die von Cygwin angelegten Installationsordner lösche und das ganze wiederhole, wird dieser Ordner 'PDFMerge' wiederhergestellt, aus welchen Gründen auch immer. Hat vielleicht jemand ne Idee, was ich machen könnte? Auch das herunterladen einer cygwin1.dll hat nichts geholfen. Es scheint mir so, als irgendwo in cygwin eingetragen wurde, dass nun auf das Verzeichnis c:\Documents and Settings\Administrator\My Documents\Studium\Skripte\Bsys2\PDFMerge\bin\ zugegriffen werden muss, wenn ich Cygwin starte. Falls dies nicht besteht, soll es angelegt und mit den benötigten Dateien gefüllt werden. Leider hab ich keine Ahnung, was ich noch machen soll. Das ganze ist sehr lästig, das andere Programme, wie z.B. die Entwicklungsumgebung Eclipse auf Cygwin angewiesen sind (Compiler) und diese nun auch nicht mehr richtig funzen. Ich hoffe, jemand kann mir helfen! mfg rox Zitieren
roxor 10 Geschrieben 17. September 2006 Autor Melden Geschrieben 17. September 2006 Hey Leute Hab die Lösung gefunden! Und zwar hab ich nach langem Probieren und Fluchen die Registry durchsucht und bin tatsächlich fündig geworden. Es waren die falschen Pfade unter Cygwin eingetragen, welche dann zu diesen Problemen führten! Jetzt läuft alles wieder! mfg rox Zitieren
Damian 1.665 Geschrieben 17. September 2006 Melden Geschrieben 17. September 2006 Super. Danke für die Infos. :thumb1: Damian Zitieren
