jan66 10 Geschrieben 21. September 2006 Melden Geschrieben 21. September 2006 Seit der Installation der letzten Updates für WinXP stürzt mein Rechner immer wieder mit dem Code 0x0000008E ab. Ich habe hier mal den Minidump: KERNEL_MODE_EXCEPTION_NOT_HANDLED_M (1000008e) This is a very common bugcheck. Usually the exception address pinpoints the driver/function that caused the problem. Always note this address as well as the link date of the driver/image that contains this address. Some common problems are exception code 0x80000003. This means a hard coded breakpoint or assertion was hit, but this system was booted /NODEBUG. This is not supposed to happen as developers should never have hardcoded breakpoints in retail code, but ... If this happens, make sure a debugger gets connected, and the system is booted /DEBUG. This will let us see why this breakpoint is happening. Arguments: Arg1: c0000005, The exception code that was not handled Arg2: bab92928, The address that the exception occurred at Arg3: f8047a20, Trap Frame Arg4: 00000000 Debugging Details: ------------------ EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - Die Anweisung in "0x%08lx" verweist auf Speicher in "0x%08lx". Der Vorgang "%s" konnte nicht auf dem Speicher durchgef hrt werden. FAULTING_IP: +ffffffffbab92928 bab92928 8a1401 mov dl,byte ptr [ecx+eax] TRAP_FRAME: f8047a20 -- (.trap fffffffff8047a20) ErrCode = 00000000 eax=00000000 ebx=bab9894a ecx=0101e000 edx=804dd250 esi=00002000 edi=0101c000 eip=bab92928 esp=f8047a94 ebp=f8047aa0 iopl=0 nv up ei pl nz na pe nc cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010206 bab92928 8a1401 mov dl,byte ptr [ecx+eax] ds:0023:0101e000=?? Resetting default scope CUSTOMER_CRASH_COUNT: 12 DEFAULT_BUCKET_ID: COMMON_SYSTEM_FAULT BUGCHECK_STR: 0x8E PROCESS_NAME: WindowsXP-KB922 LAST_CONTROL_TRANSFER: from bab947d8 to bab92928 STACK_TEXT: WARNING: Frame IP not in any known module. Following frames may be wrong. f8047aa0 bab947d8 0101c000 0000001e bab9894a 0xbab92928 f8047af4 bab948e8 826a8da0 01000000 01000218 0xbab947d8 f8047b58 bab949e1 826a8da0 e1f12268 822d5da8 0xbab948e8 f8047b78 805f9351 00000cf4 826a8da0 00000001 0xbab949e1 f8047cc4 8057b2a3 0151f548 001f03ff 00000000 nt!NtSetInformationProcess+0xd64 f8047d3c 804de7ec 0151f548 001f03ff 00000000 nt!IopParseDevice+0x7d3 f8047d64 7c91eb94 badb0d00 0151f180 ba31bd98 nt!KiUnexpectedInterrupt65+0x2 f8047d68 badb0d00 0151f180 ba31bd98 ba31bdcc 0x7c91eb94 f8047d6c 0151f180 ba31bd98 ba31bdcc 00000000 0xbadb0d00 f8047d70 ba31bd98 ba31bdcc 00000000 00000000 0x151f180 f8047d74 ba31bdcc 00000000 00000000 00000000 0xba31bd98 f8047d78 00000000 00000000 00000000 00000000 0xba31bdcc STACK_COMMAND: kb FOLLOWUP_IP: nt!NtSetInformationProcess+d64 805f9351 ?? ??? SYMBOL_STACK_INDEX: 4 SYMBOL_NAME: nt!NtSetInformationProcess+d64 FOLLOWUP_NAME: MachineOwner MODULE_NAME: nt IMAGE_NAME: ntoskrnl.exe DEBUG_FLR_IMAGE_TIMESTAMP: 42250ff9 FAILURE_BUCKET_ID: 0x8E_nt!NtSetInformationProcess+d64 BUCKET_ID: 0x8E_nt!NtSetInformationProcess+d64 Followup: MachineOwner --------- Vielleicht kann mir jemand helfen. Danke Zitieren
weg5st0 10 Geschrieben 21. September 2006 Melden Geschrieben 21. September 2006 Das sieht aber mehr nach einer Backdoor aus: The HaxDoor virus may cause a "STOP 0x00000050" or "STOP 0x0000008e" error message Zitieren
